Best year of the Iron Duke? - S-10 Forum
post #1 of 17 Old 01-17-2013, 03:15 PM Thread Starter
User is: ChevyJoe is offline
Searching for a standard cab/short box s10/sonoma with the 2.5L and 5 speed. After doing some searching it looks like the '93 model year produced the most power. Is this correct?
Since you guys are the experts, what year should I be looking for?
Also have ?'s about what tran(s) came behind the 2.5L through the years and if any of the 5 speeds came with hydraulic clutches but still need to do some more searching on those.
ChevyJoe is offline
post #2 of 17 Old 01-17-2013, 03:22 PM
zach 89s10's Avatar
User is: zach 89s10 is offline
Re: Best year of the Iron Duke?
91-93 code "A" has the best flowing head an the most aggressive cam.. look at different forums on here here, you'll learn alot.
89 short bed- sold
tech 4
5 speed
lowered 3/4
post #3 of 17 Old 01-17-2013, 03:40 PM Thread Starter
Looks like 91-93 it is. I will be converting to propane through this kit from gotpropane: http://www.gotpropane.com/p564.html
The reason for this is because most of the guy's I wheel with run propane (spare tanks) and propane is SO much simpler than dealing with sensors, wiring, and tbi in general.
Is there a link where I can find what transmissions came behind the 91-93 2.5L's?
ChevyJoe is offline
post #4 of 17 Old 01-17-2013, 04:30 PM
zach 89s10's Avatar
Not that I know of, maybe mad Max or ed123 will weigh on, they know a good bit about them also, the t5 is the same as the 2.8's. The "60 degree bolt pattern" the 3.4 has the same also.
89 short bed- sold
tech 4
5 speed
lowered 3/4
post #5 of 17 Old 01-18-2013, 02:11 AM Thread Starter
I thought I read the the iron duke has the same transmission bolt pattern as the small block and big block chevys?
ChevyJoe is offline
post #6 of 17 Old 01-18-2013, 02:48 AM
No longer a pizza tech.
90blueS10's Avatar
User is: 90blueS10 is offline
Nope. Thats the 4.3
Ryan
90 2.5 5 speed, bag project
01 Jimmy 2dr 2wd daily driver
post #7 of 17 Old 01-18-2013, 07:46 AM
zach 89s10's Avatar
The old "stove bolt" ones did, the 2.5 that come in the Chevy 2's and Nova's, there the 153, our 2.5's is the 151, there a completely different motor.
89 short bed- sold
tech 4
5 speed
lowered 3/4
post #8 of 17 Old 01-22-2013, 12:56 AM Thread Starter
What about the newer 2.2L's?
ChevyJoe is offline
post #9 of 17 Old 01-22-2013, 09:17 AM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
CJ, early RWD 2.5s had the SBC bellhousing bolt pattern. You will find those in Monzas, AMC Jeeps, early AMC Spirits, Buick Skylarks, etc.
All of the later (after 85) Dukes had the FWD Bhousing bolt pattern.
Zach has it right... 110 HP in the last A code version. The 8th digit on your VIN is the engine code. This tells you what the truck had for original power.
The T5s were basically the same for all S10s, they are light duty versions. The Camaro/Firebirds and Ford T5s were totally different. They were heavier, had the shifter in a different location and the GMs were 'clocked' 18* to the right. You can make them work in a Dime, but they need considerable mods and different combination of parts (like the clutch and flywheel are different from the S10 counterparts).
There has been talk of the 2.5 and 2.8 trannys having different gear ratios in 5th, but I am unable to confirm that.
Otherwise, the 2.5 and 2.8 T5s are totally interchangeable.
More important than the tranny ratios (if you are looking for mileage) is the rear end gear ratio. Getting good mileage is a combination of factors. You need to have the best ratio for all around driving for best mileage. If you are going to go wheeling in the woods, forget about mileage. You will need the highest (numerically) ratio you can get for slow cruising. Like 4.56 to 1 or something.
Anyway, good luck with your build/project.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best) Sold
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #10 of 17 Old 01-23-2013, 07:07 PM
zach 89s10's Avatar
I don't know a thing about the 2.2, other than I know that they actually do make a few adtermarket parts for them, they've got to much electronics and hoses on them for me, I'm young but I'm all for the old school, my dime is older than me
89 short bed- sold
tech 4
5 speed
lowered 3/4
post #11 of 17 Old 01-31-2013, 09:18 AM
Boozebag
Mad Max's Avatar
What a howl...
I don't own anything older than me... that would be pretty tough since I'm sort of dusty.
My oldest vehicle is a 1958 Wolseley...
Looks EXACTLY like this
S10 addiction:
Mad Max is offline
post #12 of 17 Old 01-31-2013, 12:21 PM
zach 89s10's Avatar
Max how many vehicles Do u have?? Lol
89 short bed- sold
tech 4
5 speed
lowered 3/4
post #13 of 17 Old 02-11-2013, 03:58 PM
Boozebag
Mad Max's Avatar
^^^^ I haven't counted but it is safe to say .... ALOT.
I have a dealer's license and have dealer tags so it's easy to drive different vehicles.
Someday I'll post a thread with some of the shizzboxes I own. Probably somewhere in the range of 40.
As you know, I have (7) S10s to start the count.
It's a damn disease I tell you.
I am currently buying a Nissan pickup with a Ford Thunderbird turbo engine in it...
S10 addiction:
Mad Max is offline
post #14 of 17 Old 02-11-2013, 10:06 PM
zach 89s10's Avatar
My service manager at work is a nut over the hardbodys an 240's. I'd love to have a KA 24 in a s10. They actually make parts for those
89 short bed- sold
tech 4
5 speed
lowered 3/4
post #15 of 17 Old 02-11-2013, 10:07 PM
zach 89s10's Avatar
2.3 Turbo?
89 short bed- sold
tech 4
5 speed
lowered 3/4
post #16 of 17 Old 02-13-2013, 12:53 PM
Boozebag
Mad Max's Avatar
2.3 Turbo?
Yeah, the 2.3. The install looks good, althought the truck doesn't have an intercooler. I can see alot of improvements that would make the truck a screamer. The 2.3 Ford is a pretty rugged engine. They put them in everything.
It has a 5 speed behind it and looks like it belongs in the truck.
Bigger turbo, injectors, downpipe, intercooler and the truck could definately qtr mile or be a drifter...
I also recently bought an '89 240SX with an RB20DET in it. Totally set up. Guy spent over 15K on it.
S10 addiction:
Mad Max is offline
post #17 of 17 Old 02-13-2013, 01:48 PM
zach 89s10's Avatar
My boss is putn a smallblock in his lol I've been helpn him, tight fit! Lol
89 short bed- sold
tech 4
5 speed
lowered 3/4
