'92 2.5 married to twin Weber DCOE Webers - S-10 Forum
post #1 of 7 Old 01-14-2009, 10:45 PM Thread Starter
User is: Alsfarms is offline
I am desiring to discuss the installation of twin Weber 45's on my 1992 S10 2.5. I have the Weber carb's and manifold. I also have an earlier 2.5 HEI distributor. The project I will be putting it in may weigh about 1,800 lbs. I also will be using a Camaro T5 trans. I have acquired a couple of sets of high compression .040 over pistons. Could someone share a bit of knowledge and experience as I get going on this rebuild.
Al
Alsfarms is offline
post #2 of 7 Old 01-15-2009, 11:05 AM
Cool, Tight, & STRONG....
Steady Eddie's Avatar
User is: Steady Eddie is offline
Lightbulb Re: '92 2.5 married to twin Weber DCOE Webers
Al
Al--
You will be very happy with the side draft Webers on the Iron Duke.
40mm size would be better, but since you already have the 45s you can install smaller venturis and gain drive ability. With the Duke's displacement, think 32mm or MAYBE 34mm venturis...also you need the anti-vibration
mounts (gaskets) to isolate the float bowls from the Duke's vibration shakes. You also need a vacuum source for the vacuum advance of the distributor, do the Webers provide a port??
Standard thinking on over boring the Duke says to stick with a 30-thou overbore, as your 40-thou pistons will weaken the block quite a bit, but they may do alright so long as your "project" is a part-time driver and not a daily.
The smaller venturis and the anti-vibration mounts are a must have....
The tail shaft housing off a S10 moves the shifter forward and should be a bolt-on if you want to relocate it farther towards the engine...
Steady Eddie
1989 S-10
Short Wide
Tech 4 2.5 L.
5-spd Manual
My "tune"--
http://www.s10forum.com/forum/f104/i...2/#post7492162
post #3 of 7 Old 01-15-2009, 02:32 PM Thread Starter
Thanks for your reply. I studied, as best as I could, the various charts and graphs that assist with sizing the chokes for the Webers. I decided based on the S10 being a 2.5 and not a 2.0 I should use the 45's according to the curves. I am not after a high end screamer at all! However, I do desire a stout runner in the mid range. Max at 5000 rpms. I do have a couple of questions, will the Camaro T5 bolt right up to my S10 bellhousing? For my application I want the shifter back as far as I can get it. Second question, I had someone tell me that the 92 S10 2.5 block will not work to drive an older series HEI unit. Is that correct or wrong. If you have any other ideas on the Weber carb setup. Please speak up. If 45's are a bit oversized, I could resale them and go with 40's. I want this project to be a very drivable unit.
Regards,
Al
Alsfarms is offline
post #4 of 7 Old 01-15-2009, 07:05 PM
User is: bear76 is offline
Where did you get the manifold?
bear76 is offline
post #5 of 7 Old 01-15-2009, 08:32 PM
Regards,
Al
Al--
If you can sell the 45s, do it. The 40mm Webers will allow for more velocity to the head. Velocity of flow at low RPMs is what you want. And the 40s have it in spades. The bigger 45s will act just like an oversized exhaust system on the "other" flow side of the Iron Duke cylinder head. Lots of volume, but low exhaust flow velocity. On the intake side, carbs too big equals the same high volume and low velocity flow. You want the exhaust note to CRACK when you blip the throttle, not bog...
There are Members here, like Member "Rizzle" that oval track race these motors, using the carbed Citation HEI distributor, and they may be able to confrim or deny if your Code A engine will accept the dizzy you have. IIRC, it should work...
The trans needs to be compared, bell housing-wise, to see if it will fit, but GM did make Iron Duke engined Cameros...with the 5-speeds...
Steady Eddie
1989 S-10
Short Wide
Tech 4 2.5 L.
5-spd Manual
My "tune"--
post #6 of 7 Old 01-15-2009, 09:04 PM Thread Starter
Steady Eddie and Bear76,
The NOS manifold I now have is a purchase from EBAY. The MFG. is Cannon. It is made for the cross flow 2.5 and likely was meant for use in a Fiero. I am certain that I will have not any problem with placing it on my S10 engine. My final project will have lots of engine room also. When I got the Weber DCOE 45's I also got a Datsun 510 intake and linkage. I will evaluate all aspects of 40 or 45 sized Webers before I do anything. If it be that I decide to sell and use 40's I will also have the Datsun manifold to sell. If anyone knows a Datsun guy, head him my way.
Regards, Al
Alsfarms is offline
post #7 of 7 Old 01-18-2009, 03:54 PM
If it fits, I'd love to see a pic.
bear76 is offline
