89 2.5L Surge at a steady Idle
Old 10-15-2009, 06:15 PM   #1
title should have been steady throttle not idle
Ok guys im new to the forum but not new to the 2.5L as I have been trying to figure out what is wrong with mine. At a steady throttle around 30-40 mph it surges bucks misses whatever u wanna call it. I have replaced so many parts here is the list some that may not have any thing to do with the problem but Ill list them anyways. Rear main, clutch, flywheel, cap, rotor button, plugs, wires, Ignition module, fuel pump relay, fuel pressure regulator, supposidly it had a new fuel pump put in it before i got the truck, deleted the egr and have a block off plate i made. Now it doesnt surge all the time, just every now and then... if you give it throttle it stops, if you let off it stops.. just at a steady throttle it does it. So if anyone has any ideas please help!
Old 10-15-2009, 07:43 PM   #2
Sending Big Oil a Message
Steady Eddie's Avatar
Question Re: 89 2.5L Surge at a steady Idle
popo--
The brainbox looks for a lean-out condition at 40 MPH, to "test" the EGR valve. Sooner or later, with the EGR valve gone, or disconnected, it will turn on the SES light and set a code. Has yours done that??
Old 10-15-2009, 07:57 PM   #3
No it hasn't set a light yet and the said condition was there before deleting the egr. So I assume the egr was not the problem.
Old 10-15-2009, 09:51 PM   #4
Map ??
Old 10-15-2009, 09:59 PM   #5
Quote: Originally Posted by Steady Eddie
Map ??
Unplugged all sensors one at a time and held the throttle at a steady idle and it still had a miss.
Old 10-16-2009, 12:46 AM   #6
???maybe something mechanical, a burnt valve??
Old 10-16-2009, 08:41 AM   #7
doesnt use any oil, burn any oil or any odd noises runs like a top other than the studder every once in awhile.. So Im pretty sure the insides are good..im sure if it was a burnt valve you would hear noise and or performance would suffer.....
Old 10-16-2009, 06:07 PM   #8
Wire Splicin Fool :-)
lesterl's Avatar
Checked fuel pressure? Could be a bad pump, even tho you said it was new cheap pumps do crap out easily.
Old 10-17-2009, 11:56 PM   #9
ok fuel pressure good, replaced pick up coil, hall effect switch, coil, still no change. My buddy and I did notcie that the exhaust was kinda coming out slow..new exhaust from cat back about 2-3 months ago. Cat is the original one.. ok Maybe the cat is clogged and or clogging the whole exhaust..pull the little plug outta the bottom and all the bbs go flying.. truck runs even worse.. put the plug back in and still no change.. how can it run worse it has every sensor on it replaced.. had the map sensor checked at the zone.. tested out good..so im at a loss now! gonna cut the cat off and hope thats the problem.. too much backpressure? anyone help is very appreciated.. I have no where else to go other than the cat. oh and we put a new injector in it too! and threw a nod tester on the injector plug.. guess what good.. so the computer is good plus i found out today it has a new one in it! so... anyone?
Old 10-18-2009, 10:29 PM   #10
lesterl's Avatar
How much fuel pressure did you have?
What exactly is it doing worse now, the surge at idle?
Have you tested the TPS? Has it been set up properly?
Vacume Leaks?
Old 10-20-2009, 08:53 PM   #11
ok tested fuel pressure! 12psi what is it supposed to be? and for the hell of it done a compression test. cylinder 1= 105psi cylinder 2= 110psi cylinder 3=95psi and cylinder 4= 95psi...
so what do these numbers tell me?
Old 10-20-2009, 08:59 PM   #12
oh and plugs are showing way lean! could it be that small rubber hose that goes from the pump to the sending unit?
Old 10-20-2009, 09:56 PM   #13
come on guys any help?
Old 10-20-2009, 11:21 PM   #14
lesterl's Avatar
Fuel pressure ok, compression #'s are kinda low.....
How do the plugs look (color).
Old 10-21-2009, 01:11 AM   #15
91MNS10's Avatar
My 91 was just doing the exact same thing and it was the o2 sensor.
Old 10-21-2009, 07:44 AM   #16
Plugs showed way lean. I all ready stated that above! I put a new O2 in it! All ready stated that above too!
Old 10-21-2009, 07:59 PM   #17
Well going to do a leak down test and pull the bed of check to male sure that rubber hose is in good shape. I can run the truck 10 -15 miles an check the radiator cap and it's cold! Any ideas on that? Brand new thermostat put in it last week. Maybe it's not working? So fuel pressure is good! But what explains the lean plugs? There's too many new parts on this thing for it to act like this! Does anyone have a clue? Other than anything allready mentioned and anything that I have said I've done
Old 10-22-2009, 09:37 PM   #18
rideharder's Avatar
ok well i had the same problem with mine. do you have a erg valve in it right now or did you block it off. if you just blocked it off it will make the truck run lean unless you buy a chip for the computer. with my truck i had the exact same situation.... checked everything. all it turned out to be was the egr valve, carbon buildup and had a small leak. be sure you buy the right egr valve too, there are 2 diffrent ones and only one will work on one type of engine. i replaced the egr and all problems were gone.
Old 10-24-2009, 01:19 PM   #19
Their is no way you can delete the EGR valve with a blockoff plate and expect it to work perfectly. Somehow, you need to get that EGR system hooked back up properly. It will never run right with a blockoff plate, as these ECU's use the EGR valve a lot. I need a minimum of PREMIUM gas to keep the detonation down, which is still present, burning away my exhaust valves on LONG hills! A lot of people run them with the EGR unhooked, but it will not run as good as it did when it was new and you WILL burn valves!
Old 10-25-2009, 12:27 PM   #20
Lightbulb Re: 89 2.5L Surge at a steady Idle
popo--
See post 18 above...
Old 10-25-2009, 07:14 PM   #21
well put a new fuel pump in it after inspection of the old one.. hose that connects the sender to the pump was very mushy..new pump in still does it! i did put the egr back on and it still does it! i think i might have a burnt exhaust valve! sound like it? low compression on the back two cylinders! not as much exhaust coming out of the tail pipe as I would like to see.. so does this maybe sound like a likely scenario? i also have the throttle body off torn completely apart and soaking in that chem stuff.. any ideas? where can i find valves for these things?
Old 10-25-2009, 07:53 PM   #22
popo--
You are grasping at straws...I suspect that you re-installed a flaky EGR valve, one that was nipples to the sky, to begin with.
It is very easy to get in over your head, with these little motors.
Believe me, the money is better spent on wine, women, and song...
DO NOT tear into it any farther than you have to.
My '89 had a significant increase in measured compression, and power, after the second oil change, when I went with full Syn 10W-30 wt. oil.
I figure the rings were gummed up.
Sure, it'll be better with a fresh valve grind, but don't spend the cash, if you don't have to...try the cheaper alternatives, first.
Old 10-25-2009, 11:03 PM   #23
lesterl's Avatar
Could be a Head Gasket, or could be as Eddie suggests and the rings are stuck, try seafoaming the hell outt 'er. If it is valves, you could get some grinding solution and do it yourself....
Old 10-26-2009, 09:10 PM   #24
I have sea foamed it! lol.. just put the throttle body back on with all new fresh gaskets.. guess what still does it! Steadit Eddie, it had this problem even with the egr off of it! do you really think an egr valve could reak this much havic? I mean look at all the parts Ive put into this thing and nothing is getting better! If anything it getting worse! I have no where else to go but internally! any other ideas? lol
Old 10-26-2009, 09:53 PM   #25
lesterl's Avatar
I guess I will ask again, what coloration were the plugs.... What do you consider lean?
Old 10-26-2009, 11:02 PM   #26
they are showing lean....i have a new set that i was gonna put in but i dont wanna waste them ya know. they dont look like a brown paper sack. I need to do a compression check again. I didnt pull all the plugs last time i did it! so with cylinder 3 and 4 both reading 95psi I suspect a blown head gasket between them two. If its blown there then those two cylinders could be working together and giving me the same reading! right? so by pulling the plugs and doing it that way I should get a very low reading from those two cylinders!
Old 10-27-2009, 10:18 AM   #27
Quote: Originally Posted by popo09
"...do you really think an egr valve could wreak this much havoc?..."
popo--
Short answer: Yes....
Old 10-28-2009, 01:30 PM   #28
Well I haven't done the compression test again yet, but I feel like explaining more what this thing is doing. When u give it more than 1/4 throttle it boggs out and ocasionally it will backfire through the thirttle body.
Old 10-28-2009, 02:13 PM   #29
DON NOT trust an old EGR valve. Do as Steady Eddie suggested and replace it. You may have installed a leaky EGR back onto it. These EGR's do wreck havoc on the 2.5L and need to be working 100%. You cant eliminate the EGR valve until a correct BRAND NEW AC Delco/Delphi valve (auto or manual) is installed. Even an old cleaned valve may or may NOT work.
Please post back if you have a new valve to try out.
Old 10-28-2009, 04:16 PM   #30
No did not install a new egr. How do you suspect that it's causing it to be a balles wonder after more than 1/4 throttle? I'll do the compression test again and see if that turns up any new evidence.
Old 10-28-2009, 08:53 PM   #31
Well, these EGR's are a nightmare. Some work, most dont. I am assuming that you have already checked your TPS sensor first and got a smooth sweep of voltage, and also am assuming that you CTS sensor has been spec'ed out with an ohm meter at different temps to make sure its OK. I dont know how to check the MAP, but if its not those, then I would go EGR next.
Old 10-29-2009, 08:38 PM   #32
Just checked the compression again with all the plugs out like your supposed to do and it checks out. 135 125 125 and 125psi. So no blown head gasket here. Going to pop the valve cover and check the cam timing by checking the lifters on the compression stroke of each cylinder.
Old 11-01-2009, 07:49 PM   #33
i meant check the cam lift.. seeing if it had a swiped cam lobe and no it doesnt! put the valve cover back on and come to find out it was out of time! So put it in time and it barks second gear now lol.., but it still has the surge that it had when this all started! u can actually look at the injector firing in the tb and see it pulse! so does that point to the computer? anyone have any suggestions?
Old 11-02-2009, 12:04 PM   #34
The surge you are feeling, most likley, is the computer looking for the EGR system. You have deleted it on your ride, and the computer is severely leaning out the fuel mixture. The only way to fix it because of your blockoff plate, is to call Sinister Performance and get a custom chip for $55. They remove the EGR function alltogether, and it seems like its the only way to go.
I did read that you tried installing an old valve, but I did the same and mine isnt working either. Did you put the solenoid back on and both vacuum lines?
Page generated in 1.06547 seconds with 31 queries
[Output: 151.98 Kb. compressed to 139.05 Kb. by saving 12.93 Kb. (8.51%)]
