88 s10 2.5 Valve cover Gasket - S-10 Forum
post #1 of 15 Old 11-19-2011, 04:18 PM Thread Starter
Jonathanr's Avatar
User is: Jonathanr is offline
My 88 s10 is leaking oil at the valve cover gasket again. I replaced it about 2 years ago. the gasket I used was one I found under the seat when I bought the truck. It was quark and still in the box so I figured it was good but it didn't last long. So I am going to replace it soon. Should I use quark or rubber, and do I need to use the RTV make gasket? If so do I use it on both sides of the gasket?
Thanks,
Jonathan
post #2 of 15 Old 11-19-2011, 05:02 PM
No longer a pizza tech.
90blueS10's Avatar
User is: 90blueS10 is offline
I like the cork gaskets myself. And heres how I do my gaskets. Rtv on gasket, stick gasket to valve cover. Then rtv on the bottom of the gasket. A thin layer all the way around on both sides of the gasket Then tighten in an alternating pattern
Ryan
90 2.5 5 speed, bag project
01 Jimmy 2dr 2wd daily driver
post #3 of 15 Old 11-19-2011, 09:29 PM
PinkNoma's Avatar
User is: PinkNoma is offline
Send a message via AIM to PinkNoma
Re: 88 s10 2.5 Valve cover Gasket
My truck had a cork gasket that leaked. I got a rubber felpro gasket for it, which also came with a new EGR gasket. I used spray adhesive when I put it on, and it's all good.
I'm pretty sure I asked the mechanics at my company what they recommended before I did it and they said rubber gasket with spray adhesive.
PinkNoma is offline
post #4 of 15 Old 11-21-2011, 06:42 PM Thread Starter
Jonathanr's Avatar
Well I ended up getting the felpro cork gasket. It was way cheaper and all they had in stock anyway. I will install it like 90blues10 suggested. Thanks for your comments.
post #5 of 15 Old 11-21-2011, 06:45 PM
90blueS10's Avatar
Fact: The gm service manual doesnt even say to use a gasket on these motors. Just rtv silicon.
Ryan
post #6 of 15 Old 11-21-2011, 08:33 PM Thread Starter
Jonathanr's Avatar
Really that's interesting. Do you think that that would work as well?
post #7 of 15 Old 11-21-2011, 08:34 PM
90blueS10's Avatar
definitely not.
Ryan
post #8 of 15 Old 11-22-2011, 12:41 PM
That Other Guy
User is: RocketFast321 is offline
Kind of like the olds 307 that was put together without gaskets, just gasket maker stuff.
post #9 of 15 Old 11-22-2011, 08:37 PM
Hot Rod Enthusiast
s10kid17's Avatar
User is: s10kid17 is offline
Its actually best to use just silicone like GM recommends. It seals a lot better than a cork gasket. Also I wouldn't use silicone on both sides of the gasket. Put it on the valve cover side because it will be easier to get off the next time, instead of scraping it off the head. I used a cork gasket on mine only because my valve cover is bent up. Yet it still leaks.
Mike.
s10kid17 is offline
post #10 of 15 Old 11-22-2011, 09:17 PM Thread Starter
Jonathanr's Avatar
Well I used the cork gasket and put RTV on both sides. I may have used too much RTV but I think my valve cover is also slightly bent. I am letting it set overnight to make sure it all dries and I will see what happens tomorrow.
post #11 of 15 Old 11-22-2011, 09:26 PM
Hot Rod Enthusiast
s10kid17's Avatar
After you let it dry tonight, tighten it a little bit more tomorrow and you should be fine.
Mike.
s10kid17 is offline
post #12 of 15 Old 11-23-2011, 01:31 PM
Boozebag
Mad Max's Avatar
User is: Mad Max is offline
If you get a premium Felpro cork gasket, it has steel inserts in each bolt hole. This prevents over tightening and will keep the cork just compressed enough to last a while. I use RTV silicone on the VC side and keep the head clean. The gasket lifts off easily when replacing, you only have to dick with the VC side.
The main reason for premature gasket failure is overtightening.
S10 addiction:
1)'82 S10, 383, 700R4, Shorty
2) '85 S10, 3.4, 700R4 4x4 stretch cab (Redneck) 3) '90 S10 2.5, 5 speed shorty
6) '83 S10, 327, TH 350, shorty (13.00 best) Sold
7) '92 S10, 2.5 5 speed, Shorty
8) 1979 LUV, Buick 3.8 V6, TH 350 Shorty.
Mad Max is offline
post #13 of 15 Old 11-23-2011, 03:00 PM
Trans_AM's Avatar
User is: Trans_AM is offline
on older volkswagen motors they..
Use a cork gasket
only sealant the valve cover side
and put wheel bearing grease on the head side. Because VW's needed valve adjustment everyoil change be able to take it off then add more wheel bearing grease.. change the gasket every other three oil changes on them too
Trans_AM is offline
post #14 of 15 Old 11-23-2011, 04:32 PM Thread Starter
Jonathanr's Avatar
Well I started the truck and drove it for 5 minuets and no oil leaks yet so I am thinking it is good.
post #15 of 15 Old 11-25-2011, 12:16 PM
1986 s10 2wd 2.5 iron duk
User is: Laertius is offline
Good info: I just went thorugh the same thing on my truck, cork-- no luck, RTV ONLY: no luck (this one was more my fault though-- could see an uneven bead when removed), then my most recent and successfull method:
1) clean both surfaces
2) thin bead of rtv on vc side
3) apply rubber gasket on VC, use clothspins to help it set up,
4) one hour later light grease on rubber gasket
5) tighten to spec on head
No leaks 200miles later
Thanks
Laertius is offline
