88 2.5 problems
I have an 88 S10 with the 2.5 motor. Has always been hard to start (Takes a lot of cranking to get it to fire up), but a few weeks ago it got to where it is darn near impossible to keep idling. Checked EGR and PCV, both good. When you can get it driving, the engine surges at times. Hooked up a vacuum gauge, and it shows a stead needle. Will be checking codes this morning to see if anything is stored. Am thinking maybe fuel pump???
Any and all suggestions are greatly appreciated. |
Wire Splicin Fool :-)
Re: 88 2.5 problems
EGR valve on these are NOTORIOUS. Hard starting could be a bad fuel pump relay, or like you thought a pump. Would check the fuel spray myself.
Location: Currently Camp Lejeune, but I am originally from Illinois User is: OffLine |
Re: 88 2.5 problems
Re: 88 2.5 problems
Re: 88 2.5 problems
Everybody has those moments. I'm just one of those people who points them out and humiliates the one who said it to the point of contemplating suicide. lol
Re: 88 2.5 problems
I CAN NOT SELF TERMINATE..... ha
Re: 88 2.5 problems
How did you check the EGR valve??? Are you SURE you can eliminate it already??? Ive read a few posts and this sucker is a ROYAL P-O-S!
It really messes with a lot of 2.5's... ones that run GREAT when you take the EGR solenoid plug off and run it like that aside from the ping... Like Mine! ![]() |
Re: 88 2.5 problems
You could also burn a hole in a piston if you arent careful (getting a new PROM, or running it a little rich), my 89 had that happen the port on the EGR was plugged up.....
Re: 88 2.5 problems
Shit. I need to really look into this mess then. When I hear my engine doing some heavy pinging while pulling a long 55MPH hill in 5th gear, I usually just lay into the gas a bit more and the ping goes away. I religiously use premium fuel to help compensate for the EGR being gone, but it still does ping sometimes. Maybe that pinging is the valve burning off! I need to look into the Sinister PROM chip..... |
Re: 88 2.5 problems
Pinging is early detonation and not good, might try to seafoam the intake you may have some carbon that is causing some of the pinging....
Re: 88 2.5 problems
Re: 88 2.5 problems
There is also a different part # for a Manual Transmission and Automatic Valve, I would suspect they are different also (may be the difference in spring tension people worry about too!)
Re: 88 2.5 problems
Hooked up a fuel pressure tester last night, and was barely able to get 2 psi. Trying a new filter tonight, if that doesn't improve things I am going to remove the pump and check the screen in the tank to see if it is plugged.
Re: 88 2.5 problems
Also check the rubber hose connecting the pump to the steel line as it gets soft and can crack, also could just be a bad pump. Check for 12v at pump, check the grounds on the frame.
Re: 88 2.5 problems
It was the fuel pump. Put in a new pump and it is running great now. Ironically enough, a few days later was driving my 88 K1500, and it died and left me stranded. Turned out to be the fuel pump as well. I am getting pretty good at replacing fuel pumps...
Re: 88 2.5 problems
Yeah, you learn real fast on those things!!!! :-)
Re: 88 2.5 problems
88s10owner ,
I once killed 3 pumps in a month 93 pontiac Bonneville ate the sending unit ( might as well do the pump too ) 2 weeks later wifes Grand Marquis didn't start ( yup another one ) week after that my 87 S-10 croaked ( yup pump , but it had 200k 0n it ) I really question the quality of the gas we bought that month The real beef was i drove a semi OTR and didn't have time to do the work myself , shop charged me bout 1200 bucks that month certainly pays to do it yourself |
Re: 88 2.5 problems
`what would cuase my 2.5 to run at a really high idle till i go down the road and it goed to normal, but if i shut it off and restart it doed the same thing also the first start of the day it takes forever to start
hack is wack
Re: 88 2.5 problems
you gotta learn how to spell bro or people are gonna give you a lotta shit on here. . .Oh and another piece of advice mods get mad when you make a thread about something then go into other threads asking the same question. . Its called 'whoring' people get bitchy about these things. but glad to see you actually using this site its great for s-series owners!!God plastic and adhesives class is boring. ![]() |
Re: 88 2.5 problems
Re: 88 2.5 problems
lester1: you mentioned in your post on 8-16-09 about checking your spray pattern. How do you do that? My 88 S-10 has the exact same problem as 88s10owner's post#1. When my engine was running, (currently won't start), looking into the TBI I only saw gas swirling on the inside walls of the TBI, and drops of gas. Should you be able to see an actual spray pattern? Injector possibly partially plugged? Any help?
whore turned lurker
Re: 88 2.5 problems
it should spray out a fan like mist of fuel onto the throttle blade
Re: 88 2.5 problems
It looks like it's just dumping in from the injector. Could this explain the hard starting? Like it's flooding out?
#24 |
Re: 88 2.5 problems
Yes, use a timing light aimed at the spray pattern should be conical in shape and fine mist, no drops should be detected, check the rubber gaskets on the injector as they can rot and cause drippage, also check fuel pressure.
