2.5L Evap Canister ?
Old 11-04-2009, 03:17 PM   #1
S-Dimin 1385
I had a problem with my evap canister on a 85' s10 2.5L. The thing was soaked with liquid gas. I checked the vacuum lines goin to the canister both have good vacuum and were dry. I disconnected the vent tube that runs to the canister from the gas tank and let the engine run no gas was coming out of it. I dont know how it filled up with gas. Myquestion is can you just plug the vent line coming from the tank, I know this would raise the pressure in the tank especially with a return fuel system, or is there any other way to eliminate the canister completely? Has anyone else ever had this problem occur?
Old 11-04-2009, 06:51 PM   #2
CatDaddy52's Avatar
Re: 2.5L Evap Canister ?
Sounds like the purge system isn't working.....
Don't think you would want to plug the vent line...the tank needs to "breathe" or you will create a vacuum.
Old 11-04-2009, 10:58 PM   #3
Wire Splicin Fool :-)
lesterl's Avatar
x2^
Old 11-04-2009, 11:25 PM   #4
S-Dimin 1385
thanks for the input im going to check the purge solenoid on top of the canister is that only controlled by vacuum? since its not computer controlled
Page generated in 0.56780 seconds with 31 queries
[Output: 49.82 Kb. compressed to 47.50 Kb. by saving 2.32 Kb. (4.65%)]
