1988 GMC S-15 2.5 won't start..
Old 11-14-2008, 01:46 PM   #1
8ty8 LS1 is on a distinguished road
just got back from a trip to the mall, parked the truck outside for a few hours...go to leave again, and it will turn over, but no fire. check for spark and fuel, as far as i can see i have neither. can this be a pick up coil problem? i'm just kind of lost here...
Old 11-14-2008, 09:03 PM   #2
tashirosgt is on a distinguished road
Re: 1988 GMC S-15 2.5 won't start..
Check that your camshaft is turning. Take the cap off the distributor and see that the rotor turns while someone cranks the engine. A stripped timing gear would explain lack of both spark and fuel. The rotor wouldn't turn. I don't know how the computer knows not to supply fuel when the camshaft isn't turning, but on the S-10 1987 Sonoma that I've dealt with, it is that smart.
Old 11-15-2008, 10:56 PM   #3
blackspawn67's Avatar
blackspawn67 is on a distinguished road
Fuel relay, fuel pump
Old 11-16-2008, 10:57 AM   #4
Wire Splicin Fool :-)
lesterl's Avatar
lesterl is on a distinguished road
Relay would only cause delayed starts untill the Oil Pressure came above 4 psi, then the oil pressure sender would engage pump.
Does the pump make a priming squeel from the area of the gas cap (take gas cap off)?
If it is not sparking and rotor is turning, could be pick up coil or ignition module or ECM as all could have something to do with fuel delivery as well (injector firing).
Have you checked your fuses?
Old 11-18-2008, 11:59 PM   #5
Shred The Shit
Freek's Avatar
Freek is on a distinguished road
I doubt it's coil. A lot of people are having these problems.
We had the exact same problem, ignition control module and fuel pump fixed it. Spent about $100 and did the work ourselves, easy fix.
Old 11-19-2008, 12:17 AM   #6
lesterl's Avatar
If rotor in dizzy isnt turning you may have lost the timing gears, common issue with the fiber gearset in the engines.
Old 11-25-2008, 03:26 AM   #7
bobadkins is on a distinguished road
It was the fuel pump when my s10 acted this way, but, I have heard of the fiber cam gear loosing teeth and you won't start until you replace the gear.
I pulled the bed and replaced the pump with some OEM pump from Advance Auto. It lasted 100 miles and failed. The intake hole in the pump was MUCH smaller than than the original. So, I got a new Delphi pump from another store (one dollar CHEAPER) and have never had another problem. Stick with Delco and Delphi unless you are looking for performance parts. The Chinese parts just do not work as well.
Old 01-03-2009, 04:49 PM   #8
chevybaby863 is on a distinguished road
i have an 86' s10 5spd manual 4x4 i seem to be having a similar problem with the noe fuel delivery. as for the other par to of the problem i do have fire, but no fuel. i have yet to test the fuel pump and i believe the ignition control module is new, and still no fire. any suggestions?
Old 01-04-2009, 01:02 AM   #9
lesterl's Avatar
Check the coil, check for 12v on coil. Have ICM pulled and tested at a parts store. Next time, start a new thread, keeps the old ones cleaner. :-)
Old 01-04-2009, 04:36 PM   #10
is that fender straight??
dimerunner88's Avatar
dimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud ofdimerunner88 has much to be proud of
chevybaby, so you have fuel or not? your post was kind of confusing
Page generated in 0.13075 seconds with 11 queries
