not low enuf
Who has swapped one into a 98+
I threw a rod in my 2000 2.2 and am about to start to swap in a carbed 400 with a th400. I have been looking around and no one has gone into detail on how they rewired everything. I have an hei dis that I am putting in it and just the important gauges now and will be doing the rest when more money comes along. What is the best way to do it? What can I keep and what do I have to pull? Wire wise that is.
Ehhh!
Re: Who has swapped one into a 98+
Is it your daily driver? For an illinois vehicle that needs to have emissions testing, you will need an engine of same year or newer I believe. Or at least be able to meet emission standards of your vehicle. Which would rule out the carbed engine. If I remembered correctly. I tossed my cpu and all wiring that was associated with it when I went carb on my 88. What exactly are you having issues with understanding? Is engine already pulled?
not low enuf
I am in normal il we don't have testing here. Most of what I have read I will have to rewire the truck. Will the lights and non engine stuff work when I pull the ecu? And yes it will b my dd
Ehhh!
If I were you, I would find a wiring diagram and take your time cutting into it. We did it after I got engine in the bay and plugged in what we needed first, then started the clean up of wiring. You will not have issues with lights unless you some how cut the wrong wires. Worse come to worse you can reconnect them. lol. I would probably pull the plug from cpu and pull it out back into engine compartment and look into the routing from there. Someone else with more experience with it may be able to give you more or better info on how to. Just what I did.
not low enuf
Ok thanks man. The motor will prob go in and out a few times. That's the route I was going to go just wasn't sure if it was the right on or not. What about heater controls? Those with the bcm too?
ROLL TIDE!!!!!!
i have a 95 that had the 2.2 it should be the same as far as wiring goes
i just cut everything in the engine bay basically except the wires for my headlights. there is no need for an ecu. if you have power doors and windows im sure you will have to keep your bcm cuz thats what controls your factory interior functions. although im not sure where that is located as i didnt have the power options. so the only wires you will have to keep in your engine bay is the wires for your headlights and one wire that has power when you turn the key to the on position and when you try to crank the motor. oh and you will need to keep the wires going to your starter relay also. (thats where i messed up now i have to rewire the relay) all that will come from the harness on your driver side im pretty sure the starter relay wires will too but im not 100% on that. hope this helps you out a lil |
not low enuf
Yea it does thanks man. I am waiting on the insurance guy to look at it and when that's all done I am going to be pulling the 2.2 out and getting it ready for the 400. How much of the firewall did you have to beat in? I have the jtr book but that's mostly 1st gen stuff
ROLL TIDE!!!!!!
none at all for the motor or trans only a lil bit to clear the passenger side header, but that is with my mounts as far forward as possible. if you want your motor to sit further back you will have to do something with your firewall.
i haven't torn into my wiring on my 99 yet but the other thing to look at is if you are wanting to keep A/C or go back to it at some point those wires are in that loom as well as neutral safty start switch, gauges you'll have to see, I'm goin after market and running new wires for them, i think the sensors ran through the ecm so you might have to find the ecm to gauge wires and connect them... firewall same as above mines clear forward and some beating on the pass side
hope this helps chevy2 |
not low enuf
Yea it's lots of help thanks Guys. This sucks I have to wait on other ppl before I can pull my motor
not low enuf
So insurance came throught today guy came and looked at it then a few hours later I get a call saying they are going to cover it. So I spent the next 4 hours pulling off the front end. All I have to do is drop the drive shaft unhook the fuel lines and the starter and the 2.2 is ready to come out.
Now I just have to wait on the check to start ordering my parts. Then it's time for the fun to begin. Should be done making my motor mounts by then. I am pitting a 400 4bolt with a th400 trans and a quadrajet(for now will put an edlbroc on it if I have enuf cash left over. |
i did a swap in my 97...and the wiring is the most pain in the but thing if ur keeping ac and heat...if not just cut it all out...and no banging on the firewall at all...but i did have to notch frame for fuel pump...i really didnt have to but i didnt want to have to pull motor to change fuel pump if somthing went wrong with it...i just made a little more clearance...what trans u planning on running?
not low enuf
Yea that what I figured. The only thing I am keeping is heat. I am going to run a turbo 400
if wiring is not your thing there is a solution... you can get a painless wiring harness that will plug into your gm steering column an give you a new fuse box with provisions for everything from ac to power options as well as stereo wiring...
since you are adding aftermarket instruments then there is really no need to keep anything... the painless or any other brand wiring harness will give you everything you need from start to finish to rewire your entire truck... it is a little costly depending on which system you use but saves tons of headaches and gives you the ability to add things as money comes... say you want ac in the future... the wires will be there if you opt for them when you buy the system... everything is labeled and the instructions are semi good as to what is needed... |
not low enuf
I would do that but kind of on a budget. Not worried about ac I took it off my 2.2 before it stopped working cause I never used it and wanted more power. I have a buddy that is really good with wiring.
not low enuf
I am about to pit the
motor in but I was thinking can I use the stock cluster and use the 2.2 sensors even if I pull the ecu? Or am I better off just putting aftermarket in? Would like to just run the stock one if possible. |
I have a 01 s10 and im putting a carb. 350 in it. what mounts and headers did you use? |
Theres literally no way to make the stock cluster work with its own electronics. You're basically going to have to get all new gauges and wire those to your existing components. The TH400 has no provision for an electronic speedo, and even if it did it wouldn't be one compatible to be read with your stock cluster. So time to start looking for some Autometer gauges. |
not low enuf
Ok that's what I thought but thought I would dbl check. Thanks. I bought the hedman headers 2.8 frame mounts from jegs. I made the engine mounts but you can buy them if you can't make em. Check summit racing eBay or jegs
Come out and plaaaaaaay!
I have a 95 and left the PCM in and just clipped the wires I know I didn't need....ac stuff and various sensors...and I just tucked the rest so I didn't clip something useful. The ones you need are pink for hot when the key is on(goes to the coil), purple for the starter(hot in crank mode) and I think brown is the exciter wire for the alternator. Then just run a thick gauge wire from the b+ on the battery to the starter. Last edited by Svtzx555 : 11-04-2009 at 02:31 PM. |
not low enuf
Will I have to leave the computer in for everything to work that way?
not low enuf
What did you guys do about the drive shaft and trans crossmember?
I have a stock driveshaft and a cross member out of a 1st gen 4.3.
#24 |
not low enuf
Will the one from my truck work or will I need to put a new yoke on it?
#25 |
not low enuf
I also have the rear drive shaft wout of a 95 4wd blazer will the yoke Crome that work if my tutu won't?
#26 |
not low enuf
Any one? Anything?
