what is the easiest v8 swap - S-10 Forum
post #1 of 22 Old 03-23-2009, 01:07 AM Thread Starter
User is: xtremewhite99 is offline
I am just wondering i own a 99 s10 4.3L and I am just wondering out of the v8's what is the easiest swap and how much do they usally cost.
post #2 of 22 Old 03-23-2009, 01:45 AM
Banned
User is: 4x4zr2GA is offline
Send a message via AIM to 4x4zr2GA
Re: what is the easiest v8 swap
if you want to keep it fuel injected, the easiest swap is to find a 96'-04' vortec 5.0L or 5.7L complete engine. you can use your v6 wiring harness and computer, all your sensors will plug up the same, and your front accessories from your 4.3 will bolt right up to the front of the vortec v8, also the transmission will bolt right up too... you will have to buy the swap motor mounts, you will have to recess/move the radiator (use a corvette radiator) and A/C condensor foreward and run some electric fans. you will also have to either use the v8 wiring harness, or just cut the injector part of the v8 wiring harness and splice it into your v6 harness, and then have your computer reflashed for a v8. if your going to do it yourself, good, you will save tons on labor cost. you can usually pick up a good running vortec 305/350 for under $650. its hard to say how much you will spend, becuase it all depends on how crazy you get, and what you pay for things. anywhere from free to about 3k is a normall price range. i had a chance to pick up a vortec 350 with 94,xxx miles on it for $400, had a buddy who already had motor mounts that he was going to use, but didnt... coulda got those free, he also had a wrecked '94 z28 camaro i could have gotten the radiator out of for free (i did use the electric fans from it though, there on my truck now), all i would have had to find was the complete engine harness, or just the injector part and i woulda probly had a little over $1,000 once the swap was pretty much complete.
4x4zr2GA is offline
post #3 of 22 Old 03-23-2009, 01:58 AM Thread Starter
ok what about the 5.3L is that a harder swap.
post #4 of 22 Old 03-23-2009, 07:49 PM Thread Starter
ok sorry I am pretty new to this engine swap stuff, I am just wondering if anyone can tell me what are the 5.0L engines found in and also what are the 5.7L engines found in and also is that 5.7L the same as the ls1 motor.
Thank you:
Mark
post #5 of 22 Old 03-23-2009, 08:15 PM
No longer a pizza tech.
90blueS10's Avatar
User is: 90blueS10 is offline
Thank you:
Mark
5.0s and 5.7s were found in the fullsizes, silverados, sierras, conversion vans, yukons, suburbans, tahoes. etc.
the ls1 is an all aluminum 5.7 found in corvettes? and camaros, ws6 firebird, etc. going to run alot more than a cast 5.7
Ryan
90 2.5 5 speed, bag project
01 Jimmy 2dr 2wd daily driver
post #6 of 22 Old 03-23-2009, 11:22 PM Thread Starter
ok does anyone know what is the hp on those 5.0L and the 5.7L and how long to these take to install on say my 99 s10 4.3L.
post #7 of 22 Old 03-24-2009, 12:30 AM
LSx and V8 Mod
SweetS10V8's Avatar
User is: SweetS10V8 is offline
Send a message via AIM to SweetS10V8
HP varies with every engine, Ive driven a 1st gen truck in on Friday night after work and was driving it on Sunday with a V8, I had someone else who was also mechaically inclined helping.
But youll most likely need a lot more time if its your first time.
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
post #8 of 22 Old 03-24-2009, 02:00 AM Thread Starter
ok is there shops that also do these installs, also say what do a late model 5.7 put out for hp
post #9 of 22 Old 03-24-2009, 02:01 AM
Banned
the LS1 5.7L and conventional style 5.7L are two completely different motors. if your worried about cost, just stay away from the LSX series engines and focus on finding a vortec v8 such as the vortec 5.0L and vortec 5.7L.
the vortec 5.0 is 305 cubic inches and put out 220 horsepower, the vortec 5.7 is 350 cubic inches and put out 250 horsepower.
if you decide to go with an older style (non-vortec) 305 or 350... then expect the 305 (stock) to have somewhere around 140-160 horsepower, and expect the 350 (stock, most common configuration) to have about 190 horsepower.
the vortec line of v8's began showing up in the full size trucks/vans/suv's in 1996. they stopped putting them in the trucks/suv's in 1999, but continued putting them in the fullsize vans up untill 2004. in mid year 1999 (new body style trucks/suv's) they started using the LSX series motors.
4x4zr2GA is offline
post #10 of 22 Old 07-30-2010, 11:42 AM
User is: jesussdanner is offline
Did the vortec 5.7s use a throttle body?
post #11 of 22 Old 07-30-2010, 01:47 PM
Heavy Metal Body Man
Maverick2664's Avatar
User is: Maverick2664 is offline
Send a message via AIM to Maverick2664
of course they do, all fuel injected engines use a throttle body
but they are not throttle body injected if thats what youre asking
-Under Construction-
98 S-10 extended cab: stock floor body drop, TPI 383 w/ 0411 pcm conversion, T56 manual
post #12 of 22 Old 07-31-2010, 12:54 AM
Tundra Redneck
shadowmoonwolf's Avatar
User is: shadowmoonwolf is offline
that's what I think i'm going to try and do to my '93 next summer is swap the tired old 4.3 in it for my '84 K10's 350 and turn it into a TBI once I upgrade some of the internals. hoping that makes for an easier swap than trying to harness it up as a vortec. Anyone have much experience with that year putting it in a 4x4 and how hard that would be for a beginner?
post #13 of 22 Old 01-30-2014, 06:46 PM
User is: duane122000 is offline
What about in a 2003 w a 2.2? whats the best way to go?
post #14 of 22 Old 01-30-2014, 08:40 PM
HILROD's Avatar
User is: HILROD is offline
Almost nothing from a 2.2 will work with a V8. The wiring, computer, trans, radiator, and mounts all would need to be changed.
HILROD is offline
post #15 of 22 Old 01-30-2014, 09:47 PM
User is: Seadoorxpguy is offline
The easiest swap is to sell your s10 and get a silverado.
post #16 of 22 Old 01-30-2014, 10:53 PM
Sold :'(
s10xtremist's Avatar
User is: s10xtremist is offline
I forgot all about this xtremewhite99 dude and his every post beginning with "I am just wondering i own a 99 s10 4.3L and I am just wondering..."
Getting better with every failure
Project threads:
Punching bag
Unicorn XJ
post #17 of 22 Old 01-31-2014, 01:42 PM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
There would be no reason to waste time swapping in a 5.0L vortec IMO, with that being said the "easiest" swap in a 96+ 4.3 truck is the Vortec 5.7.
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #18 of 22 Old 02-14-2014, 05:16 PM
Is it best to try and stay in the same year range due to computers and such?
post #19 of 22 Old 02-19-2014, 12:42 AM
robroyoldboy's Avatar
User is: robroyoldboy is offline
Ok, new question: I have a '91 2wd longbed with a 4.3 TBI. I've heard whispers of it being an easy swap to a SBC TBI.. Any ideas as to how easy it really is? I ask mainly because I have a carbureted 305 with the H.O. heads and a one-piece rear main. I also have access to a junkyard for cheap, so I could probably find a TBI manifold. So I guess my question is: what are the differences?
post #20 of 22 Old 02-25-2014, 12:20 PM
Gaaoooooo
MINTSICK's Avatar
Pretty easy swap but again there is zero reason to ever swap to a 305ci v8.
MINTSICK is offline
post #21 of 22 Old 04-21-2015, 11:06 PM
User is: nomad363 is offline
Where do I find parts to raise the front 2", and the back 4" in a 1999 chevy S-10?
nomad363 is offline
post #22 of 22 Old 04-22-2015, 09:02 PM
Passwordistaco
Back_N_Black's Avatar
User is: Back_N_Black is online now
^ epic first post.
