Vortec head #'s... - S-10 Forum
post #1 of 9 Old 07-18-2005, 09:59 PM Thread Starter
Kevs10's Avatar
User is: Kevs10 is offline
Vortec head #'s...
My dad has a chance to get a 2002 vortec short block from a van and also could pick up the heads for a couple hundred more.... Can anyone tell me which heads were the good vortecs vs. the ones that aren't as good - by part number?
I think I heard to stay away from '906 versions as the seats were different and flowed poorly compared to the other versions - and were mainly found on the 2500 series trucks - but I would like some confirmation if this is true and which numbers were considered the 'ones to get'... if anyone has any experience with them!
Thanks --Kevin--
Black 95 s-10 355v8 - 700r4, 99 Grill/light, Goodmark Cowl Hood ,Street Scene Mirrors, Xtreme Rims & lowered 3/3 with some wide tires
Kevs10 is offline
post #2 of 9 Old 07-18-2005, 11:22 PM
ALMOST DONE
lownslow1988's Avatar
User is: lownslow1988 is offline
Send a message via AIM to lownslow1988
Re: Vortec head #'s...
im not sure of which is better but i heard something similar also.....maybe try searching a lil...
88 s10...V8 Swap Weekend warrior
03 Blazer ZR2.....Daily driver
post #3 of 9 Old 07-19-2005, 12:23 AM
LSx and V8 Mod
SweetS10V8's Avatar
User is: SweetS10V8 is offline
Send a message via AIM to SweetS10V8
10239906 and 12558062
Carcraft made a statement that one was better than the other(hence the rumor), but later retracted the statement. They are both excellent heads....
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
post #4 of 9 Old 07-19-2005, 01:06 AM
PPG sprayin' member
downtoearth's Avatar
User is: downtoearth is offline
The 906's are the the ones I have and I was proly right about 400 hp.
-Mitch
post #5 of 9 Old 07-19-2005, 01:34 AM Thread Starter
Kevs10's Avatar
Checked everything I could about the CarCraft site and came away with no answers as to which ones are the better. I do know now that '059 and '093's are apparently small valve heads (1.88 or so) and that the '060's are very good, but I was looking for info on the '062 and '906's to see why they were or weren't different or recommended as I had heard earlier...
There apparently were quite a few variations along with 305 versions, of the Vortecs and I am trying to get as much info to arm myself before commiting to try and buy a pair - to ensure I get ones that are useable without srewing around with them much. As I stated earlier I heard the 906 versions were poorer flowing and didn't work as well as the '060 / '062 versions - due to the bowls and seat areas directly under the valves!!??
Kevs10 is offline
post #6 of 9 Old 07-19-2005, 02:21 AM
PPG sprayin' member
The van wont have the 12558062 those heads were only made in 1998. Both heads are the L31 Vortec's they both have 170cc intake ports, 1.94int and 1.50exh valves, and 64cc combustion chambers. You most likely have the 906's unless it is a Gen III votec, if it is you proly have the 12559895.
-Mitch
post #7 of 9 Old 07-19-2005, 08:14 PM
LSx and V8 Mod
SweetS10V8's Avatar
It was CHP not carcraft, my bad. As long as you get one of those two numbers I gave you, you will be getting the good ones everyone wants....
http://chevyhiperformance.com/howto/97458/
http://www.2quicknovas.com/vortecheads.html
http://www.chevymania.com/tech/vortec.htm
http://www.customclassictrucks.com/t.../0405cct_head/
post #8 of 9 Old 07-20-2005, 12:02 AM Thread Starter
Kevs10's Avatar
I have read lots online lately trying to answer some of my own questions about these vortec heads but I have yet to find out very much regarding the '906 versions that don't crap all over them - verses the '062 versions. I suspect the 5.7 I will get to pull heads off will prove to have the '906 types as some have alluded to, and I feel that they aren't the best types to get based on much of what I have read...
I would like to find out more about statements and/or comments regarding the '906 casting versions that you say apparently had uncomplimentary comments regarding their efficiency, retracted or explained. If you have access to any links that would shed more light on this issue and tell more about the '906's as equals to the others (including the '062's) I would appreciate finding out more, as I can't seem to find much myself... --Kevin--
Kevs10 is offline
post #9 of 9 Old 07-20-2005, 08:09 AM
TrailBlazin'
SuperSS27's Avatar
User is: SuperSS27 is offline
Send a message via AIM to SuperSS27 Send a message via Yahoo to SuperSS27
Those are the heads I have...:-D
Need replacement parking brake cables?
Need Customized parking brake cables for a rear end or brake conversion?
WWW.BRUINBRAKECABLES.COM
