vortec 350 water pump question - S-10 Forum
post #1 of 13 Old 01-05-2012, 09:04 PM Thread Starter
what? to loud? u crazy
bmph8er's Avatar
User is: bmph8er is offline
i tried searching around but wanna double check a few things. what all water pumps will fit a 99 vortec 350? im looking for some without the heater hose outlets. its a gen 1 block so almost all 350 sbc should fit wouldnt they? i wont be running heat or anything like that its a bagged truck building just to beat on so none of thats needed. thanks
{tow pig} 01 GMC Seirra 5.3 xcab
3/5 drop, 2 alts, 2 batts, 4 15s, 12,500 rms amp, 2 rf t1 comp sets, 125 sq ft deadner, billet grill insert, 22s, long tube headers, offroad y pipe, S&B cold air intake, cat back, blackbear race tune.
{daily} 95 civic 4 door lowered american bass 2000 rms, 2 re 12s and memphis highs and pos 4 channel
{project} 92 standard cab short bed. gettin shaved, bagged, v8ed, dragged, beat, and rebuilt
bmph8er is offline
post #2 of 13 Old 01-05-2012, 09:45 PM
RedNoma's Avatar
User is: RedNoma is offline
Re: vortec 350 water pump question
You can run any style pump, but you have to use the corresponding accessories. The vortec is it's own design, neither long or short pump. So if you use the vortec accessories you must use the vortec pump.
Corey
'96 GMC Sonoma '99 Honda VT750 Shadow ACE '09 Roush GT Mustang (#09-002)
Sold: '03 Nissan 350Z '00 Suzuki TL1000R
RedNoma is offline
post #3 of 13 Old 01-05-2012, 09:47 PM Thread Starter
bmph8er's Avatar
na i have a crank pulley and water pump pulley as well as a alt mount from a 70s v8. so i belive i can just use a old style long pump. just wanting to make sure. all im going to be running is crank pulley water pump and alt. no power steering or a/c or nething
bmph8er is offline
post #4 of 13 Old 01-05-2012, 11:27 PM
Call me Mario, Princess
AceHaag's Avatar
User is: AceHaag is offline
This is wrong. You can not use a vortec water pump on an early block because the vortec has an external bypass where the early small block is internal.
Mike
my truck
New direction --->Time to get High
2001 s10 ext cab 6.0 243 heads, ls2 cam, nnbs truck intake, 87mm tb, 4l60e, 241c, dana 44's front and rear, 4.30 gears 35" m/t Baja claws.
AceHaag is offline
post #5 of 13 Old 01-06-2012, 12:10 PM
RedNoma's Avatar
Considering we're talking about a "vortec" block everything that I said is in fact correct. You can use all three style pumps on that block.
Corey
RedNoma is offline
post #6 of 13 Old 01-06-2012, 12:54 PM
benster's Avatar
User is: benster is offline
you need an early style pump cause with a serpentine set-up the water pump is reverse rotation. so with your old style v-belts most aftermarket water pumps or old carbed engine water pumps will fit. if you wanna save some headaches, make sure you get a year that was carbed. i can't recall any chevy v8 that were carbed and had a serpentine set-up.
1983 sonoma GT
355 SBC 300-325HP, th350 2600 stall
8.5" rear, 3.08 and zq8 power steering
85 camaro RS rims, 15"....upgrade!!
"if you like how your truck looks, why care what others think about it?"
benster is offline
post #7 of 13 Old 01-06-2012, 11:42 PM
AceHaag's Avatar
Exclamation Re: vortec 350 water pump question
Go ahead and put an early pump on a vortec block and watch all your coolant piss onto the floor out the bypass hole that doesnt seal on the block.
Mike
my truck
AceHaag is offline
post #8 of 13 Old 01-07-2012, 01:42 PM Thread Starter
bmph8er's Avatar
from what i been told the blocks are the same vortec or not. its the heads that make it a vortec. my gen 1 vortec block is basicly the same block they been using forever. then again thats what summit and jegs told me when i was pricing stuff.
bmph8er is offline
post #9 of 13 Old 01-07-2012, 09:05 PM
2003Xtreme's Avatar
User is: 2003Xtreme is offline
The blocks are initially the same from what I understood the Gen1 vortec blocks.. I have a 96-98 roller block that I used a 90s heads/ waterpump on it with serpentine setup. I am not REAL familiar with this.. but here is a pic of my 96-98 roller vortec block.
99 Hugger Orange Z28
93 Suburban Lowered
91 S10 shortbed Lowered
Project Build Thread Links
http://www.s10forum.com/forum/f135/s...y-pics-483887/
http://www.s10forum.com/forum/f135/f...yard-d-483861/
http://www.s10forum.com/forum/f3/198...t-work-489962/
Originally Posted by J_SIN View Post
I'd rather pump up my bags with a bicycle pump than use their products.
post #10 of 13 Old 01-08-2012, 12:08 PM
Hey guys watch this!!!
ToLows10's Avatar
User is: ToLows10 is offline
You are indeed correct. The only thing you have to worry about is pump rotation which will be decided by if it's a serpentine belt or not.
Not sure if theres a stock serpentine set up that uses a standard rotation pump or not.
My Old Blazer
http://www.s10forum.com/forum/f3/my-...f-pics-466111/
The New S10
http://www.s10forum.com/forum/f30/my...ckhalf-736129/
My back tires are STILL wider then your motor!
ToLows10 is offline
post #11 of 13 Old 01-10-2012, 03:52 AM
"factory freak"...
Crew Cab Sonoma's Avatar
You can tap and plug the bypass hole on early pumps.
But most likely the vortec block is just machined flat
With no hole drilled, so as long as the typical early style
Pump gaskets are used, shouldn't be any leak.
Look at the pic above. The "ear" where the bypass hole
used to be is still there, it's just not drilled for the bypass.
95 S-10 2.2. Soon to be DD
post #12 of 13 Old 01-10-2012, 04:10 AM
"factory freak"...
Some 85-86 engines used a serpentine belt for the WP and alt.,
but still had V-belts for PS and AC.
No automatic tensioner was used, and WP was std. rotation.
post #13 of 13 Old 01-10-2012, 02:32 PM
"factory freak"...
Now that I think about it, many 87 SBC engines
used that setup too.
