vortec 350 timing set ??? - S-10 Forum
post #1 of 7 Old 03-10-2010, 09:51 PM Thread Starter
User is: the_dam_man is offline
can I install a double roller or gear drive on a vortec 350 if I am using the crank/cam sensor in the stock timing cover? is there a performance upgrade for these motors?
post #2 of 7 Old 03-10-2010, 11:48 PM
eric0o1's Avatar
User is: eric0o1 is offline
Send a message via AIM to eric0o1
Re: vortec 350 timing set ???
With my double roller, the reluctor would have made contact with the chain links. I had to space the reluctor out about 1/8" or .125", or the thickness of the reluctor itself. I simply cut the center out of another reluctor, so it would still be keyed on the crank. About 2.5" over all diameter. I installed the "spacer", then the reluctor the crank sensor actually reads. I am still in the process of getting everything together so I have not run it yet, however there appears to be no harm in how the sensor will read.
You can't use a gear drive because of the noise interference with the knock sensor.
02 Blazer (2wd), supercharged 383 in the works http://www.s10forum.com/forum/f10/20...3-swap-456167/
eric0o1 is offline
post #3 of 7 Old 03-11-2010, 10:24 PM Thread Starter
what if I disable the knock sensor with my tuner?
post #4 of 7 Old 03-12-2010, 10:51 AM
eric0o1's Avatar
If it were me I wouldn't. I would rather run a factory timing chain as opposed to disabling the knock.
Also, I have heard it is not suggested to run a gear drive with a roller camshaft. I have no idea the reasoning behind it, but it could lead back to roller camshafts being more commonly found in EFI applications where a knock sensor is present. Again this is something I'm only heard second hand and have never had experience with. I've never looked any further into it because I personally hate gear drives because most guys simply install them for the "blower" whine.
eric0o1 is offline
post #5 of 7 Old 03-12-2010, 01:44 PM
DIRTRIDER56's Avatar
User is: DIRTRIDER56 is offline
ya i wouldnt go without the knock either... youd be taking a chance on ruining that vortec 350. i dont know why you want a gear set up inless you want that blown whine... to much work to make a little noise for me lol... go for the real deal!
2000 Xtreme s10... 350 HO crate
post #6 of 7 Old 03-12-2010, 05:24 PM Thread Starter
I was simply posting the question. I recalled reading somewhere where there was a hi-po chain for the LT motors that worked on the vortecs (some GM part)
post #7 of 7 Old 03-12-2010, 09:23 PM
eric0o1's Avatar
I believe it is the LT4 timing chain
eric0o1 is offline
