V8 swap.....with carb need fuel pump advice - S-10 Forum
post #1 of 14 Old 11-27-2009, 11:36 PM Thread Starter
User is: revmoe is offline
My S-10 blazer has already had a V8 swap done to it...It has a Edlebrock carb on the it. My question is...I am very tired of having to pump the pedal because there is no fuel pump hooked up to it. Can i use the intake fuel pump that is already installed to supply fuel to my carb. if soo i know I will need a regulator...is that all that is needed? or can it even be done.
revmoe is offline
post #2 of 14 Old 11-27-2009, 11:42 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Re: V8 swap.....with carb need fuel pump advice
If your using a stock setup you need a return regulater. But yes you can.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #3 of 14 Old 11-27-2009, 11:54 PM Thread Starter
return regulator the same as a fuel psi regulator...? And when you say stock? are you talking about the engine...because it is in stock condition...right now.
revmoe is offline
post #4 of 14 Old 11-28-2009, 12:06 AM
jtcfanof3's Avatar
When I say stock I meen stock fuel setup.
http://www.jegs.com/i/Holley/510/12-...oductId=761151
With a carb you will need to bleed off that excess fuel the pump is going to want to feed it because it still thinks a TBI is installed.
Return style/bypass style same thing just for clarification.
I like my old school mechanical fuel pump......guess its a prefrence thing. I dont have to pump it unless it has sat for awhile, like a week.
post #5 of 14 Old 11-28-2009, 12:10 AM Thread Starter
return regulator is the same as a fuel psi regulator...? And yes the fuel setup is the same...the pump is just not connected...cuz the ECM and all is disconnected..So how do I make this work correct.
revmoe is offline
post #6 of 14 Old 11-29-2009, 10:57 AM
Ehhh!
towb3's Avatar
User is: towb3 is offline
Yeah, for the most part. The regulator will have a fuel inlet, regulated outlet, and a return line to the tank to bleed off excess fuel that was regulated down. I, like jtc, am going to ditch my electric inline and use a mechanical. I have had nothing but issues with my electric pumps. With a mechanical it is a lot easier to trouble shoot. I guess its just my opinion since my truck has been down twice in the short time its been together due to bad electric pumps.
towb3 is offline
post #7 of 14 Old 11-29-2009, 11:21 AM
takes 2 balls in our game
s10-den's Avatar
User is: s10-den is offline
if you can, just put a block mounted pump on it and be done
s10-den is offline
post #8 of 14 Old 11-30-2009, 01:02 AM Thread Starter
Yeah I might just do that...I have to replace the fuel tank, and I figured why not ask anyway....Well I was going to get the
1721 - Edelbrock Performer RPM Fuel Pump
1727 - Edelbrock Fuel Pressure Regulator
but I didn't if it would work for my application.
revmoe is offline
post #9 of 14 Old 11-30-2009, 11:27 AM Thread Starter
My biggest thing is i plan on putting a remote start on the truck, and right now...she has trouble starting in the cold..I will have to pump the gas several times before she will start up. So will those edlebrock products work for me, and will it help for the starter application?
revmoe is offline
post #10 of 14 Old 11-30-2009, 06:09 PM
Ehhh!
towb3's Avatar
Remote start on a carbed engine almost sounds pointless to me. When it gets good and cold you are almost required to walk out and start it. Unless it is kept somewhere warm. I guess. If not, I would like to see that kit. Something that controls an electric choke I guess? If not, it would be pointless to walk out and pump the gas, walk back in and hit the key fob. IMO.
THe pump should work. I haven't personally used one so I couldn't tell you from experience. It says it doesn't require a regulator, but I would run one anyways. I'm sure you already know, but you will need to also order push rod for the pump and the mounting plate. unless you already have them.
towb3 is offline
post #11 of 14 Old 11-30-2009, 11:03 PM Thread Starter
Well this is why i thought about the electric fuel pump... I have figured out that all one would have to do for remote start is have a power solenoid that would pull a cable connected to your choke, and then start the car. you can put the solenoid on your aux channel. this is what the ppl use on their older carbed cars.
revmoe is offline
post #12 of 14 Old 12-01-2009, 12:25 AM
Ehhh!
towb3's Avatar
I wouldn't mind that this winter. My Florida blood isn't liking this cold weather, and not looking for winter. I haven't used a mechanical yet, JTC tends to have given pretty good info in past threads on stuff I have searched for. A lot of the hotrod guys I run around with stand behind their mechanicals. The only reason Iwent to the electric against MOST of their advice is 1.) I am hard headed 2) I have heard of guys in the past having issues at the track with fuel cutoff from older mechanical units. Again, my choice is to go back to the mechanical, I don't think that will be an issue with remote start. I am going to check out the remote start and choke issue.
towb3 is offline
post #13 of 14 Old 12-01-2009, 12:38 AM
Ehhh!
towb3's Avatar
It looks like people are using a trunk popper/solenoid for what you are talking about. I don't know why I didn't ever think about that.
towb3 is offline
post #14 of 14 Old 12-01-2009, 12:55 AM Thread Starter
yep that is right....The only reason why I am talking about going with the electric fuel pump is because it is already installed in my tank....All I need to do is regulate it..., I believe all I need to do is hook it up to my 12V, so when the car is on the pump is running...I wouldn't not my using a mechanical pump, but it robs power...even though it's very very small...to drive...I plan on getting an electric water pump, either belt driven, or regular, and electric fans...I am slowly rebuilding this junker so that she can be a bad truck...
revmoe is offline
