v8 swap noob
Old 09-30-2009, 02:15 PM   #1
Bouche's Avatar
v8 swap noob
hey guys im pretty new to the v8 idea. iv been thinkin about it. i have a 87 s10blz with the 2.8. i just am curious as to what can be re used and what has to be replaced if i swapped in a 350. and is there somewhere that sells specialty motor mounts for this? thanks
Old 09-30-2009, 02:27 PM   #2
Bouche's Avatar
Re: v8 swap noob
or since im not really after power would it be easier to do a new vortec 4.3 as far as fitment wiring and reusing my existing parts go? id rather take the cleaner, easier way
Old 09-30-2009, 02:37 PM   #3
Myself's Avatar
Re: v8 swap noob
Whether you go 4.3 or V8 you cannot reuse anything from your motor or trans.
Old 09-30-2009, 07:44 PM   #4
Heavy Metal Body Man
Maverick2664's Avatar
Re: v8 swap noob
like Myself said above, its about a horse a piece, coming from the 2.8, theres nothing you can reuse for the 4.3 or the 350
and yes theres a few companies that sell mounts for s10 v8 swaps, mine came from Trans Dapt
Old 10-04-2009, 04:40 PM   #5
I/W LSx swap 4 racetruck
Scrap's Avatar
Re: v8 swap noob
Not to lead you elsewhere but check out this book> http://www.summitracing.com/parts/JTR-S10/#
It helped out a little, I really couldn't use everything to build my truck. The manual outlines buiding street trucks with full accesories and stuff, but had a lot of good tips for what vehicles/ companies to source certain parts from to make the swap easier. Every section is covered, ( i.e. cooling, mounts etc. Gl!
-SS
Old 10-04-2009, 08:17 PM   #6
Bouche's Avatar
Re: v8 swap noob
well i guess i could run a carb instead of fuel injection. that will save a little electrical hastle. are there any other websites that specilize in the swap?
Old 10-06-2009, 10:14 PM   #7
Re: v8 swap noob
uh yeah... this one
Old 10-07-2009, 02:14 AM   #8
EAT ME
88 s10 Blazer's Avatar
Re: v8 swap noob
I got my mounts on ebay for about $50, The only thing I reused from the 2.8 was my drive shaft.
Old 10-07-2009, 03:33 PM   #9
Bouche's Avatar
Re: v8 swap noob
ok i got some more questions. i have found a 5.3 long block for 500 bucks to thats pretty much a go. so to use the fuel injection what do i have to do as far as computers go?
Old 10-07-2009, 04:33 PM   #10
Bouche's Avatar
Re: v8 swap noob
and also i just thought of the airflow sensors. what do with that stuff? and what manual trans will fit to that motor? may be a dumb question but hey im new at this can i use my existing stock 5spd trans behind my 2.8?
Old 10-07-2009, 10:39 PM   #11
Re: v8 swap noob
to get that 5.3 to work, you need to find the correct ECM and wire harness for it obviously... OEM or aftermarket, it has to be for a 5.3... if you get an OEM one, you may have to send it out to have it reprogrammed, sometimes theyre individual engine specific and will "lock" themselves if swapped... or something like that, it was something similar to that with mixing and matching the old TPI/LT1 ECM's and PROM, if you used a 89+ chip, you had to have the VATS disabled or you wouldnt be able to start it.. or something like that, i dont know much about it
what do you mean "airflow sensors"?
if you want a manual trans, youll be best off with a T-56 or aftermarket equivilent, i'm 95% sure that all the LS engines and the Vortech's share the same bellhousing pattern, so you wont need an adapter plate or anything
and no, your 5 speed will not fit the 5.3.... even if it did, would you use it? think about it, would you trust a tranny that was never designed to be put behind a v8?
Old 10-07-2009, 11:37 PM   #12
Bouche's Avatar
Re: v8 swap noob
ok whts involved with the computer swap. and with the new harness wont there be things i dont need? what do i do with the extra wires
Old 10-08-2009, 12:23 AM   #13
Re: v8 swap noob
you will use most everything on the harness, or at least, you should be... engine harness is seperate from the body harness, as well as the computers, ECMs control engine function, and PCM's control body/chassis stuff... the only thing you have the option to not use would be something like the AC and whatnot
if your using a factory harness and end up with plugs and wires that you cant use, then just remove them from the harness, its not that hard all you do is fish out the wire and once you trace it back to the connection block, tear it down and remove that wire, theres usually a clip or pin thing that holds the end of the wire in place, youll need to use a little screwdriver and push it aside to pull the wire end out... or if your lazy just snip, tape up, and stuff the wire back into the harness casing
as far as computer swaps, i dont have a clue, do some research, i dont know anything about the Gen III/IV engines... although theres a lot of guys around here that do
Old 10-11-2009, 12:36 AM   #14
Bouche's Avatar
Re: v8 swap noob
so i just swap my ecm? and theres is an ENGINE harness? thats seperate from all the rest of my factory wiring? do i just plug in the new ecm or do i have to make a new circuit or what?
Old 10-11-2009, 01:01 AM   #15
Bouche's Avatar
Re: v8 swap noob
or is it easier to run something with a carb? basically whats the easiest way
Old 10-11-2009, 03:03 PM   #16
Re: v8 swap noob
it sounds to me like you have no idea what to do or how F.I. works, and youd probably be way over your head if you tried one
go with a carb, thats by far the easiest way, all you need is basically a fuel line
Old 10-11-2009, 03:06 PM   #17
Duct tape hides rust!
Re: v8 swap noob
You have to swap the engine/ecu harness/ecu from the vehicle that the 5.3 came out of. Your stock engine harness is of no use to you. Just go carb'd, much easier. With a carb'd setup you have your ignition wire to the starter (purple), positive cable from battery to starter (red), ground from battery to block (black), alternator wiring (go with a gm 1 wire).
Other than that either use a electric fuel pump with a regulator, or a mechanical on the block. Either way your going to need to buy swap headers/mounts, possibly fab a trans mount, and maybe get the driveshaft shortened or lengthened.
Its really very simple, just takes common sense like anything else. Good luck, and dont forget to post a project thread when you start.
Old 10-11-2009, 10:54 PM   #18
Revolt's Avatar
Re: v8 swap noob
The only thing I've used from the 2.8s I've converted to 5.0/5.7 TBI's is the ECM harness if its 88 or later. Has to be modified a great deal and most cases re-pinned.
87 2.8 to newer style vortec would require all new.
Old 10-12-2009, 04:01 PM   #19
Bouche's Avatar
Re: v8 swap noob
thanks guys. carbed it shall be i suppose
