V8 in 98, how do i pass smog in Ca
so ive always wanted to put a V8 in my truck but how do i get away with it, I live in ca and i was told but the smog testing guy that it wouldnt pass if it has a V8.
Thanks for any help and info. |
Re: V8 in 98, how do i pass smog in Ca
1.Research what your specific rules are and follow them.
2. Move. |
is a fungineer
There are several threads on this forum about the exact same topic, basically you have to put an engine that is the year of your truck or newer (so for you, 98 and up), and it has to pass emissions. You have to get it visually inspected at the DMV and they give you a sticker to put in your doorjamb. |
*INDEPENDENT*
yea just pay the smog guy off
Build them right....Mod
Just have to know the rules and abide by every detail.
Here's an excerpt from this engine swap manual: http://www.jagsthatrun.com/Pages/Che..._V-8_Smog.html |
Just because someone works at a smog place, it doesn't mean he knows everything about the smog laws. And a lot of smog place just don't even want to deal if any vehicle that isn't stock. |
Do a 98+ up motor, transmission, and fuel injected with cats and I am sure you will pass. Normally from what I have read is that your motor must be from the same year as your vehicle and you should have no problems. Or just move out of cali. lol
yea i had heard about the same year or newer thing, so your saying if i swap a V8 in and go to the smog check i won't pass? I would have to first go to the dmv and it has to be inspected?
Road Racing Blazer
but it wont pass visual inspection. once they type in your info it will say v6 and they will fail instantly. only way pass is to pay them off or title/vin swap.
stupid regular cab!!
why not with just a same yr or newer fuel injected motor computer and cats...why wouldn't that pass? as long as he has all the bs a silverado v8 would have why would it make a difference if its in an s10 or not..?
It is very easy to do an engine swap in California! It's done all of the time. |
is a fungineer
I think he means just installing a V8 and then going on about your business like nothing ever happened - of course smog would fail you on visual. If you go the legal route and have it inspected, you'd be fine. |
I thought for a light duty truck the engine has to be from a light duty truck or passenger car. I didnt think you could do an engine from a ful size and pass?
Okay. It was more of a question. I had heard that you couldnt use one out of a van or fullsize. I didnt know.
registered to your mom
I'm not sure how yall do emissions there, but here in MD, we get all kinds of stuff in that isn't stock. I tested a mustang that originally had the v6, but he told me he put a modular motor in it. Our computer program allows us to change certain features of the car (ie a scroll tab that can list if it has the 3.8 or 4.6) But we don't really care. It's the inspection that will fail you. Also, obd2 we just scan the computer. If the vin doesn't match or has codes, it obviously fails.
Many of us inspectors used to pass cars like that all day. But since then, they hanged the computer software, so passing obd2 is out of the question. |
is there a wiring harness that will allow us to still us our OBDII port?
so is there anyone out there that has done this in Ca that has any input on this?????
Move to Oklahoma. No smog laws. Lots of freedom. I can run a blown and injected 1971 big block in my s10 if I want to. No helmet laws for Motorcycles, either. We may not have the prettiest state, but we have the most freedom.
crap
You have to follow the BAR SMOG rules for engine swaps. If I
remember right, you have to have an engine that was offered for that year AND model. Say you have a 92 Sonnma with a 4.3 Z TBI. You could possibly install a 5.7 with TBI since the emissions are almost identical with that of the 4.3. The 5.7 would have to be a Ca emissions engine, all smog equip for the 5.7 would have to installed as well as the ECM and the Check Engine light would have to functional. Deal is, GM never offered a 5.7 for a S Series truck, so even if you get it all swapped over, you may STILL not be able to tag it. You would have to go to a state Ref test center in any event for the testing. If it somehow passed, you would get issued a BAR door label with all the emissions equip req and smog techs would have to go by that. But the way smog is getting out here in Ca, you would most likely be going to a state ref for testing all the time..Here's some info from BAR. a swap with a 5.7 legally. (866) 272-9642 Last edited by bg's : 07-05-2009 at 04:34 AM. |
