Throttle Cable Too Long!!!!!!!!! - S-10 Forum
post #1 of 11 Old 07-02-2004, 09:05 PM Thread Starter
User is: njdad61 is offline
Exclamation Throttle Cable Too Long!!!!!!!!!
I've just dropped a 305 into my '82 S10 that originally had a 2.8 V6. Besides beating the living crap out of the firewall for some clearance and using a floor ratchet shifter instead of the column, everything stock has worked perfectly. Until now........ I bought a throttle cable bracket and went to attach the cable to the carb, and it's wayyyyyy too long. I can't remember exactly, but I'd guess the throttle was on the passenger side of the old carb, and I only have to go straight forward on the driver's side. Is there a certain cable I can buy somewhere, or can the factory one be cut???? Thanks for the help.
njdad61 is offline
post #2 of 11 Old 07-02-2004, 09:47 PM
LT1 Powered
Navecm's Avatar
User is: Navecm is offline
Send a message via AIM to Navecm
Re: Throttle Cable Too Long!!!!!!!!!
i currently have a cut one, looks awful like its going to break, but has held up for a few months, i will eventually replace it.
www.lokar.com carries throttle cables
94 S10 Blazer 2DR - LT1/4L60E|3.42s|3716lbs
94 S10 Reg Cab/Longbed - LB4/NV3500|2.73s
Navecm is offline
post #3 of 11 Old 07-04-2004, 12:40 AM
Race Cop
S10Fan's Avatar
User is: S10Fan is offline
I used one from a early 90's Caprice but I still had to shorten it a little.
’87 Long Bed, 350 V-8, TH-350 A/T, p/s, p/b, p/w, p/dl
Lowered 5/5, Full Tweed Interior, custom door panels, dash, and center console. Coilover rear suspension. Viper red.
S10Fan is offline
post #4 of 11 Old 07-04-2004, 12:45 AM
sdime90v8's Avatar
User is: sdime90v8 is offline
go to auto zone i dont know if thay still do it but a buddy of mine had them order hime one he told them how long he needed it to be and payed for it and they got it in like 2 days later
post #5 of 11 Old 07-05-2004, 12:27 AM
SIC-Founder & WA Ch. Head
low-blazer's Avatar
User is: low-blazer is offline
Send a message via AIM to low-blazer
I used one out of a 73-87 full size chev...dropped right in, worked like a charm. No shortening at all..
post #6 of 11 Old 07-05-2004, 12:30 AM
Awesome User
Diablo's Avatar
User is: Diablo is offline
i just looped my stock one
Diablo is offline
post #7 of 11 Old 07-05-2004, 01:18 AM
User is: Jeffyboy is offline
Send a message via AIM to Jeffyboy
Looped stocker here, too
Silver '85 standard cab short box S-10: .040 over 350, 10.5:1, 3.42 zexel posi, TH350, leather buckets, Autometer gauges, fuel cell, Xtreme rims with 255/50/16 rear and 225/55/16 front Sumitomos. 13.26 @ 104.5 mph on street tires
http://s10v8.com/members/jeffyboy/
'98 ZQ8 Sonoma - sold!
http://www.cardomain.com/jeffyboy78
Jeffyboy is offline
post #8 of 11 Old 07-05-2004, 10:25 AM
One Piece At A Time
sic ones's Avatar
User is: sic ones is offline
Send a message via AIM to sic ones Send a message via MSN to sic ones Send a message via Yahoo to sic ones
I actually went to the parts store and bought a small electrical connecter. You know, the type that is used to hook up to the output stud on the alt? I clamped that on my throttle cable and then soldered over it. It works great!!
One Piece At A Time -1989 Single cab short-bed 4x4
305 V8. Undergoing SM465/NP208 and solid axle swap.
Hell Hound-1992 Blazer Tahoe 2-door 4x2 4.3L Vortec V6/4L60-E. The new fixxxer-upper.
sic ones is offline
post #9 of 11 Old 07-05-2004, 11:41 AM
The One
User is: Smokedawg is offline
I built a bracket out of aluminum and bolted it to the high rise intake and attached the cable to it and made it work....
-Smoke
1990 Mustang GT-
347 Stroker--Compucar Nitrous, AFR, Systemax Intake, AFM, 30lbers, full suspension and lots more
1995 Chevy S-10
406 SBC, Dart 215 Pro-1 heads, Dual tunnel ram, Nitrous, full tub, 4-link, adjustable drag shocks, coil-overs, 9in rearend, 4.56 gears...etc
post #10 of 11 Old 07-05-2004, 08:14 PM
SK WUT?!?!?
JDime98's Avatar
User is: JDime98 is offline
Send a message via AIM to JDime98 Send a message via MSN to JDime98
go to the bone yard and get one out of a 87 full size truck a guy I know had the same problem and he used the full size cable and worked fine
JDime98 is offline
post #11 of 11 Old 07-07-2004, 05:46 PM Thread Starter
Thanks for the advice, guys!!! I tried to loop my stock cable yesterday, and it seemed to work fine, but i guess it was so old that when i tried to mount it in the new bracket i bought, part of the clip broke off!!! I took a trip down to o'reilly's and had them pull one for an 80's model full size, and the cable was a lot shorter. I went ahead and bought it, and it works great, although I still have to loop it a little. Thanks Again, E1!!!!!
njdad61 is offline
