The 5.3L S-10 goes 11.56@120.38MPH
Old 07-02-2006, 11:36 PM   #51
KING DORK
dbprecision2002's Avatar
Re: The 5.3L S-10 goes 11.56@120.38MPH
From what I heard and what I have seen the crossmember is going to be cut. I even have the manual on the swap but if I post there pics I would infrige copyright laws. LOL!
Old 07-03-2006, 10:57 PM   #52
cdnrednk's Avatar
yep, turns out I gotta notch that crossmember... Hate being wrong lol.
But, its no big deal to cut that out and weld in some bracing.
Old 07-03-2006, 10:59 PM   #53
KING DORK
Ya it does not look too bad just put some metal plates on the back of it to beef it. Then if you doing a/c going to notch out I thihk the pass side frame. Like inch and half.
Old 07-03-2006, 11:04 PM   #54
Unless you mod the oilpan,which cuts down on oil capacity of coarse but it has been done.You just need to find someone good at welding aluminum (prone to leak oil)
Old 08-12-2006, 07:47 PM   #55
9.52@152.65
Black X's Avatar
bump
Old 08-13-2006, 06:22 AM   #56
what type of heads are you running? I didnt notice it in your mod list. Want to do the swap but thinking of ported ls1 heads. If i do so will it be a direct bolt on or is there machine work involved?
Page generated in 0.56481 seconds with 31 queries
[Output: 56.98 Kb. compressed to 53.91 Kb. by saving 3.07 Kb. (5.39%)]
