tall valve covers?
Old 10-21-2009, 12:49 PM   #1
i fly low
red2ndgen's Avatar
tall valve covers?
I'm setting my engine in now for fitment and break in, i haven't got a tranny yet though, the firewall looks super tight on the bell housing(almost as if the tranny wont fit), is this normal? with the trans dapt mount from summit i am told i dont need any firewall mods? and also my tall valve cover isnt fitting with the factory brake booster, is this normal cause from pics it looks like people have talls on some of their 350s, and if this is normal can i get a smaller diameter booster to fit my valve cover, possibly off of an older s10?
Old 10-21-2009, 01:01 PM   #2
i fly low
red2ndgen's Avatar
Re: tall valve covers?
Old 10-21-2009, 01:58 PM   #3
Heavy Metal Body Man
Maverick2664's Avatar
things are going to be tight by the firewall, you will probably have to do some "massaging" with a hammer to get things to fit well... especially to get to the bellhousing bolts
and you will need a smaller diameter booster, you can either go with an aftermarket one or i hear the ones that came on a dodge neon fit, but double check that because im not 100% sure
Old 10-21-2009, 10:55 PM   #4
goin broke but n style
S15vortecpwr's Avatar
anytime i remove a s10 tranny i bend the pinch weld up on the firewall. it makes life simpler to remove the tranny again if it fails.
Old 10-21-2009, 11:01 PM   #5
Fronkensteen
The Griff's Avatar
I've got talls on my blazer I think blazer mounts are different though....
Old 10-22-2009, 02:01 AM   #6
i fly low
red2ndgen's Avatar
is it this same way with a 4.3, cuz i was assuming with the relocation mounts that from the 3/4 cylinders back should be exactly as if it were a 4.3? it was like this when i put a 4.3 into my firebird, i adjusted the mounts 6 inches back and it moved the engine back as if it were the back six cylinders of the sbc v8 that was in it.... it just hit me though that i hadnt measured how much the mounts offset the small block
Page generated in 0.56113 seconds with 31 queries
[Output: 57.63 Kb. compressed to 54.54 Kb. by saving 3.09 Kb. (5.36%)]
