LinkBack (19) | Thread Tools |
#401 |
Re: Swapping? Heres A List Of Parts And Answered Questions!
I have a 92 sonoma extended cab I'm about to swap a 350 into, so all I need is headers, mounts and an electric fan, correct? I currently have a jet stage 2 chip in it, will I need to remove that and go back to stock chip for this to work? also, is the computer harness plugs the same from the fullsize 350 the same for my truck (the actual plugs that plug into the computer box, if it is I'll get computer and all from the donor truck) one more thing, it is an ext. cab with the 2-piece drive shaft, I want to loose that and go with a one piece, is there any shafts out there that's the right length or will have to get one custom made? maybe one out of a longbed s10 or fullsize.
#402 |
i have a 2.2 auto 4l60e and a 4:10 rear end that is my set up i want to put a 93 fi 350 in it i have motor mounts and headers what else do i need
#403 |
#404 |
i dont have time to read this whole forum to see if someone asked this already but i have a 91 with the 2.5 in it and i wanted to put a 350 in it and i was wondering what would need to be done. my truck is bagged so the ac/heater blower and stuff is gone. and the windshield wiper fluid tank is gone. do they have motor mounts that mount right up? would i need a different tranny? or would it just be eaiser/cheaper to get the 4.3 that my year came with and put that in. i jus need more power. im not lookin to make it fast its just that the 2.5 dont get out of its own way. lol
#405 |
someone plz direct me to forum that covers all front caps and beds that will bolt on to a 1993 s-10, including GMC etc. i luv my s-10 and up until a few weeks ago it was in mint condition. i want to just exchance the bed & bumper, and i'd like to exchange the entire front cap to those 80's style with the little square grills. i'd like to go with an all "black" bumper no rubber bumper guard, yet have that plastic spoiler like the late 80's GMC's have. any help would be appreciated. Tom.
#406 |
i was reading over this tread and didn't see my question but i my have missed it so sorry if its been covered when swapping a 4.3tbi to a 350tbi can you use all the pulley/brackets from the 4.3
#407 |
This is my first time on this fourm and I might not have seen it but what if I want to take out my 95 4.3 tbi and replace it with a carburated(my bad on the spelling) 350 what will not work any more..... ie speedo indicator lamps ect. and what will i need to replace? Thanks for the help
#408 |
ginuine chocolate face
ok, so you're saying that i can drop a 350 in a 99 that had a 4.3 and an auto tranny by just changing a few harnesses and taking out the computer?
#409 |
ok i have a 91 s10 2.5 5spd i want to get a carbed 350 v8 and 4 spd trans what do i need to get???
#410 |
[quote=camaro590;4336554]ok i have a 91 s10 2.5 5spd i want to get a carbed 350 v8 and 4 spd trans what do i need to get to make the swap easier?
#411 |
2LO4BC
Location: Kamloops, BC CANADA! User is: OffLine ![]() |
#412 |
I have a question on radiator. What is the best radiator to use in a 96 s10 with a v8? Also i want to keep my a/c evap coil in place so i can use my a/c. I have a single belt system off a 93 chevy full size truck that i'm using. And most of all i don't want to cut it up to fit the radiator.
#413 |
NEED4SPEED!
I'm thinking of swapping in a carbed 350 w/vortec heads and 700R4 trans. into my CPI equipped 95 Blazer 4wd. What will need to be done to make my guages etc work? Also what about the fuel pump? Will the original pump work with the carbed setup? I'll only be runnin a 600cfm carb and making about 300 HP at the crank.
#414 |
DREAM XTREME
if i was to get a lq9 6.0 and it included all the wireing and computer junk needed would it basically bolt right in and would my stock gauges still work? and will a 6.0 bolt up to my stock 5-speed? thanks
#415 |
Sorry about this.. but i didn't have time to read this entire post. so forgive me if i am asking a question that has been asked.. I have a 2000 S10 Blazer 4x4 with the 4.3 that has 135k on it. i wanted to rebuild that motor but a v8 sounds way better. the blazer is lifted 6" with 33's.. I want to make the swap. what motor should i find to make it a smooth swap ?? computer issues scare me.. what do i need for this all to happen easy. lol..
thanks in advance.. ![]() |
#416 |
nothing ????? ![]() |
#417 |
Hello my name is Robert.I want to know if i can use the original 1992 S-10 radiator with the 350 engine.
#418 |
THANKS JOEY |
#419 |
takes 2 balls in our game
v8 swapmounts,headers or manifolds off of a low performace camaro(305).is the MAIN things
#420 |
#421 |
Acessory fits depend on which engine you are using. I am planning to use a '95 LT1 from a Camaro in my '94 Noma, and it is a 90% drop-in fit, with the Camaro accessories. Ah, but this is on a 2WD truck. 4WD is different. On the JTR manual, I have the 14th edition, which has a chapter on the 2nd gen. versions. This chapter is also on their website, if you go online to:www.JagsThatRun.com It is chapter 16. This just includes up thru 97. The third generation...??? ![]() |
#422 |
On all the threads about V-8 swaps,
I have never seen anybody raise the issue of the speedo scale. My truck goes to 85mph. The tach goes orange at 4500 and shows redline at 5000 rpm. The LT1 we are going to put into it will make these values a joke. What is available and what works for higher speedo scale, and tach recalibrating? |
#423 |
THERE HASN'T BEEN V8 NOVA SINCE THE 70'S IN THE 80'S IT WAS A FWD 4CYL. REBADGED TOYOTA COROLLA YOU MIGHT WANT TO CHECK YOUR FACTS OR LAY OFF THE DRUGS, THEY DO BAD THINGS TO YOU LIKE BELIEVING THAT THERE WAS V8 NOVA IN THE 80'S. |
#424 |
LOOK @ THE PICTURES & READ THE VERBAGE, YOU'LL GET THE IDEA. '82-'90 IS 1 GRILLE SETUP '91-'93('94) IS THE OTHER GRILLE SETUP WHICHEVER GRILLE YOU LIKE, YOU THE MATCHING YRS. RAD. SUPPORT FENDERS, DOORS, BED & CAB ARE THE SAME FOR 1sT GEN. INTERIOR WISE: 2 DIFFERENT DASH & DOOR PANEL DESIGNS, JUST THE ONES YOU WANT & INSTALL. SOME COMPONETS ARE SHARED FOR ALL YRS. AGAIN LOOK @ THE CATALOG. RUG, SEATS, GLASS, BELTS: SAME ALL YEARS HOPE THIS HELPS |
#425 |
I dunno if this has been talked about at all...did not really feel like posting a new topic or reading 9 pages of post's. But anways i do have the s10-v8 conversion manual and have givin it a good look through but i have not read weather or not i could transfer all the things off my 1993 2.8L to a 1994 5.7L, Like power steering, alternator, ac compressor?
#426 |
Hi, My Kids Engine Is Shot In Her 1994 S-10 Blazer 4x4 Was Thinking On A V8 Conversion What Would Be The Least Work And If I Stay With The 4.3 Vortecs What Years Will Work In Her 94 Thanks For Any Help
#427 |
Is that a zen riddle or something? Last edited by 2005lm7 : 02-08-2008 at 03:11 PM. |
#428 |
#429 |
i've read throughlyout of this thread but one question i've got thats went unanswered....
will the 350's factory A/C compressor clears the hood? i know that the ZR-2 models' will not clears without a 2 inch body lift, but i dont know about the regular S-series... thanks |
#430 |
He pissed on my rug
