Swapping? Heres A List Of Parts And Answered Questions!
LinkBack (19) Thread Tools
Old 07-08-2009, 12:14 AM   #501
Build them right....Mod
philntx's Avatar
Re: Swapping? Heres A List Of Parts And Answered Questions!
Bubba, please make sure you don't "hit" the Report post button. This sends an email to every administrator on this site that you have a problem to report.
Thanks,
Old 07-14-2009, 08:33 PM   #502
twisted2door's Avatar
I have a 01 blazer with the 4.3, I want to swap to a carb 350. In doing this will i run into any problem with wiring as far as taillights interior light, etc. Since the 350 does not have a computer,also is the tranny controlled by the computer?
Old 07-16-2009, 03:36 PM   #503
this winter ill be doing a 350tbi turbo 400 205 tcase swap into a blazer with 4.3tbi and a 700r4 trans and just wanteed to be sure that so long as i put the 350+400 computer in place of the 4.3+700r4 computer everything will be plug in and run right...correct?
Old 07-19-2009, 12:37 PM   #504
I am looking to make a swap also. I have a 92 single cab 2.5L 5 speed trans in a S10. I am wondering if there are any small block motor that will bolt up to my trans or do I have to get a different trans? I have been reading on here for days and cant find what I am looking for. I believe (from what I read on wikipedia) that I have the 2.5L TBI motor.
http://en.wikipedia.org/wiki/GM_Iron...engine#Tech_IV
Is this an easy swap or would it be easier for me to find a blown up 4.3TBI?
Also does anyone know the code or name of the 5 speed trans out of the 92 s10's that came with the 2.5L? I believe its the same trans as the 2.8...
Old 07-20-2009, 12:17 PM   #505
dpn't trust wiki. you can go into it now and just change anythign you wanna change and it'll show up. i've heard they just changed the bellhousings on that tranny.
i'm being told 2 different thing. that 1) i can just get the comp for the lt1 that i'm using and match that to the bcm that i have in the truck and 2) that i need to piggyback the new ecu to the old one. which one is it?? my truck is a 2000 xtreme if that makes a difference.
Old 07-26-2009, 07:37 PM   #506
where can I get a bracket for the tv cable and trottle cable?
Old 07-26-2009, 08:58 PM   #507
OK. i'll start off by saying i havent read the entire thread to see if my question is already answered, but everywhere i look to see if i need to swap out my 350's oil pan to clear the IFS. do i need to do this? the 350 is a 69-80 2 or 4 bolt main one peice rear main seal.
Old 08-11-2009, 11:31 PM   #508
Thumbs up Re: Swapping? Heres A List Of Parts And Answered Questions!
Just found a steal on ebay!
http://rover.ebay.com/ar/1/711-53200...4&toolid=10001 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170370955121&ssPageNam e=STRK:MESELX:IT
Old 08-16-2009, 01:56 PM   #509
Lots of Great information here. Thanks to all those that have contributed to this thead and this site with their vast array of knowledge.
Here is my one question: Could this realistically be completed in one weekend if all extra parts were on hand and ready to go in? The reason I ask is because the S10 is my daily driver so the less amount of time she's off the road the better.
Here's my plans...
1994 4.3 TBI 4L60E to 350 Carb 700R4
From what I've read thus far I'll need the following
Headers
Motor Mounts
Fuel Fittings to connect to the Carb
Guages
and Either a vette radiator or electric fans
and the 350 swap bible
I read through this entire thread yesterday and probably missed something along the ways so please let me know...
Thanks
Bradley
Old 08-18-2009, 10:28 AM   #510
Fronkensteen
The Griff's Avatar
Bradley - I guess a weekend job is feasible in one weekend if you have the knowledge, tools, time, parts etc... however, as with most major swaps there's always "gremlins", as we call them. that you just can't prepare for them, as well as the small nickle and dime stuff like hose clamps, fuel line, or vaccum tee's etc... So I can't rule it out, but I can't gurantee it either. I had all the "essential" parts in hand and started it hoping to have it running/ready to run right away and of course ran into different "gremlins". Such as fire wall modification, distributor clearance, fuel delivery issues etc... And this is just me speaking from my personal experience... the only way to tell is to jump in and get your hands dirty.
Also, As far as gauges, You don't necesarily need new ones, alot of us opt for new ones due to the simplicity of Auto Meter or other aftermarket
gauges...
Hope that helps a bit...
Old 08-18-2009, 10:29 AM   #511
Fronkensteen
The Griff's Avatar
I do know that there is a different oil pan for the 4wd's. Do you know which oil pan do you have?
Old 08-18-2009, 10:31 AM   #512
Fronkensteen
The Griff's Avatar
I bought a universal one for a carb @ O'reilly. I belive Spectre is the company that made it. Or you can go to the junkyard and find them on an older v8 truck as well....
Old 09-17-2009, 02:08 AM   #513
Question Re: Swapping? Heres A List Of Parts And Answered Questions!
okay, ive read just about all of this thread and i still cant find the answer to my questions.
i have a 95 ext cab its a 4.3 5sp 2wd
its tbi and i want to but a 350 tbi motor in it . im keeping it a 5sp.
my question is will everything plug in and run good. ive already made my tbi fuel pressure adjustible to solove the problem of it runing lean.
and it has obd II .
i had a 92 4.3 5sp and the only diffrent i see in the two motors is that the 95 has diffrent valve covers and trimming chain cover.
im planning to do this winter and get it done as soon as possible.
will everything be about the same as a 1st gen swap???
any help will be thanked greatly.
Old 09-17-2009, 02:50 AM   #514
Here was another extremely helpful link concerning the rear, for anyone doing a V8 swap, outside of tranny DONT FORGET that 7.5 grenade...This link details an 8.8 (yes blue oval) rear swap that is very cheap and easy..but the benefits are awesome..just wanted to share.
http://www.s10v8.com/showthread.php?t=9312
Old 09-21-2009, 11:53 PM   #515
and it has obd II .
i used 1st gen v8 kit it worked out fine i had a 95 ext cab with a 2.2 5 spd and went to a 350 and turbo 350 trans i had to trim the ears off the trans and that was i did away with alot of wires and it ran great all the accsesoories worked and all that now im about to start a 83 ext cab and go for the 350 swap
Old 09-28-2009, 02:59 AM   #516
I love fords, go figure.
94Sonoma94's Avatar
So heres what i got, 2.2 coversion to 5speed 355 carb.
Motor mounts
V6 Tranny/driveshaft
custom mounts
Custom headers/manifolds
radiator/essential plumming
wat am i missing, i feel like i need more.
Old 09-29-2009, 04:11 AM   #517
ok i have a 1997 s10 and i'm putting in a 383 stroker with a carb do i need any of the wiring i'm going to be runing a mallory dis. and coil and a 350 turbo tranny the block is punch out 40k
Old 10-05-2009, 09:18 PM   #518
eats "rice"
94sdime350's Avatar
My truck came w a 350 combo. I have a 350 tpi all aluminum w 700r4 w harness and ecu. Besides fuel pump what else do I have to change? What about sensors? And exhaust clearance w tranny? The 350 in my truck now has an oil pan leak and a tranny coolant line leak. So I think its time for a change. Any help would be great.
Old 10-08-2009, 01:10 AM   #519
Bouche's Avatar
ok i just dont get the concept of swapping the computers and harnesses. not the functionality part but how you do it. help
Old 10-12-2009, 08:48 PM   #520
Revolt's Avatar
Go to your local junk yard and ask if you can watch the proper removal of the ECM harness. If you have a local pull your own part yard go and have a look at the ECM harness and how its installed. Not a whole lot to it, really.
Old 10-15-2009, 10:06 AM   #521
eats "rice"
94sdime350's Avatar
Here are my mounts. They are fabbed. No kit. Hard mounts, bushings.
Old 11-09-2009, 07:05 PM   #522
jgreen's Avatar
I have a 2000 s10 2.2, automatic, im looking into swapping a 5.3 in it so i want to aquire some parts when i can, i know i need a tranny computer harness etc, but should i do fuel injection or have a carb?
Old 11-11-2009, 10:32 AM   #523
eats "rice"
94sdime350's Avatar
With fuel injection you can reuse some stock s10 parts from the fuel system. Like the fuel pump and pressure regulator. With a carb thats all gotta go w the swap. But a key point I need to make is w your truck being a 2000 model year. inspection might be an issue in your state. In NY we need to plug every car after 1994 into the computer for inspections. You cant plug anything into a carbed motor.
If you do go w FI check out painless wiring they have a harness for the 5.3 motor. It will make your FI swap go so easy. and i think they can do custom ecm flashing for heavilly upgraded motors.
Good luck w your project.
Old 11-15-2009, 09:06 PM   #524
1994dime's Avatar
ok i just wanted to clear this up for myself, if you use the computer/harness from a 4.3 wht exactly has to be done to it for it to work good with a 350?
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f10/swapping-heres-a-list-of-parts-and-answered-questions-23481/
Posted By For Type Date
V8S10.ORG • View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 01-08-2008 11:10 PM
ls-1 or carburated s-10? - LS1TECH This thread Refback 12-24-2007 07:19 AM
MAKIN MY S-10 FAST This thread Refback 12-21-2007 06:21 AM
Bond Calculator - time bond calculator, bond fdic This thread Refback 11-15-2007 09:13 AM
svirtokilo 49 post This thread Trackback 10-28-2007 10:42 AM
diagram s-10 block - Pagebull results 25 to 36 This thread Refback 09-27-2007 05:47 PM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 09-25-2007 02:16 PM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 09-24-2007 02:24 PM
Refinance Interest Rate - interest finance, does rate interest This thread Refback 09-06-2007 07:28 PM
Web Link This thread Refback 09-05-2007 10:12 PM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 08-31-2007 03:11 PM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 08-19-2007 11:28 PM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 08-15-2007 09:34 AM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 08-10-2007 12:39 PM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 08-10-2007 11:07 AM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 08-09-2007 02:08 AM
V8S10.org :: View topic - 95 4.3L V6 4x4 S-10 swap questions This thread Refback 08-08-2007 09:04 PM
2.5 to 4.3 - The Forums at Chevy Talk This thread Refback 06-30-2007 10:03 PM
Louisville Streets Discussion Board - S10 Engine swap This thread Refback 06-29-2007 12:46 PM
Page generated in 0.61798 seconds with 32 queries
[Output: 143.59 Kb. compressed to 133.96 Kb. by saving 9.64 Kb. (6.71%)]
