Swap 350 crate into bagged s10
I'm looking to put a 350 crate into my s10, but I'm not exactly sure that it will fit. Its bagged and lays frame on 20s. the stock control arms are modified. I'm basically thinking that fitting the headers in will be the problem. Also i wanted to know if the stock transmission, drive shaft, and rear end, will hold up to a 350 crate.
Re: Swap 350 crate into bagged s10
Never worked on a bagged s10, if your truck was a 4.3 the driveshaft/rear should work. However I and everyone else don't know what year or engine size your truck is, so the transmission is up in the air.
Might have to simply jump in and get your hands dirty. |
Heavy Metal Body Man
if your truck is only bagged and not BD'd, you can probably get away with hedman's longtube v8 s10 headers, they do not hang below a stock frame, shorties are also an option, hedman also makes a set of those, as well as patriot
if your truck is a 4.3, your driveline will work fine as long as you dont put any really good parts in that engine, you start making too much power and you will break the stock parts, especially the transmission, it wasnt really designed to be put behind a v8 |
Not rich, Just broke
the stock control arms might give u a lil clearance issue but other than that it shouldn't be too much hassle.. i've got a 350 in mine with tubular upper and lower arms laid on 20s and runnin patriot shorty's lays out with plenty of room
its a 97 with a 2.2.... i did some research about the transmission holding up and found out my buddy is running 800hp on the same stock trans and rear end. I'm still trying to find out about the headers clearing and what oil pan to get so i dont crack it when i lay it out
i forgot to mention that I'm planning on running just a stock 350
run a stock oil pan and shorty headers then would be my thoughts, keep it simple and u'll have the least amount of headache in the build
are you running fuel injection or a carb? because i wanna run a carb, but i dont know what to do as far as the computer goes. I'm looking into if i can get it wiped or exactly what i should do
i'm running fuel injection, running a carb would be much simpler for the most part of wiring it up and all since u wouldn't be using most of the wiring harness anymore
paint color? ... Mud =D
as soon as i saw that it made me and if money is no object to you, you could always invest in a dry sump system and get all the clearance you could want |
modified control arms wont clear unless their SD uppers...ask me how i know...
air ride technologies do clear, got em on mine....modified stocks wont
Tim loves his doritos
And in order to know what kind of transmission should be used, we are gonna need more information on this "crate engine". There is a huge difference in the demand from a transmission between using a ZZ4 crate and a Gen 0 crate.
you guys are making this way more complicated than it actually is... i dont see the need for a crazy ass pan/oil system setup... the pan on a small block doesnt hang any lower than it does on the 4.3's... hell my truck is bagged -and- bodied with a smallblock and still have at least 2 inches pan clearance, you can even put a high capacity pan on your smallblock and it will still work, the extra space is added to the sides, not the bottom
unless you made your truck all wheel drive, have an engine that make rediculous power, and plan to road race it... a dry sump oil system is a waste of money and time... plain and simple its not needed |
that is more or less what i mean, thanks for clearing that up, you need tubulars ![]() |
im puttin a 350 into a 97 thats bagged and bodied i have stock arms, u guys are saying that the stock arms are goin to be in the way of the headers?
under general experience yes the control arms hit the headers before laying out. not to say it's impossible cause seems like there's always an exception to the rule
yeah, mine hit real hard and put small dents in mine. whoopsie. I left my truck aired up mid way through the swap to get a jeck under it easier and left it for like a week...came back to find it aired out and control arms hitting the headers. My mistake, dont let it happen to you. Im pretty sure the only thing your BD will affect is the exhaust clearance and your hood most likely will not fit. The stock oil pan (mine was from a 4x4) hangs way above the skid plate and has no chance of hitting the ground.
Has anyone seen a layed out s10 with a v8 swap using stock control arms? i fail too see how its possible. |
#24 |
ROLL TIDE!!!!!!
i have stock control arms on mine with my v8 but it doesnt quite layout yet and when i go to make it layout i will surely have to get some tubulars the stocks will hit the headers. other than that there is no problem with having a v8 and laying out with bags. the oilpan still has plenty of clearance
#25 |
#26 |
i cut my uppers up just to see if they'd fit while i waited for my SD uppers in the mail (no it did not see the road like this) and they still dented them up when layed out
#27 |
#28 |
(Chaos)
Rofl
#29 |
You could always make your own headers....
