Rear axle questions
Old 07-01-2009, 08:33 AM   #1
Rear axle questions
Hi all,
Hoping for expert help here. I am putting about 450 to 500 hp into my s10 extended cab for drag racing. I know I will buy a Street Fighter T-350 transmission or similar for it, but I need to know what the rear axle will handle. The guy I bought it from had 456 gears and a mini spool installed in the stock rear-end and was running low 13s with a warmed over 350. The rear end looks small to me,though ( I think about 7 1/2"), and if this will not handle the torque, then I am wondering if there is a bolt-in that will work from another vehicle or if I would need to have one custom narrowed (not cheap, nothing is here in OKC) . Any help would be appreciated.
Old 07-01-2009, 08:45 AM   #2
Local Tech
ls1s10onair's Avatar
Re: Rear axle questions
with an automatic, and good driving, the 7.5 will handle a lot..... otherwise, you can get an 8.5 from a 2nd gen (they aren't too common, but they're out there)... thats 100% bolt on, tho in some cases, the driveshaft needs to be shortened. you can also get a for 8.8, with few mods to fit, but its wider than an s10 rear
Old 07-01-2009, 09:26 AM   #3
10 sec. street truck!!!
Formulakid1's Avatar
I went 10.50's on my 7.5" rear, but now I have a 9".
Old 07-01-2009, 09:29 AM   #4
So you think the 7.5 will handle running 11.70 1/4 mile times with 10"X 28" slicks?
Old 07-01-2009, 09:31 AM   #5
Why did you go with the 9" if the 7.5 was handling it? Just for safety reasons? Should I invest in a set of Strange or Moser axles for the 7.5 , or should I just wait until I can get something bigger?
Old 07-01-2009, 12:00 PM   #6
It is what it is bitch...
dre0227's Avatar
Its about the 8.8 explorer rearend. The best bang for your buck.
http://v8s10.org/forum/viewtopic.php?f=19&t=10989
Old 07-02-2009, 12:13 AM   #7
Why wouldn't an 8.8 out of a Mustang work? Has anyone tried it?
Old 07-02-2009, 12:16 AM   #8
Because the Mustang rear is not set up for leaf springs and the Exploder rear is almost a bolt in.
Old 07-02-2009, 12:22 AM   #9
I made well over 200 runs in the mid 11's on the stocker(stock axels with a Zexel unit from a Camaro)
But you let the motor have one hiccup on the starting line with nitrous and BAMMMM!!!!....it's time for an upgrade
The runs before the carnage were 10.50's with 1.4?'s(maybe 1.5?'s....don't remember) 60' times.
Either way.....if it's a NA application with an auto, the 7.5 will live almost forever.
Old 07-02-2009, 01:02 AM   #10
RecklessPerformance
C-Bo's Avatar
I've been told the issue with our stock rearend isn't the axles, it's the pinion that can't handle the shock.. I am not sure on this so any one can chime in on that with experience.. hopefully it will help both of our concerns!
Old 07-02-2009, 01:35 AM   #11
See post 9.
If you have a stick and some sticky tires....the 7.5 will die a gruesome death.
The ring gear and pinion will impersonate a hand grenade.
If you have an auto(no trans brakes....treat as manual) and you preload the suspension at the line....it will live a very long time.
It'll even live on the spray......until it stumbles off of the line....unloads the suspension...and then comes back to life before you can even think to lift, thus ripping the front tires away from the clutches of gravity.
BTW, this stunt resulted in the death of my 7.5 and 700R4 instantaneously.
Old 07-02-2009, 01:36 AM   #12
BTW, preloading the suspension will greatly reduce the amount of shock to the ring gear and pinion, and rear tires...thus(in my experience)making it easier to hook.
Old 07-02-2009, 01:41 AM   #13
RecklessPerformance
C-Bo's Avatar
will a ladder bar setup hurt or help with the shock?
Old 07-02-2009, 08:22 AM   #14
Mine is set up with slide-a-lock traction bars. I do not intend at this point to use nitrous for bracket racing (just another thing to worry about). Hopefully this rear end will hold up long enough to enjoy it before back-halfing, probably after next season.
Old 07-03-2009, 01:10 AM   #15
I don't think that would change.
Old 07-06-2009, 11:42 PM   #16
s10 junky
wolf36520's Avatar
mine runs 11.60s in the 1/4 pushing 450 hp with the stock 7.5 i beefed it up with a set of mosser axles,3.73 richmond gear and a minni spool running m/t e/t drags 15 26 10 and have never had a problem with it not being able to handle the power
Old 07-10-2009, 03:31 PM   #17
firstgenon24s's Avatar
Hey Fix Yo Door! lol jk
