rad w\long wp
Old 06-30-2008, 08:36 PM   #1
boudreaux is on a distinguished road
rad w\long wp
anyone have a long waterpump in an old body style s10...
i have cooling problems.....
Old 06-30-2008, 08:45 PM   #2
Re: rad w\long wp
bump , i have a griffin rad in the forward position,HAD a fan pulling it took a crap on me. so i decided to buy a good set w/shroud but i can`t find anything to fit...mounting surface is 22 1/2 x 15
Old 07-01-2008, 06:58 AM   #3
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
Re: rad w\long wp
Welcome to a v8 s10's main problmm....overheating
You say had "a" fan,whatkind of fan?
Old 07-01-2008, 11:57 PM   #4
markfothebeast is on a distinguished road
Re: rad w\long wp
Let me post my writeup on here. I have a long neck style waterpump also.
I had the idea in the back of my head about installing a radiator in the A/C cooler's place since I dont have a/c and i really want an electric fan. Now that I have done some research on it I see that its a fairly common mod. I thought I would post some-what informative photos for those attempting to do this on a 1st gen.
The inside diameter of the mounting area (15 3/4" x 32").
Next I searched for a decently priced radiator that I could have shipped out and recieved within the same week. I found a Griffin 15.5" x 27.5 3" deep dual-core radiator from Summit for $207 after shipping.
I removed the rubber mounts that were once in the radiators area and pounded down the tabs to make more clearance.
A screw is mounted in the center that will interfere with the radiator and possibly damage it. I just grounded down the tip about 1/2" to 3/4".
I bought a simple air cutting tool from Wal-Mart and cut the top of the bracket for the radiator filler neck to slide in.
My truck came with a lame single row radiator that was weaseled in and my fan was a 4-blade that was bolted directly to the water pump pulley. A flex fan wouldn't even had fit in that space it was so tight. I have much more space to work with now to allow an electric fan to fit.
This is the semi-final product. I took a dremel and ground off the sharp edges and painted the area. I have yet to install the external tranny cooler. I have cleaned up the engine bay and done some engine work since the 1st photo was taken.
Old 07-02-2008, 12:00 AM   #5
Re: rad w\long wp
I have no overheating issues!
Installed the electric fan setup. Cost me $83 for the fan and adjustable fan relay kit on Ebay.
The final product
Old 07-02-2008, 12:02 AM   #6
Re: rad w\long wp
I am running a high-flow water pump and high-flow thermostat also. I have barely seen 190 on a 90 degree day.
Page generated in 0.10421 seconds with 12 queries
