Race oil pan recommendations needed!
Old 11-01-2009, 07:04 PM   #1
man on a mission
Looking for the best fitting Race style oil pan for my destroked 400 powered 95 S10. I see milodon makes one but i didnt know if a claimer style would fit or not? Your suggestions are appreciated
Old 11-01-2009, 07:14 PM   #2
Re: Race oil pan recommendations needed!
is it 2wd or 4wd? if it is 2wd i have the milodon s-10 pan on my destroked 400 and it works fine plenty of room around the sump
Old 11-01-2009, 08:12 PM   #3
Ross Racing Engines
wayfastwhitey's Avatar
I'm using a Hamburger's oil pan on emann's 400. Should be plenty of room. Nice 8qt pan with good baffles and a splash screen.
Old 11-02-2009, 02:07 AM   #4
man on a mission
yea sorry its a 2wd. ill check out the hamburger pan also...Thanks fellas
Old 11-02-2009, 08:20 PM   #5
1 Fast S10! 9 Second Club
bgblock427's Avatar
moroso 8 qt pan with baffles here
Old 11-03-2009, 10:19 AM   #6
well what exhaust are you runnin? cause if you go with the inside frame longtubes then you CAN NOT run anything wtih a kick out sump. those headers will just about touch a dang stock pan.
Old 11-03-2009, 09:56 PM   #7
man on a mission
im probably gonna go with 1 3/4 fenderwells
Old 11-04-2009, 04:54 PM   #8
bgblock427's Avatar
Why does he have to run a kick out sump pan? mine is a 8qt with 2 in headers inside the rails.
Old 11-04-2009, 09:28 PM   #9
well if you have the hedman long tubes you cant run a kick out sump...
and with your eight quart pan how much ground clearence do you have? i couldnt have anything hang below the crossmember cause i am also lowered. it just depends on what he is doin wtih this thing.
Old 11-05-2009, 12:11 AM   #10
10 sec. street truck!!!
Formulakid1's Avatar
I can back that up
Old 11-05-2009, 12:12 AM   #11
I had to dempel the tubes to get them on with that pan.
Old 11-05-2009, 12:48 AM   #12
ya i had tried 2 different style pans and i couldnt get either to work without some mods. and then i thought about how fun it would be to change the starter.... you've already got to take the headers apart to get one in there with a stock pan...
Page generated in 0.57006 seconds with 31 queries
[Output: 75.42 Kb. compressed to 70.30 Kb. by saving 5.12 Kb. (6.78%)]
