power steering leaking from pump...
Old 08-14-2008, 12:42 PM   #1
Cutting Edge
truefire04's Avatar
truefire04 is on a distinguished road
i have tried to tighten the fitting as tight as i can get it but it steel leaks i really dont have room to get it any tighter. any advice?
Old 08-14-2008, 06:10 PM   #2
the youngest has been
tippmann243's Avatar
tippmann243 is on a distinguished road
Re: power steering leaking from pump...
is there an oring on it?
Old 08-14-2008, 07:38 PM   #3
Cutting Edge
truefire04's Avatar
yea everything that was on it when i got it....and i got it new.....so i have no clue, i dont know if im getting it tight enough because the pully gets in the way.
Old 08-15-2008, 03:05 PM   #4
Cutting Edge
truefire04's Avatar
ok update, its not powersteering fluid....its brake fluid.
Old 08-15-2008, 05:04 PM   #5
Cutting Edge
truefire04's Avatar
ok its not brake fluid...powersteering fluid.....this sucks....every time i stop or have to stop fast the pass. side smokes........
Old 08-16-2008, 08:12 PM   #6
BlazingSaddle is on a distinguished road
This is silly, there is no way you can let something "get in the way" and not be sure you got it tight. Get under there and take the darn thing apart, look for the right way to seal the fitting, if it takes an O ring, buy a new one, if not, wrap some plumbing / teflon tape around it and put it back together. Don't convince yourself you cant do it. Use dextron atf for power steering fluid and it'll be RED so you can tell the difference.
Page generated in 0.08483 seconds with 11 queries
