eats "rice"
Please help. carbed 350 to 350 tpi swap questions
Some one give me info on 350 to 350tpi w 700r4 swap. Any thing special besides fuel pump and return lines? And obviously wiring? Diagrams for 350 tpi 1988? How about O2 censors? what about tranny lengths? Is a th350 the same length as a 700r4? Assuming all mounts are same for motor and tran.
Re: Please help. carbed 350 to 350 tpi swap questions
The easyest thing to do is go to summit or jegs and buy a PAINLESS WIRING HARNESS that what i did and they are really easy if you not go at wiring
eats "rice"
Wiring isn't really a problem, I'm really just looking for the other stuff listed.
wiring will be the hardest part, definately do with a stand alone harness. An electrical engineer buddy and I tried to make it work and it just wasn't worth the time and frustration.
why not keep the th350? |
eats "rice"
The th350 is beat. It leaks; as does the oil pan on the motor. I gotta pull the motor to change the gasket on the pan. My friend needs a motor and I can get the tpi motor and 700r4 cheap . I know what goes into wiring a tpi motor. Ive swapped them tpi for tpi. Plus I love the look of a tpi motor compared to other fuel injected motors. My causin built one in his camaro 383 stroker motor. Its sick. I was in on that project. That was a while ago. I got "everything" pretty much figured out. For fuel Im gonna swap my holly blue fuel pump for a fuel injection rated one, and run a return line off the pressure regulator to the fuel cell. Im gonna Weld on new O2 bungs on my headers. and if I need a different length in the tranny Im gonna swap tail ends. I have tracked down a wiring diagram for a 88tpi motor and the camaro it came out of. Thanks guys will update soon.
what are you planning on doing to the computer?
eats "rice"
the motor is running in a camaro now. i plan on taking anything ican from it. including ecm.
vats?
Heavy Metal Body Man
do some research man, took me less than a minute to find this on google http://www.tciauto.com/Products/TechInfo/trans_dims.asp and this http://sethirdgen.org/tpi1.htm |
eats "rice"
VATS is not an issue since my tpi is an 88. No pass key either. Thankyou for the tranny link tho. Every lil bit counts.
