new here gas mileage for your carb v8s
Old 10-27-2009, 04:46 PM   #1
alright well im looking to buy an s10 an drop a v8 in i dont want to mess with the whole wire harness an ecu bs. so i figure carbing it would be the best way. my questions are at this. how much does it normally run? what gas mileage are you getting with your carb motors? an difficulty of swap? right now i drive a ford f150 4.2 v6 i love the truck just no options for it cause its a v6. no ways to get real power an its an extended cab with a long bed so its just not what i want. so i found a s10 on craigs with a little 4 banger in it for a super cheap price its a 91 or 92. so im lookin at a bit of body work suspension interior wheels an tires an motor. so any sugestions any threads that would help or websites would be great. im new here sorry if this has been talked about. pm me if you would like or post here. thanks
nick
Old 10-27-2009, 04:52 PM   #2
Registered Neanderthal
SH-60B's Avatar
Re: new here gas mileage for your carb v8s
That subject has been discussed just recently: http://www.s10forum.com/forum/f10/ga...w-a-v8-417008/
Old 10-28-2009, 05:52 PM   #3
built for stangs
slownlo's Avatar
if you are looking to get good gas mileage make sure you have an automatic with overdrive or a t56.. if you got a plane jane th350 or 400. your screwed. If all depends on how you build it. gears, transmission, tire size it all plays a factor. I
Old 10-28-2009, 06:29 PM   #4
Heavy Metal Body Man
Maverick2664's Avatar
yup, a th350 and a carb will get you less than 10 mpg unless the rearend is rediculously high geared, but wheres the fun in that... add an OD trans and youll see probably 15 or so, add fuel injection and youll see 20+
Old 10-28-2009, 08:03 PM   #5
alright. well im looking at buying a 91 standard cab with a 305 bored .60 over. lowered an everthing its awesome. an only 1200 bucks. needs motor to be pulled clean the motor put new bearings gaskets. an it will be all good. but needs a posi in the rear bad i havent went an looked at it yet but im going hopefully next week. an then well see im hopeing it turns out good
Old 10-28-2009, 08:17 PM   #6
992drjimmy's Avatar
For 1200, make sure its not a cobbled up hack job. You dont want to be fixing someone elses mistakes.
Old 10-28-2009, 08:17 PM   #7
firstgenon24s's Avatar
I get about 13 or so with a TH350 with stock rear but I have 24" wheels that help out a little bit when cruising.The larger wheels drop the rpms a little bit.
Old 10-28-2009, 08:47 PM   #8
built for stangs
slownlo's Avatar
1200 I hope you know what your looking at, if not bring someone with ya could be a pile, could be gold. Man 60 over is alot make sure he starts it for a little while to make sure it don't over heat.
Page generated in 0.57050 seconds with 31 queries
[Output: 63.92 Kb. compressed to 60.18 Kb. by saving 3.74 Kb. (5.85%)]
