Need some 350 info
I saw a really good write up on the 4.3, with regards to the various years, and what the changes on each one was - sort of a timeline thing.
Is there anything anyones seen like that for the 350's? If not.... I've got a line on a 1990 TBI engine out of a Suburban. I'm trying to figure out if there were any inherent flaws in that era, and things like the cam - is it a roller in that year? I need to let the guy know if I'm going to take it or not pretty quick. I'm not overly concerned about the head flow, as I've got plans to put a set of AFR's on it in a year or so. Thanks! |
Re: Need some 350 info
http://en.wikipedia.org/wiki/Chevrol...l-Block_engine
That don't have too much useful information, but its the best I know of. I'd be interested to see something more detailed myself. |
Call me Mario, Princess
Location: St. Francis, Minnesota User is: OffLine ![]() |
a 90 should be a roller engine. it was around 88 or so they changed them all over.
55'-86' 262-400 sbc are totaly interchangable 100% bearly anyhting was changed other than bore and stroke sizes. but the 85-86 corvette that had aluminum heads were a little different. 85'-86' tuned port injection systems are interchangeabale with all 55'-86' blocks with no mods
87' and up blocks are one piece main seal roller engines with centerbolt valve covers. 92-97 LT1/LT4 engines use a similar block with similar heads but nothing interchanges with the 87-up blocks. the tbi was used from 87-95 in most gm cars and trucks. in 96' the vortec was introduced. it used a plastic short runner intake. the vortec heads were based on the lt1 port design but can fit on any 55-up block. the gen1 based block vortec was used till 2000 I belive but in 98 the ls based engine was introdued which is 100% new and is totaly different. 4.8,5.3,5.7,6.0 are all ls based engines. |
the youngest has been
cars got roller motors in 87 but trucks got flat tappet motors till 95. granted they both run a roller block, but trucks dont have a roller cam |
OK, thanks all - that pretty much sums up what I needed to know.
Oh yeah - IF I wanted to run a roller cam on this block, is it pretty much just swapping the cam and lifters over (and possibly adding the thrust washer) ? |
