Make your own motor mounts.... - S-10 Forum
post #1 of 35 Old 06-09-2012, 05:24 AM Thread Starter
First Gens FTW!
Kansas Dime's Avatar
User is: Kansas Dime is offline
I've got an 87 S-10, the original motor was a 2.5 four banger. A buddy and I have a welder. Do any of you guys have a template to fab up some homemade motor mounts?
Thanks in advance, just trying to save some coin.
post #2 of 35 Old 06-10-2012, 04:11 PM
1sikdime
zizzybalooba's Avatar
User is: zizzybalooba is offline
Re: Make your own motor mounts....
If this is your first v8 swap you should look into getting the book on SBC swaps into S10s. I believe it even come with a template for the mounts. Your also going to need to buy stock 2.8 mounts to bolt to your frame.
Current Rides:
1985 S10- 350 swap, currently bagging
1996 Blazer LT AWD - Bone stock (Daily)
post #3 of 35 Old 06-10-2012, 05:53 PM
chevyman39452's Avatar
User is: chevyman39452 is offline
You can take the motor mount plate that bolts to the motor and then bolts to the frame mount from a 70s or 80s Chevy vehicle and cut a piece off of it and bolt it to the s10 frame mount just like V8 swap mounts, they work just fine I've used them several times when on a budget. I tried drawing you an illustration but its not to good but maybe you can get the picture of what I mean.
89 s10 blazer 350/700r4
85 c10 408 sbc
92 Silverado daily driver
post #4 of 35 Old 06-10-2012, 05:55 PM
Dang its upside down lol sorry
85 c10 408 sbc
post #5 of 35 Old 06-10-2012, 06:48 PM Thread Starter
First Gens FTW!
Yes it will be our first V8 swap, I'll look into the book. What gives with having to go to V6 mounts on the frame though?
post #6 of 35 Old 06-10-2012, 06:53 PM Thread Starter
First Gens FTW!
I appreciate it, not sure I'm quite tracking with you exactly though.
post #7 of 35 Old 06-10-2012, 07:16 PM
Yea it would be better to explain in person ill try to get an actual pic of what I'm talking about instead of a crappy drawing lol
85 c10 408 sbc
post #8 of 35 Old 06-10-2012, 07:22 PM Thread Starter
First Gens FTW!
Thanks, I sure would appreciate it.
post #9 of 35 Old 06-10-2012, 07:48 PM
Here's a pic of the mounts I'm talking about there the top mount mainly found on Chevy trucks but cars also you cut one of the bolt holes off then bolt it to the s10 frame mount so that it will set the motor forward like the swap mounts do its not as strong but I've used them with mild 350s in s10s with no problem. I also drew another picture so it will show you a little more of what I'm talking about
85 c10 408 sbc
post #10 of 35 Old 06-10-2012, 10:46 PM Thread Starter
First Gens FTW!
Thanks brother, I think I'm tracking alittle better now.
post #11 of 35 Old 06-10-2012, 11:43 PM
Yea its actually really simple just harder to explain on the internet
85 c10 408 sbc
post #12 of 35 Old 06-10-2012, 11:57 PM Thread Starter
First Gens FTW!
With running that set up are you good to go using the stock driveshaft and a 350 turbo?
post #13 of 35 Old 06-11-2012, 12:07 AM
B4U Task Force
Rhotpursuit's Avatar
Www.v8s10.org has all of the info you need including the best motor mounts.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #14 of 35 Old 06-11-2012, 01:02 AM Thread Starter
First Gens FTW!
Thanks alot, I'll check the site out.
post #15 of 35 Old 06-11-2012, 10:49 AM
Yea trans and driveshaft will work
85 c10 408 sbc
post #16 of 35 Old 06-11-2012, 01:52 PM Thread Starter
First Gens FTW!
Sweet, thanks alot brother!
post #17 of 35 Old 06-11-2012, 05:24 PM
1sikdime
Im almost positive your speedometer cable will even work on a th350. If your truck is a reg cab short box your gunna need the th350 with the shorter tail shaft to run the stock driveshaft
Current Rides:
post #18 of 35 Old 06-11-2012, 05:55 PM
I've done 4 regular cab short bed s10s and I've always used a long tailshaft th350 with my stock driveshaft
85 c10 408 sbc
post #19 of 35 Old 06-11-2012, 05:57 PM Thread Starter
First Gens FTW!
Mine is a regular cab shortbed, I figured it would have to have the shorter tail shaft.
post #20 of 35 Old 06-11-2012, 07:02 PM
I've always used a long tail with stock driveshaft
85 c10 408 sbc
post #21 of 35 Old 06-12-2012, 01:28 AM Thread Starter
First Gens FTW!
Well damn you said one thing and the other guy said the opposite lol.
post #22 of 35 Old 06-12-2012, 11:08 AM
Yea that's just how I've always done it my current s10 has a long tail in it and I'm using the stock driveshaft
85 c10 408 sbc
post #23 of 35 Old 06-14-2012, 01:07 AM Thread Starter
First Gens FTW!
Ok, just wondering though. Could I possibly use my 4 speed that was bolted up on my 2.5 and make that work if I didn't use a 350 turbo?
Just wondering, it never hurts to ask questions.
post #24 of 35 Old 06-14-2012, 10:23 PM
1sikdime
I had my motor and trans as far back as possible. maybe thats why? Maybe if you move it all the way forward a long tailshaft will work?
And no your 2.5 trans wont work.
Current Rides:
post #25 of 35 Old 06-14-2012, 10:24 PM
No the 2.5 trans want bolt up
85 c10 408 sbc
post #26 of 35 Old 06-14-2012, 11:55 PM Thread Starter
First Gens FTW!
That sucks about the tranny but thanks for letting me know guys.
post #27 of 35 Old 06-15-2012, 12:19 PM
If your truck is a 4 cylinder truck and it has the original rear end its proly low gears. You can check the rpo code to see what gears you have. If you have low gears like 3.73s or lower you might want a 700r trans if your gonna drive it a lot.
85 c10 408 sbc
post #28 of 35 Old 06-15-2012, 04:44 PM
1sikdime
Ya 10 4 on that.. mine had the 2.5 with 3.73s and i swaped in a 350/th350 and left the gears alone. It was ok for street but if your going on the highway look for a 700r4 for the extra gear.
Current Rides:
post #29 of 35 Old 06-16-2012, 02:10 AM
Yea mine has 373 gears th350 3000 stall it runs a lot of rpms on the street at 50-60 mph I try to stay off the highway.
85 c10 408 sbc
post #30 of 35 Old 06-17-2012, 12:35 AM Thread Starter
First Gens FTW!
Me and a buddy were able to fab these up.
post #31 of 35 Old 06-17-2012, 01:13 AM
Ford guy stuck w/ chebby
n8rsk8r's Avatar
User is: n8rsk8r is offline
hell yeah!
where in KS you? I am in Olathe. If close we should combine forces on some projects.. would help a ton!
-Nathan
1999 2WD Automatic S10 standard cab.
I have nearly rebuilt this damn truck 100%!!
n8rsk8r is offline
post #32 of 35 Old 06-17-2012, 01:25 AM Thread Starter
First Gens FTW!
Just north of the speedway a bit brother. We have a template to make the mounts if you'd be interested.
post #33 of 35 Old 06-17-2012, 11:29 AM
Them mounts look good man
85 c10 408 sbc
post #34 of 35 Old 06-17-2012, 09:08 PM Thread Starter
First Gens FTW!
Thanks, it was kind of a pain in the ass with the tools we had, but we managed.
post #35 of 35 Old 11-08-2012, 11:26 PM
87s10guy's Avatar
User is: 87s10guy is offline
Does cutting a full size mount really work I want to save some money but not if it's to week
87s10guy is offline
