lt1 install need help
Old 04-03-2008, 01:04 PM   #1
94ss s10's Avatar
im trying to install basicaly the intire drive train out of an 95 impalla ss into my 94 ss s10 does any one know what motor and trains mounts i can use the new motor is a lt1 350 and the trans is a 4l60e if any one else has done this swap, any advice or anything about problems i might run into would be greatly apreciated
thanks
Old 04-03-2008, 01:18 PM   #2
good bye red, it was fun
1/4milecrazy's Avatar
Re: lt1 install need help
2.8 motor mounts on the frame with V-8 swap mounts on the block,trans should line up with a stock auto crossmember and mount
Old 04-03-2008, 03:07 PM   #3
94ss s10's Avatar
the v8 swap mounts on the block do you know a part# or a manufacter i could get them from in canada also will i run into any clearence issues with the oil pan and the front crossmember
Old 04-03-2008, 06:44 PM   #4
Sittin on Chrome
eacyde's Avatar
Where in Canada are you?
Old 04-04-2008, 12:19 PM   #5
http://s10v8.carshopinc.com/product_...id/59/S10_2WDM
Old 04-04-2008, 01:38 PM   #6
Project Dime's Avatar
no u wont have any clearence issues with the oil pan and the front crossmember. just use a stock oil pan and u will be good to go.
Old 04-06-2008, 09:34 PM   #7
94ss s10's Avatar
im in pickering ontario canada and i went with a kit from trans dapt that lets me use 4.3 mounts for the motor, any one know if the trans will mount up with my orignal mount
Old 04-07-2008, 04:21 AM   #8
Hillbilly Mechanic
haha, pickering?
no way
im just finishing up my swap next weekend and will be out and about in that area all summer
id offer some advice but my lt got carburated
good luck dude
Old 04-07-2008, 09:22 AM   #9
Local Tech
ls1s10onair's Avatar
not to barge in, but 4.3 mounts are way too soft.... look on the jags that run website.... www.v8s10.com 2.8 mounts would be better
Old 04-07-2008, 03:05 PM   #10
Sittin on Chrome
eacyde's Avatar
x2 and there are more exhaust options with the 2.8 style mounts.
your other option is to go with Trans Dapt Plates and use OE v8 mounts
Old 04-07-2008, 09:49 PM   #11
94ss s10's Avatar
ha ha oshawa ill race you some time, the trans dapt kit i picked up is #4691 and it sugests useing there mounting pads #4218 any input on that, also what does everyone do with all the emission controls like the evap can and the air injection system i want to put headers on and i wont be able to reconect the lines, also will a msd 6al box still work with the opti spark system
Old 04-08-2008, 12:13 AM   #12
Hillbilly Mechanic
nice, right on man, always down for a good ol race...lol...just wonderin something tho, o you or anyone else know where to get the optispark bolts from(the ones that bolt the stupid thing to the block) or do you know the size of the bolt and threads?
94ss if ur engine isnt in yet and you can get to one of these bolts would you be interested in having a few made for me and i will pay you for your time and parts.
pm me dude, and we can work soemthing out, making them is my last resort, but gm dosnt list or stock them apparently.
Old 04-08-2008, 01:54 PM   #13
Local Tech
all the optispark bolts are, are ur timing cover bolts.... 1/4-3/8" longer..... i thought they were 1/4x20........ take out a timing cover bolt and get three longer ones
Old 04-08-2008, 02:01 PM   #14
Hillbilly Mechanic
wow, thanks a lot man, just saved me a lot of running around
Old 04-09-2008, 04:42 PM   #15
94ss s10's Avatar
any one have any advice on what to do with smog equ. like the air injection system and the egr. stuf
Old 04-09-2008, 08:13 PM   #16
Are you required to keep it? I ditched mine.
Old 04-09-2008, 09:58 PM   #17
Hillbilly Mechanic
all mines gone as well
Old 04-09-2008, 10:12 PM   #18
94ss s10's Avatar
thats the thing i dont know if i need it, will it pass emision testing with out it its going into a 94 and the new motor is a 95 so ether way i got a few more years of testing i think its 20 years every other year, or even what do they test against when i put in the 350, will they test against the 4.3's standards or the donor car's, if i can get away with it i want rid of the systems
Old 04-10-2008, 09:24 AM   #19
Hillbilly Mechanic
actually, ontario just f-ed up majorly on the law they just passed, no vehicle passed 1987 can or will be exempt, ever.
your truck, sorry to say it, will need to be sniffed even when its 50 years old
it sucks in a big way yes.
my suggestion is your going to need to have it all hooked up, although u will probably still pass just because u can go under Hot Rod classification, all you have to do is prove its not available in that truck, wich is very easy cuz there was never an 8 offered.
id go in and ask someone at a drive clean place, but what ive heard itll be fine...worst comes to worse, i know someone close that can pass anything.
good luck bro
Old 04-10-2008, 09:44 PM   #20
94ss s10's Avatar
yea ill ask some where any idea what the idea behind the air injection system is as best i can tell its just a centrifugal air pump atached to two check valves blowing into the exhost manifolds, i think my air pump is ceased cuz when i put in the fuse it blows and the motor runs fine with out it
Old 04-11-2008, 07:17 AM   #21
Hillbilly Mechanic
i wouldnt ask to much about the air pump, all it does is pumps air into ur exhaust so that it has a better ratio on the meter really
id just ask a drive clean guy if youd be classified under hot rod(wich im 95% sure u are) and find out how strict the legal amounts are....how i understood it, is u could pass a carbd engine with the right tune, but almost any FI'd engine will pass....dont know if thats true exactly, but im sure theres a little more to it than that...lol
good luck dude
Old 04-13-2008, 11:47 PM   #22
94ss s10's Avatar
hey what brand of headers do you use on the lt1 the guys at karbelt wernt sure
Old 04-14-2008, 12:58 AM   #23
Hillbilly Mechanic
just small block swap headers....i used cheap ones, and now im finding the passanger side is a tad tight to the frame...im not doin the exhaust so i dont really care, but its gonna suck for the wallet wen they guy overcharges me cuz of it....lmao
the LTX's have D shaped exhaust ports, 1st gen small blocks have O shaped ones, normal headers for a first gen small block will work, they just wont advertise that they work for it.
PS....The opti spark bolts are just 1/4" bolts 2" long..lol
Old 04-14-2008, 08:43 AM   #24
I use Sanderson headers
Old 04-14-2008, 08:30 PM   #25
94ss s10's Avatar
what did the sanderson headers cost you, and when repowering the rest of the truck do you only need to put power to the stud bar with the red wires on it, or am i missing some thing
Old 04-16-2008, 09:09 PM   #26
bkaltec's Avatar
I have sandersons now got them for i think 240 or something. They were quick to install and no issues and had good clearence. BUT, i just ordered some hedman longtubes, which from many people i trust say are quite a bit better. However they require the 350 style mounts and adapters, not the 2.8 style.
And on the wiring, youll probably have some power and grounds on the driver and passenger side body plugs. Grab some wire diagrams and check on it.
Old 04-22-2008, 07:49 PM   #27
94ss s10's Avatar
anyone know if the stock s10 fuel pump will be fine to feed the lt1
Old 04-23-2008, 11:55 AM   #28
former V8 AWD member
The Stunningman's Avatar
Yes it will work fine.
Old 05-02-2008, 09:40 PM   #29
94ss s10's Avatar
did any one reconect the a/c in on the lt1 i dont think the s10's compressor fits in the bracket the compressor clutch still has two wires on both compressors but it looks like the s10's has a 2 wire pressure sensor on its back but the lt1 has a 3 wire sensor on one of the lines any one know the conections also does any thing need to go back to the lt1 computer, i can find a wiring dia for the s10's a/c with out buying one any one help me out.
Old 05-02-2008, 11:03 PM   #30
c_ren's Avatar
I just printed off the wiring diagrams for the 94 s10 today. I am putting
a LT1 out of a 94 caprice and I also have the diagrams for it. I think that
the impalla and the caprice are the same. If you want them let me know
and I will see what I can do about getting them scanned and sent to you.
Old 05-03-2008, 12:06 AM   #31
94ss s10's Avatar
ya man id appreciate that the impala ss is acually a caprice 9c1 clone didnt find out till i got my hands on the car so ya we' are doing the same swap my email is camro44@hotmail.com you could send them there thanks
Old 05-03-2008, 10:41 AM   #32
capricefrk013's Avatar
The air injection is NOT needed. It was a recall by GM. Unplug it or pull the relay for it. It causes moisture to build up. They F-ED up with that one. When I got my caprice it was already disconnected by the previous owner. Which was the Ohio State Highway Patrol.
Old 05-03-2008, 11:10 AM   #33
c_ren's Avatar
I'll get them scanned as soon as I can, and send them too you.
Old 05-03-2008, 11:11 AM   #34
94ss s10's Avatar
thats good because my air injection pump is ceased anyways, whats the point of the charcole canister to me it just looks like it sucks fumes out of the gas tank
Old 05-03-2008, 11:12 AM   #35
94ss s10's Avatar
thanks c ren
Old 05-03-2008, 11:15 AM   #36
c_ren's Avatar
I just set my motor in last night. I had to remove the a/c compressor. If you want to run your a/c you are going to have to notch your frame for it to fit.
Old 05-03-2008, 11:19 AM   #37
94ss s10's Avatar
really thats shitty was that with the lt1's compressor or the s10's that one is a bit fater
Old 05-03-2008, 11:32 AM   #38
c_ren's Avatar
The one off the lt1. I am going to mount the one off of my s10 on the driver side where the coil is and relocate the coil somewhere. Just make sure you pull the compressor off of the lt1 before you set it in or you will have to pull it back out.
Old 05-03-2008, 10:18 PM   #39
94ss s10's Avatar
that puts a bit of a dent in future plans i was planning to mount a eaton m60 supercharger from a 3800 seires motor on the drivers side with a bit of modification, there farly cheep to pick up i gess ill see if i can just put up with the heat stuck sitting in trafic, what are you putting were the compressor was
Old 05-04-2008, 11:09 AM   #40
c_ren's Avatar
I think I am going to have to put an idler pulley there so I can route y belt properly
Old 05-05-2008, 11:33 PM   #41
94ss s10's Avatar
know of any pre fit kits or is this going to have to be a junkyard peice together deal
Old 05-06-2008, 02:07 AM   #42
dragsdaily's Avatar
i did some calling around today (drive clean) they told me v8 in s10 would be hot rod but we new this already. so i call a testing shop they told me if it's under hotrod all you really need is a cat and the proper gas cap to test. but if it fails then you have to start messing with it. maybe even putting the smog crap back on.
Old 05-06-2008, 12:40 PM   #43
c_ren's Avatar
Mine is going to be a piece together deal. I am making my own brackets for what I need
Old 05-06-2008, 06:04 PM   #44
94ss s10's Avatar
yea i think i will piece mine together too im aproching the 3000$ mark and i still need headers any one know a model # for headers the guy at karbelt is trying to tell me the bolt patteren is stightly different from regular 350 s10conversion headers to fit on the lt1, (and thanks for the info "dragsdaily")
Old 05-06-2008, 10:58 PM   #45
Use the standard headers SBC part for yours you have iron heads.
Old 06-01-2008, 10:25 PM   #46
Ok does anyone know if the stock LT1 manifolds out of a 95/96 9c1 will work for this swap? also mine is a 95/96 and I was wondering if I had the D shaped ports or O shaped ports...
Thanks in advance. I can weld anything so if i have to cut and relocate some sensor on my manifolds believe me when i say i can do it.
Best Regards
J
Old 06-02-2008, 09:51 AM   #47
bagged85's Avatar
d shape were only on the manifolds so any s10 v8 headers would work ok, i heard the stock manifold on the passenger side will hit the frame. im about 4 hours from you and doing the same thing. 94 s10 using a 96 caprice 9c1, let me know how the wiring goes, im planning on using all wires from the caprice but no clue what comp does what or what comp runs my guages, all other comps have been ripped out since i put in a carbed 350 last year.
and since you will need e-test every 2 years you should put all sensors back on as well as the 4 sensors infront and behind the cats
Old 06-02-2008, 02:37 PM   #48
c_ren's Avatar
I just wanted to give y'all some info on the VATS/Passkey system that you will need to know if you are installing a LT1. Go to my site (http://csansing.cyanidehosting.net/) click on the projects tab. Download the VATS Module Information file. The link that says my truck will give a pic of where the wires are that run the factory gauges. This is all for a 94 dime.
Old 06-03-2008, 06:17 PM   #49
94ss s10's Avatar
i dont think i need to put restors in the pass key system as long as i power the pass key system the motor started and ran fine but when i dont power it motor starts for a few seconds then shuts off, before i took the motor out of the donor i isolated the wires i needed all the way to under the hood and the only wires i acculy needed to make it run was the igniton set, passkey stuf, and fuel pump power wire, i still have to figure out which are for the gauges data port and warning lights, does any one know if the motor should sit level or a certen #of degre leaning to the rear, mine has a prity good slop to the rear going on
Old 06-04-2008, 08:49 PM   #50
LT1 S10 Expert
Aight guys... Don't be afraid of notching the frame. It's a simple cut and re-weld. You just need to get some sort of steel angle and get it welded in there. OR, there is an A/C Delete pulley that is made to specifically bolt in place of the A/C compressor. GM sells them or go to a camaro forum and do some searching around.
And why do you guys in Canada need A/C either way? Does it get hot up there???
You can yank the EGR and AIR crap as well as the charcoal canister stuff. Again, get on a camaro forum (try www.camaroz28.com ) and do some searches for custom tuning. You can send your PCM to people and have the correct stuff programmed in or out. Including the following: delete VATS, delete AIR, delete EGR, delete charcoal canister, program in whether you have an auto or manual tranny, rear-end ratio, tire size, etc...
The OBD-I LT1 really is a versatile system. I think that if you have a '96 motor you have an OBD-II system which is little more difficult to work with (and I don't have much experience with them as there is more crap to deal with). So hopefully you guys have OBD-I. Oh, and if you do happen to have OBD-II you can "change" a few things and go back to OBD-I. Not too bad of a procedure. Again, just do a search.
I'll try to go back and see if you guys had any other issues later.
Page generated in 0.65376 seconds with 31 queries
[Output: 207.98 Kb. compressed to 189.28 Kb. by saving 18.70 Kb. (8.99%)]
