just some pics of my v8
Old 07-03-2008, 02:43 PM   #1
Cutting Edge
truefire04's Avatar
truefire04 is on a distinguished road
just some pics of the 95 lt1 in my truck.
Old 07-03-2008, 02:48 PM   #2
S T F U
jakethegriff's Avatar
jakethegriff is on a distinguished road
Re: just some pics of my v8
looking good man! looks like you finally got her running good eh? good to see. what's the specs on the motor/truck?
Old 07-03-2008, 02:49 PM   #3
llorracs93s10's Avatar
llorracs93s10 is on a distinguished road
Quote: Originally Posted by jakethegriff
looking good man! LT1 i'm assuming, what's the specs on the motor/truck?
x2
Old 07-03-2008, 03:02 PM   #4
lt1s10onair's Avatar
lt1s10onair is on a distinguished road
not to pick apart anything, but that breather on the throttle body is gonna make it run like shit.... ur technically lettin in a leak after the maf..... nice tho
Old 07-03-2008, 03:14 PM   #5
donut king
lee-mill's Avatar
lee-mill is on a distinguished road
looks good
Old 07-03-2008, 03:21 PM   #6
Cutting Edge
truefire04's Avatar
motor is a 95 lt1 from a firebird formula truck runs great.....the only thing thats not working is the fuel gauge, and the cheep gauges that i got from summitracing......dont buy summit brand gauges....i have an autometer speedo, and fuel gauge, i had a autometer tach that i recalibrated for the v8...i know i get 250mpg....truck is a 98 s10 ex cab. can i just plug that line? and i dont know why the fuel gauge is not working, i dont know if the sender is bad or not.....it worked before the swap, but after it did not. and that was with the stock gauges.
Old 07-03-2008, 03:53 PM   #7
Y would you wanna do that
JonathanMaples's Avatar
JonathanMaples is on a distinguished road
ooo thats the where the pcv line went my bad i took a closer look.. ya hes right ur letting in un metered air u can just cap it off or go to a yard and get the pcv line most yards i go to wont charge for junk like that..
Old 07-03-2008, 03:58 PM   #8
Cutting Edge
truefire04's Avatar
no it was hooked to the valve cover i didnt have a good hose to put on is so i put that on. the truck runs great.
Old 07-03-2008, 04:02 PM   #9
formyadidas!!!
J.Cakes's Avatar
J.Cakes will become famous soon enough
wow, i wish i could get that kind of mileage with my 4 cyl
Old 07-03-2008, 04:04 PM   #10
i think you mean 25 mpgs, but is that true? I am having a t56/lt1 swapped into my truck right now and i wonder wat mpgs it would get.
Old 07-03-2008, 04:04 PM   #11
haha, we quoted and bolded the same thing....
Old 07-03-2008, 04:06 PM   #12
Cutting Edge
truefire04's Avatar
i ment 250 per tank...sorry
Old 07-03-2008, 04:07 PM   #13
i ment 250 per tank
how bigs ur tank? and wat trannyu using?
Old 07-03-2008, 04:08 PM   #14
Cutting Edge
truefire04's Avatar
i used the trans. from the firebird, i think the tanks is a 18 gallon
Old 07-03-2008, 04:20 PM   #15
Cutting Edge
truefire04's Avatar
sorry for the bad pics, but what do you expect from a camra phone.
Old 07-03-2008, 04:51 PM   #16
so its a t56 six speed or a auto?
Old 07-03-2008, 04:58 PM   #17
Cutting Edge
truefire04's Avatar
auto 4l06e
Old 07-03-2008, 05:00 PM   #18
auto 4l06e
o ok...i am doing the lt1/t56 six speed in my swap. Mine is also a std. cab, so i should have alittle less wieght than you especially since from wat i remember the first gens are lighter than the second gens to begin with.
I am also installing a 02 blazer rear with 3.42 gears and disc brakes. I am hoping for 18 avg. mpg, and 20+ hwy
Old 07-03-2008, 05:01 PM   #19
btw, you got any exhaust clips?
Old 07-03-2008, 05:17 PM   #20
Cutting Edge
truefire04's Avatar
no not yet
Old 07-06-2008, 01:12 PM   #21
my598's Avatar
my598 is on a distinguished road
here is my v8 project finally done. took off the tbi went carb runs alot better. really quick. my 90 blazer is next big block,nos,etc street truck. looking for a manual brake setup
Old 07-06-2008, 01:21 PM   #22
my598's Avatar
somemore pics. the manual brake setup is 4 the 90 blazer. trying 2 finish everything or close 2 before i leave 4 iraq again. will post pics with the carb setup.
Old 07-06-2008, 02:15 PM   #23
Cutting Edge
truefire04's Avatar
that looks really good
Old 07-06-2008, 02:41 PM   #24
my598's Avatar
thanks
Old 07-06-2008, 03:31 PM   #25
did you keep the 4x4? thats a nice swap. if u kept the 4wheel u got any pics of where u ran the pipe after the header and the front drive shaft?
Old 07-06-2008, 03:36 PM   #26
Blazin_Jason's Avatar
Blazin_Jason is on a distinguished road
Can I get some info on your remote oil filter setup? What parts did you use, no leaks?
Old 07-06-2008, 05:09 PM   #27
10 second club!!!!!
Formulakid1's Avatar
Formulakid1
I was running my oil filter just like My598.
It's just a remote oil filter kit from summit or jegs, but I used -8 an lines for my hoses.
It works great.....but mine started leaking after about 3 years of use....so I just relocated it to where the oil filter stood up like normal.
Old 07-06-2008, 07:40 PM   #28
Cutting Edge
truefire04's Avatar
thats not the pvc line the pvc line is on the driverside, i whent to autozone and got some caps from the help section and capped it off
Old 07-06-2008, 07:48 PM   #29
my bad,, i thought that was a part of the positive crankcase ventilation system, still your swap looks clean do you got any videos of it yet?
Old 07-06-2008, 08:17 PM   #30
my598's Avatar
yes i kept the 4x4 i`ll get some pics 4 u. it goes under the driveshaft. the pipe is removal so i could take out the trans.
Old 07-06-2008, 08:30 PM   #31
Cutting Edge
truefire04's Avatar
i dont sorry
