just saying good bye to the v8 guys its been fun.
Old 10-07-2008, 04:58 PM   #1
Cutting Edge
truefire04's Avatar
truefire04 is on a distinguished road
well as of the other day, i threw a rod....not sure how bad the damedge is....have not pulled the motor out of the truck yet, the v6 will begoing back in....im not sure if i even want to put the v8 back in due to some small problems i was haveing...powersteering leak, oil leak...
Old 10-07-2008, 05:10 PM   #2
tennerv8's Avatar
tennerv8 is on a distinguished road
Re: just saying good bye to the v8 guys its been fun.
Its all part of the game. Fix it and put it back together.
Old 10-07-2008, 05:34 PM   #3
Two Weeks!!
00s104.3's Avatar
00s104.3 is on a distinguished road
Thumbs up Re: just saying good bye to the v8 guys its been fun.
x2
Old 10-07-2008, 05:40 PM   #4
I SHIT BRICKS
OneLowSdime's Avatar
OneLowSdime is infamous around these parts
x3
Old 10-07-2008, 08:43 PM   #5
Power Hungry
RopeS's Avatar
RopeS is on a distinguished road
x4
Don't let a small thing like a thrown rod put you out of the v8 game..
You know even a v6 can throw a rod, right? Then what? A 2.2? lol
Old 10-07-2008, 09:43 PM   #6
94 s10 in progress
FxsX24's Avatar
FxsX24 is on a distinguished road
power steering leak = 30 bucks worth of hose and its fixed
oil leak, uhhh replace the gaskets/seals while you are fixing it
if it is something you have to drive then the 6 is ok, but you gotta revert everything back to the way it was before, i say rebuild it and drive something else
Old 10-08-2008, 12:22 AM   #7
Cutting Edge
truefire04's Avatar
yeah i have been thinking of rebuilding it, maybe better internals....cam.... i have a 97 jetta that i will be driving as soon as i get the clutch fixed...and i can get out of the thunderbird im driving now...i need to get a new oil pan i was told one from a 3rd gn f body would work....and the powersteering leak was leaking from the pump, fitting...and the oil pan was leaking from the oil level sensor....i guess if im going to go that far might as well replace the timeing set....
Old 10-08-2008, 01:30 AM   #8
BAGS FTMFL
v8lonoma's Avatar
v8lonoma has a spectacular aura aboutv8lonoma has a spectacular aura about
fuck the 4.3 sounds like a perfect reason to pull the v8 out and beef it up for more power. dont let some minor bugs that need to be worked out turn you away from the v8.
Old 10-08-2008, 10:41 AM   #9
Cutting Edge
truefire04's Avatar
its not...but i was just thinking that i wanted the truck on the rd, but now there is no reson for it now, so ill wate till i have the money to build the v8 up right
Old 10-08-2008, 10:48 AM   #10
chevy42083's Avatar
chevy42083 is on a distinguished road
Sounds like a good plan
Side note... I thought I was unique ... didn't know there was ANOTHER 2.73 geared LT1 2nd gen
You could always fix the power steering like i did.... the box has a loop of hose connecting the input to output, and i got rid of the stock accessory bracket You can barely see the loop, but here's the bracket.
Old 10-08-2008, 11:32 AM   #11
Cutting Edge
truefire04's Avatar
so how does that work for you? still have power steering....
Old 10-08-2008, 12:35 PM   #12
chevy42083's Avatar
No power steering
Mine was leaking so badly it was going out 1/2 the time anyways... so now it's just "out" all the time.
BUT... it'll NEVER leak again
Old 10-08-2008, 01:02 PM   #13
Cutting Edge
truefire04's Avatar
well i like haveing powersteering...so when i get around to taking it out rebuilding it putting it back in ill make sure everything is ok...
Old 10-10-2008, 09:56 AM   #14
Cutting Edge
truefire04's Avatar
what does a good rebuild kit normoly caost.
Old 10-10-2008, 03:56 PM   #15
V8 with bags
V8Blaze's Avatar
V8Blaze is on a distinguished road
yea dont ditch it, ive had some many stupid problems with my engine, its unbelieveabe, ive wanted to sell the whole heap many times. But then i remember why i built it, so i just fix it and keep on going. And a rebuilt kit differs alot in price. I know alot of people have personal preference on manufactuers. They go from a few hundred for a simple ring/seals setup to a few grand for new crank, rods, pistons the works. It depends on what you broke and what you want to spend
Old 10-10-2008, 04:13 PM   #16
Cutting Edge
truefire04's Avatar
well i hear a rod nocking, and now the lifters are tapping....so i want to do it right and upgrade everything so i wont have a problem later on. what about heads...i think ill go .30 over...i want to put a cam in it two....im not going to be useing it as a work truck anymore, and it wont be a dd...i have a 97 jetta for that.
Old 10-11-2008, 09:25 PM   #17
Cutting Edge
truefire04's Avatar
would the starter make the truck sound like it threw a rod?
Old 10-13-2008, 03:47 PM   #18
XtReMe_CaNaDiAn's Avatar
XtReMe_CaNaDiAn
without sounding like a dick, it sounds like your guessing, if you threw a rod youll know it, does it knock? and it should knock a lot worse when it first starts, a good start would be to drop the oil and look for any sign of metal, even better cut open the filter and do the same. I'd hate to see you go BACK to a 4.3 if its something that can be fixed quite simply
Old 10-13-2008, 04:15 PM   #19
Cutting Edge
truefire04's Avatar
well i had just changed the oil in it, a couple days before this happend....it knocks bad when you first start it and when you give it gass it gets even worse....its making a whinning sound also, i checked the belts but nothing seems to be broken....i checked the dipstick nothing on it ....i did run seafoam threw the motor....but like maybe 20 min. just sitting in the driveway.
Old 10-13-2008, 04:33 PM   #20
Anti chrome King!
95xtreme's Avatar
95xtreme is on a distinguished road
flywheel loose? but yeah what is your oil pressure doing?
Old 10-13-2008, 04:39 PM   #21
Cutting Edge
truefire04's Avatar
oil pressure is good....between 24-50....24 at idel and around 50 driving
Old 10-13-2008, 04:40 PM   #22
Cutting Edge
truefire04's Avatar
flywheel shouldn't be loose, i never touch the trans when swapping, put motor and trans in as one.
Page generated in 0.15041 seconds with 11 queries
