Idle with comp cam - S-10 Forum
post #1 of 10 Old 01-30-2007, 07:28 PM Thread Starter
User is: sboxv8 is offline
Send a message via MSN to sboxv8
Idle with comp cam
about rpm should my truck idle at ??? i got these off of the comp site
Comp cam
CS XE284H-10
intake exhaust
valve adjustment 0 0
gross valve lift .507 .510
duration at .006
tappet lift 284 296
valve timing at .006 open close
intake 36 68
exhaust 82 34
duration at .05 240 246
lobe lift .338 .34
lobe separation 110 degree
these specs are for the cam installed at 106 intake CL
im just wondering what RPM i should set my idle at.... my 350 includes...flat tops...441 heads...Edelbrock RPM air gap intake...heddman headers...edelbrock 650 carb...HEI with MSD ignition module with vacuum advance.. thanks
sboxv8 is offline
post #2 of 10 Old 01-30-2007, 07:45 PM
tomstoy's Avatar
User is: tomstoy is offline
Re: Idle with comp cam
mines a .488 lift comp cam and i am idling at 850 rpm in gear and about the same in park timming set at 10 degrees BTDC.
tomstoy is offline
post #3 of 10 Old 01-30-2007, 09:00 PM
11 second station wagon
The Stunningman's Avatar
User is: The Stunningman is offline
Comp cam
CS XE284H-10
intake exhaust
duration at .006
tappet lift 284 296
intake 36 68
exhaust 82 34
lobe lift .338 .34
Numbers at .050 are wrong I believe.
post #4 of 10 Old 01-30-2007, 10:58 PM Thread Starter
how do u figure that my .050 are wrong??? those are off of the comp site.. and 99.999% sure that is what it says on my cam card
sboxv8 is offline
post #5 of 10 Old 01-30-2007, 11:05 PM
Your #'s are right. Its a XE.
Should idle around 850-900 rpm with a lot of lope for your combo. Hope your either stick or have 2800 + convertor.
post #6 of 10 Old 01-30-2007, 11:29 PM
LSx and V8 Mod
SweetS10V8's Avatar
User is: SweetS10V8 is offline
Send a message via AIM to SweetS10V8
With a bonus of low vacuum for brakes....
Your cam is way way to big for your combination, now get a good set of heads and its a different ball game...
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
post #7 of 10 Old 01-30-2007, 11:52 PM Thread Starter
yea i know my heads dont flow what the cam would like but my buddy had some 441 around that he would let me use.... i am planning on getting some AFR heads sometime this next summer... the truck is only for weekend warrior till this semester is up so this summer so AFR's are on the way
sboxv8 is offline
post #8 of 10 Old 02-01-2007, 11:42 PM Thread Starter
like here again.... what does this have to do about rpm for idle... if you dont know its o.k. ... i do know about vacuum and heads... i am not made of money... i can't buy everything at once... so the 441 heads are a decent flowing stock head adn flow fairly well with some pocket porting...
so if you know so much abou everything what do u think the idle should be set at...???
Thanks Stunningman for the reply
sboxv8 is offline
post #9 of 10 Old 02-02-2007, 12:59 PM
NewV8S10's Avatar
User is: NewV8S10 is offline
Send a message via AIM to NewV8S10
The cam in my blown LT1 is similar to that one. Slightly different duration and more LSA, but it idles at 1k rpm. I hope you have a nice stall for that thing, and a vacuum canister for the brakes. Mine pulls about 8 inches on a 114 LSA.
Chris
NewV8S10 is offline
post #10 of 10 Old 02-04-2007, 02:09 PM
User is: 2BV8JMY is offline
900-1000rpm w/7-10" vacuum. I have an XE294 hyd.roller (242/248@.050) in a 383 and it idles at 900rpm w/9" vacuum. A flat tappett such as yours in a smaller engine should be rougher with less vacuum at comparable idle rpm..
2BV8JMY is offline
