ROLL TIDE!!!!!!
how much to shorten driveshaft?
i have a regular cab noma i am putting a 350 in it. im not sure as to what transmission i will be using either a turbo350 or 700r4 and the truck is bagged front and back with the sd bolt on 3 link. how much would i need to shorten my driveshaft? i will be draggin it too so it needs to be enough not to jam into the tranny when its that low. thanx for any help. i am putting this in the v8 section also
RecklessPerformance
Re: how much to shorten driveshaft?
I've swapped V8s into a 91 blazer 4.3l and a 95 single cab 2.2l and never had to modify the drive shaft! Surely being bagged it still won't matter.. not 100% though!
ROLL TIDE!!!!!!
every1 that i have talked to has said that i would need to im not sure tho i guess ill see tho mine is a 95 also
RecklessPerformance
ROLL TIDE!!!!!!
thats what i am going to use to i already have the 2.8 mounts on the frame now i am waiting on the conversion mounts to come in i have some pics of it in the same thread in the baggin it section if you would like to see it. i still have a ton of work to do. oh and did you have to cut anything on your firewall i am hoping the mounts will bring the motor away from it to where i dont have to
RecklessPerformance
The only firewall issues i had was clearance of the passenger side collector (heddman shorties) and used a hole saw to cut the floor/firewall at the pinchweld so it is easier to get to the tranny bellhousing bolts. I didn't have to cut the holes.. it just made life easier!
ROLL TIDE!!!!!!
ok thanx i wonder if i could just beat it in a lil or something
I have a 94 extended cab TPI 350 with th350. Originally had a 2.2 5 speed and I had to extend the driveshaft.
ROLL TIDE!!!!!!
i wonder if thats just cuz its extended cab? how much did they charge you?
i had a 350 in mine and had to modify the shaft,,but it was taching out the ass at highway speed so i put the 700 back in,,i would run the 700
ROLL TIDE!!!!!!
yea thats wat was making me consider it so it would be practicle for the highway im sure thats what ill end up with i want something good to race with to tho maybe ill have it built to where i know it will handle it
An ol Scott
Location: Greenville/Simpsonville SC User is: OffLine |
I had to shorten mine by 3/4in after I installed the engine almost up against the firewall.
i had mine shortend 3/4inches and put new ujoints and all in for like 165 bux, and balanced.
x RIDE N LOW x
i paid $95 to have mine shorten and balanced.
EAT ME
Location: Gadsden, AL-Indianapolis, IN User is: OffLine |
Didnt have to shorten mine at all.
ROLL TIDE!!!!!!
EAT ME
700r4 trans and these mounts:
ROLL TIDE!!!!!!
sweet how do you have your motor sitting? is it as far forward as possible or what?
EAT ME
yeah its all the way forward and all the way up as possible.
ROLL TIDE!!!!!!
ok thanx did you have to cut your firewall? well you gotta first gen its prolly different
EAT ME
Nope just had to beat it in for the headers and to get to the bell housing bolts easier.
ROLL TIDE!!!!!!
ok thats what someone else toldme also for a 2nd gen. why couldnt you set the motor lower then it would prolly clear the firewall better? or would the oil pan not clear then?
#24 |
V8 with bags
i didnt read all the post but here my info
Its not the motor mounts by themselves, its the position of the engine, and also if the trans is the same. Another thing people usually through into the mix when doing a project is lowering it at the same time. On an big static drop, and some air bag setups the arc of the suspension pulls the rear a little forward. This combined with a slighty rearward sitting v8 swap or a different trans, leads to almost everyone needing a different amount. Personally my engine is as far back as the JTR mounts will allow. And i measured for my driveshaft after in installed the 4 inch rear drop. I ended up getting i think 1.25 or 1.5 cut off the shaft. Then when i lowered the rear to a 6 inch drop i installed some JTR setback plates b/c my drive shaft was a little to far into the trans then i liked. Its best to wait until the last thing to worry about the shaft length. I only paid 80 bucks for the driveshaft shorted and new higher end u joints installed, but everywhere is different. Id just budget up to 200 dollars so you dont get any surprises with price or needs for the drive shaft to delay the project |
#25 |
ROLL TIDE!!!!!!
good info blaze my truck is bagged all the way around so i guess ill just have to wait and see how it turns out thanks for the help
#26 |
with the th350 it depends on the length of the tailshaft, they came in 3 flavors. 6" or short shaft, 9" or longshaft, and 12" that came in some trucks. if its out of a fullsize car it will be a 9" shaft and you most likley wont have to shorten the shaft at all unless its needed for your drop. a longshaft th350 (9") is the same size as a 700r4 or nv3500 that comes in s-trucks. the motor usually doesnt get pushed back any more than the stock motor as the additional length goes forward.
#27 |
ROLL TIDE!!!!!!
ok thanx thats some more good info to know. im sure i will be getting a 700r4 but i am really just using what i can get either way now i know what i will need.
