how much does s10 weigh - S-10 Forum
post #1 of 11 Old 07-11-2004, 03:33 AM Thread Starter
Beau
User is: gbody454 is offline
pretty straight forward......would really help with my cam and trans decision.
Its an 87 s10. Short bed, regular cab, was a 4 speed. ALL A/C equipment removed. I'm nowhere near a scale and i'm hoping a few of you V8 guys will know what they weight after the swap.
gbody454 is offline
post #2 of 11 Old 07-11-2004, 10:04 AM
IMBLOWN
jameskirk1's Avatar
User is: jameskirk1 is offline
Re: how much does s10 weigh
You should be sitting right under 3000lbs
post #3 of 11 Old 07-11-2004, 10:16 AM
www.myspace.com/MINTSICK
jmwxtreme43's Avatar
User is: jmwxtreme43 is offline
Send a message via AIM to jmwxtreme43
i know navecm in his 2 door 1st gen blazer with an LT1 weighs in at 3700lbs, my 2000 standard cab shortbed 2wd s10 weighs in at 3500lbs, they are pretty heavy trucks
post #4 of 11 Old 07-11-2004, 10:33 AM
tits, clits or bong hits
Slamed93noma's Avatar
User is: Slamed93noma is offline
Send a message via AIM to Slamed93noma
I have a 93 excab 4.3L automatic and it was right at 3500lb
" True minitruckers dont start with an xtreme"
Originally Posted by stodd16
haha yeah well atleast real men dont wear skirts
post #5 of 11 Old 07-11-2004, 11:07 AM
LT1 Powered
Navecm's Avatar
User is: Navecm is offline
Send a message via AIM to Navecm
i beleive rhansen has a 82 s10 with a 350/350 combo and weighs in around 3100-3200
94 S10 Blazer 2DR - LT1/4L60E|3.42s|3716lbs
94 S10 Reg Cab/Longbed - LB4/NV3500|2.73s
Navecm is offline
post #6 of 11 Old 07-11-2004, 11:57 AM
junky's Avatar
User is: junky is offline
gbody454,
I sent you a pm.
junky
junky is offline
post #7 of 11 Old 07-11-2004, 10:17 PM
footbraker
Rhansen's Avatar
User is: Rhansen is offline
weight in sig is with me and 3/4 tank of gas. truck weighs around 2950 by itself.
spare parts...
Rhansen is offline
post #8 of 11 Old 07-12-2004, 12:44 AM Thread Starter
Beau
I'm really wanting to use my powerglide but only if i can get the weight down. Where are some good places to remove excess weight on these trucks. I've already gotten all of the A/C stuff out...the bench seat is gone....that old carpet felt like it weighed a ton......where else?
gbody454 is offline
post #9 of 11 Old 07-12-2004, 02:05 AM
Severed Ties Petitioning
black82s10's Avatar
User is: black82s10 is offline
Send a message via AIM to black82s10
lose the inner fenderwells, remove all the things not necessary for the engine to run from the engine compartment, relocate the battery to the rear, get fiberglass body panels wherever possible(especially hood), get the heater box assembly out too(if possible) don't keep any of that emissions b.s. Pretty much what I've done, and I can't weigh much more than about 2500. I just don't have any glass parts yet. I also got rid of all the stock interior, and put in an aluminum dash with aftermarket gauges. But there's tradeoffs.
Originally Posted by TheFue View Post
all tools are neutral in existance until they're handled by the flaws of humanity.
post #10 of 11 Old 07-12-2004, 03:07 AM
Junkyard Master
User is: sbctimh is offline
could swiss cheese the core support/inner fenders to keep some support up there
I'd try losing the weight as far forward as possible myself to help the distribution
replace bumper with plastic bumper cover
5 S-10s and none of them fast
sbctimh is offline
post #11 of 11 Old 07-12-2004, 11:00 AM
footbraker
Rhansen's Avatar
All I've done is put in RCI (Summit) seats and the tailgate was a POS so I replaced with a tail-net. Truck came without AC or PB, still using a steel hood, inner fenders etc, and the motor has iron heads. It wouldn't take much to drop another 100-150#
spare parts...
Rhansen is offline
