Help With Emissions
hope this is the right place im new to the v8 conversion so i live in ga where you have to have emissions in most places so what are the rules on engine swaps here in ga as far as emissions go. I have a 1993 2.8 v6 with 5 speed manual wanting to go to 350 Thanks in advance
Re: Help With Emissions
No one knows surely someone had to get emissions done on there truck
not low, not gonna be...
not sure, but you may just have to pass HC and CO
sniffer requirements for 1993 models. maybe a visual check for the converter. you live in the metro Atl. area? you might want to contact state or county emission control authority to find out what the requirements are. Last edited by Crew Cab Sonoma : 11-04-2009 at 11:33 AM. |
you'll have to give more time for more people to read
this. at least a day. |
this might help:
http://www.cleanairforce.com/ http://www.cleanairforce.com/motoris...iontesting.php Last edited by Crew Cab Sonoma : 11-04-2009 at 12:16 PM. |
i called the clean air forcethey said that whatever motor i put in it when i get ready to do emissions the 350 has to meet the emissions requirements for the original motor ie the new 350 has to put out equal or less emissions than the 2.8 v6 i pull out is that even possible????
absolutely.
its measured by "PPM" or parts per million, or percentage of exhaust content, so even though the V8 will have a bigger total volume of exhaust, as long as the sniffer's "sample" of the gas doesnt exceed the maximum PPM or percentage, a large V8 can pass just as easily as a small 4 cylinder... Last edited by Crew Cab Sonoma : 11-04-2009 at 06:42 PM. |
WICKED 6 RACING
Getting a V8 to pass is fairly simple unless NOX is involved then it can be a little bit of a pain in the butt. The biggest issue is do the have to pass visual. Then you can have issues like needing cat fuel injection and everything else to make it pass.
