HELP PLEASE....Freeze plug Fell in - S-10 Forum
post #1 of 16 Old 12-15-2009, 07:16 PM Thread Starter
User is: revmoe is offline
Ok...so I was trying to remove my freeze plug from my 350 and I guess I hit it so hard that it went in...i didnt fall all the way in but...I cant get it out...Can someone help me get it out..
revmoe is offline
post #2 of 16 Old 12-15-2009, 07:21 PM
Heavy Metal Body Man
Maverick2664's Avatar
User is: Maverick2664 is offline
Send a message via AIM to Maverick2664
Re: HELP PLEASE....Freeze plug Fell in
steel or brass? if theyre steel, get a one of those telescoping magnets to help you fish it out, if theyre brass youll have to use a screwdriver or really long pair or needlenose pliars
once you get the plug by the opening, grab the lip with a pair or channel locks and pull it out sideways
-Under Construction-
98 S-10 extended cab: stock floor body drop, TPI 383 w/ 0411 pcm conversion, T56 manual
post #3 of 16 Old 12-15-2009, 07:33 PM Thread Starter
it's a brass freeze plug...but how to I turn in around in the hole so that the lip is out...because it seems like I cant get it out enough to grap it...the engine is still in the truck..
revmoe is offline
post #4 of 16 Old 12-15-2009, 08:09 PM
Looking for 8's
bgblock427's Avatar
User is: bgblock427 is offline
channel locks
post #5 of 16 Old 12-15-2009, 08:43 PM
just keep monkeying with it, youll get it turned around eventually, all you need is a place to grab with channel locks
post #6 of 16 Old 12-15-2009, 08:58 PM
Eight433's Avatar
User is: Eight433 is offline
drill a hole in it, then use something through the hole to pull it out. If you have a slide hammer, it should be cake.
-2011 Silverado Regular Cab Short Box 5.3 6 speed auto 4wd
-67 Cadillac Deville on air
-2000 RoadStar Silverado 1600
Eight433 is offline
post #7 of 16 Old 12-15-2009, 09:34 PM Thread Starter
Ok what about the metal and crap getting into the block...? I dont have a slide hammer....it seems as if it expanded or something when i knocked it in...
revmoe is offline
post #8 of 16 Old 12-15-2009, 09:40 PM
Eight433's Avatar
you only have to drill a small hole. there should not be many shavings that make it in the block. A couple shavings wont hurt nearly as bad as an entire freeze plug!
anyways, you could drill the hole, put a lag bolt through it or even a heavy screw or something, then you have a "handle" to grab onto with some locking pliers. yeah i'm sure its not gonna just fall back out. The screw could provide leverage to turn it sideways so you can yank it out.
Eight433 is offline
post #9 of 16 Old 12-15-2009, 11:06 PM
94 s10 in progress
FxsX24's Avatar
User is: FxsX24 is offline
i had the same thing happen to me, i just fished for it and got it, but the motor was on a stand so it was easier
1999 SAAB 9-3 SE
1994 S-10 PROJECT TRUCK 283 TBI V8
2007 YAMAHA NYTRO
Originally Posted by 2002redSdime View Post
only the most hardcore minitruckers are from canada, cuz even their milk is bagged!!
FxsX24 is offline
post #10 of 16 Old 12-16-2009, 01:23 AM Thread Starter
Well guys, while I was drilling a hole in it...It caught up on the bit, and came right out! So I got my block heater installed, and it's working great!
revmoe is offline
post #11 of 16 Old 12-16-2009, 08:50 AM
good to hear
post #12 of 16 Old 12-16-2009, 12:37 PM
"factory freak"...
Crew Cab Sonoma's Avatar
glad you got it.
even if it fell into the the water jacket, and you couldnt reach it,
it wouldnt hurt anything to just leave it in there...
wouldnt be the first time its ever happened...
95 S-10 2.2. Soon to be DD
post #13 of 16 Old 12-16-2009, 01:56 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
That is some kind of luck!
Teamsters Local 1150
SH-60B is offline
post #14 of 16 Old 12-16-2009, 11:37 PM
Originally Posted by Crew Cab Sonoma View Post
glad you got it.
yeah, 1 or 2 is nothing to worry about... its when you have a pile in there that you start to have problems
we have an engine come in our shop a year or so ago that the guy wanted rebuilt, and when we took it apart, we found quite a few plugs in the block, as if the last time it was rebuilt they just pounded them in and put new ones in
post #15 of 16 Old 12-17-2009, 12:20 AM
S-series abuser
User is: minitrucker83 is offline
If its ever hard to come out of the hole, you could always bend it to make it smaller. It wouldnt take much.
post #16 of 16 Old 12-17-2009, 02:13 AM
9 sec. street truck!!!
Formulakid1's Avatar
User is: Formulakid1 is offline
Send a message via Yahoo to Formulakid1
I'm guilty of having one floating around in my motor.........but all of them......WOW!!!
