Help Please
Old 10-29-2009, 08:21 PM   #1
Help Please
i have been running my small block chevy in my truck for about 4 months and love it. but the other day i was in second gear and then laid into the gas until i was at about 4500 rpms then when i let off and then started giving it gas again it had miss like i had foiled a plug. so i checked the plugs and the #4 plug was gunked up so i changed it but the cylinder still is not firing it is getting spark and the plug gets wet with fuel could it be the exhaust valve is stuck.
Old 10-29-2009, 11:36 PM   #2
Registered Neanderthal
SH-60B's Avatar
Re: Help Please
Pull the valvecover & have a look. Could be someting obvious like a broken rocker stud or bent pushrod.
Old 10-30-2009, 10:01 AM   #3
Re: Help Please
i was going to pull off the valve covers today to look if it is a rocker arm or push rod would it make the plug get covered with fuel ( if it is and exhaust rocker or push rod )
Old 10-30-2009, 10:19 AM   #4
1993 S-10 EL 4.3L
dcoogan's Avatar
Re: Help Please
good idea
Page generated in 0.55645 seconds with 31 queries
[Output: 49.10 Kb. compressed to 46.79 Kb. by saving 2.31 Kb. (4.71%)]
