got few ??
Old 07-02-2008, 10:24 PM   #1
dcrazywhiteboy is on a distinguished road
got few ??
I have a longbed s10 2.5 5spd that i took out and I am puting a 350 in it, once i get the 350 in how do I get it runing what do i hook the distributor to get fire and the alternator to to keep chargeing the battery. Also what do i do bout the gastank what will i need to do to make it work.
Old 07-03-2008, 12:44 AM   #2
conn.rod is on a distinguished road
Re: got few ??
it will basically be the same as the 2.5 you distributor may be different but the external coil wire will go the battery terminal on the HEI distributor.alt wires,starter wires,electric choke wires will be the same.unless your running a newer fuel injected model.
Old 07-03-2008, 03:30 AM   #3
Project Dime's Avatar
Project Dime is on a distinguished road
Re: got few ??
http://www.v8s10.org/forum/viewtopic.php?f=8&t=16
that should have everything u just asked...
Old 07-03-2008, 08:00 AM   #4
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
Re: got few ??
Just like conn. rod says.Use the original red/pink coil wire to hook to the dizzy.As far as the gas tank, just unhook the fuel pump and hang a pump off the block and your good to go.Use the originale lines, but,you will have to mod the 4 banger lines because of their location
Old 07-03-2008, 11:27 PM   #5
Re: got few ??
thanks everybody thats what i was leaning towards thanks
Page generated in 0.09577 seconds with 11 queries
