get electric or mechanical pump? and what size?
looking at getting a electric fuel pump when i get my fuel cell put in my truck i am trying to find out what size pump i will need.
it is a 91 sonoma with a pre 87 SBC 355 edelbrock intake and carb any info would be great! there is already an aftermarket electric pump hooked to the stock pump but i am thinking about oging ahead and replacing it. also what is the difference in mechanica and electric fuel pump? how do you hook up mechanical? pro's and con's? |
Re: get electric or mechanical pump? and what size?
i dont know much about this if you cant tell! haha
A mechanical fuel pump would be mounted to the engine and the crank would compress a lever inside the block that would compress a diaphram inside the pump to push fuel up into the carb, then release the lever, opening the diaphram back up that will suck fuel from the tank, the reason they don't push or pull from the wrong side of the pump is a pair of basic one-way valves. An electric pump can be mounted either in the tank or in the fuel line just about anywhere, though the reccomendation is usually close to the tank and below it. You do not want the pump to ever suck dry if at all possible. Either one should work just fine.
mechanical sounds too confusing i like the electric lol thank you though now i know
Hoods are overrated
haha
how is a manual pump confusing man? all you do is bolt it to the engine block. hook one hose to the fuel line from the tank and run a hose from the pump to the carb no wiring at all |
hay there artos did ya mean cam...
I did indeed, good catch, last night was a long night, they've all been long nights lately though.
x2 on that man. if ya look i didnt post that up till about 3 am. was workin a customers engine. i hate morons...
takes 2 balls in our game
Put a machenical pump on and be done. Just that simple
just bolt it up? maybe when i read it i made it seem like more than it is. i'm still trying to put it together in my mind sorry. i'm not the best when it come to engines i can do enough to get by but cant figure this one out
As long as the motor has the fuel pump rod in it,put a block mounted pump on it and use the original fuel lines and thats all there is to it.
where is this said rod?
bad s-10's brewing
Passenger side there should be an opening with 4 bolts around the perimeter.Theres a small hole inside ,aproximetly 3/8 in diameter that goes straight through to the camshaft.If you dont already have one go to your local parts house or junkyard and get a fuel pump push rod. Put some heavy grease on said push rod ( all around it so it stays inthe block ). Put the mounting plate with gasket on the block using only the 2 bottom bolt holes , then put the fuel pump in with with gasket ,making sure the fuel pump arm is under the pushrod . Atatch fuel lines bingo your done.
sweet i'll get that checked out! from ones i have found mechanical pumps are cheaper unless i looking wrong place
It is what it is bitch...
A mechanical will work just fine for you and be a lot easier. Like every said bolt on, hook up fuel lines and be done.
ok one more question........... the fuel cell i bought doesn't have the foam in it...is this a MUST have thing? or is it ok not to have any foam in it?
and if i do need it how do i put it in? just buy the foam and shove it in there? |
Just put some spray foam in it.
ROLL TIDE!!!!!!
i know this is kinda an old thread but i didnt want to start a new one
i have a mechanical pump on my motor and i need to hook up the fuel lines does any1 know what size fittings i will need to run a stainless braided line from the filter on the driver side framerail to the pump on my motor i will be using 3/8 inch line and im getting it all from jegs i dont know what size threads my stock filter has and i also need to know the thread size for the one on the pump that goes up to the carb my motor is a 350 from a 71 chevelle if that matters |
Heavy Metal Body Man
the threads on the pump (mechanical) outlet and the inlet on the carb's fuel rail are the same, and the threads are the same as a 3/8 brake line nut, we just plumbed a 383 we ran on our test stand
as for the what the fuel filter on the frame rail is i dont know, but theres a good chance its the same size/threads as the one on the fuel pump |
ROLL TIDE!!!!!!
ok so is 3/8 brake line nut different than any other 3/8 fitting cuz i bought what i needed in regular 3/8 fittings and it was too big
i dont know, we keep an inventory of AN and JIC fittings at work, ill see what fits into the fuel pump, both inlet and outlet
think i may have found something.... a size/thread comparison chart, looks like sizes are not constant across the board
http://en.wikipedia.org/wiki/AN_thread |
ROLL TIDE!!!!!!
ok so i guess i need -3 sized AN fittings
i might just call jegs before i place the order and let them help me out i did see this jegs mechanical fuel pump fitting kit and all the thread sizes are 1/4 inch http://www.jegs.com/i/JEGS/555/15940...ductId=1061702 im sure i have a couple 1/4 inch fittings laying around if i can find them i will see if they thread into my pump and filter |
#24 |
ROLL TIDE!!!!!!
ok i tried a 1/4 inch fitting and it was to small for the outlet on the pump and i tried a 3/8 plug that i had and it kinda sorta fit but the threads werent right for it
so i dont know i dont understand the AN type fittings maverick how did you run the fuel line to your pump? i just want to run a stainless braided line from my filter to the pump using 5 foot of the braided line thats what im gonna tell jegs when i call them lol |
#25 |
well since its a test stand, all we used was a rubber hose with hose clamps to run from the tank to the pump
im on my lunch right now, i didnt get a chance to fiddle with any fittings this morning, maybe ill head back early so i can do that for ya |
#26 |
ROLL TIDE!!!!!!
thanx for your help man.
i could do the rubber hose with clamps but that just doesnt seem to safe to run from the pump to the filter for a permanent line |
#27 |
if your using the mechanical pump can you still use the stock tank?
n my 86 2.8 what would i do with the fuel pump and sending unit in the tank and/or the extra lines |
#28 |
ROLL TIDE!!!!!!
you can use the stock tank and i have been told that i could just kill power to the pump and it will work
also i have been told that i will have take the pump out and extend the line on the sending unit to reach the bottom of the tank and reinstall everything im trying it first without doing anything with the pump if that doesnt work i will pull it out |
#29 |
Hoods are overrated
you can leave the stock pump in.
just unplug the power connector at the top of the tank |
#30 |
some get lucky and itll pull through the stock pump fine. and others dont.
just try it out. |
#31 |
well i messed around with various fitting this morning and none of the AN fittings worked, its a different type of thread, so far the only thing ive found that screws into it is like i said, a 3/8 brake line nut... this is for the outlet on the pump
as for the inlet on the pump is just a flanged male tube, if you got rid of the flange you could use a compression fitting you are using a carb correct? why the need for crazy high pressure fittings? carbs operate around only 7-8 psi and the only line thats pressurized is the one between the pump on the engine and the carb, from the engine back there isnt any at all.... a rubber hose and a few clamps is more than enough for a carb |
#32 |
ROLL TIDE!!!!!!
well i was just thinking i needed the braided line cuz my fuel line will have to run right under my oilpan and i thought it might get the line to hot and make it leak or something im sure i could think of a better way to route it tho
#33 |
if your oil is hot enough to cause surrounding lines to fail... you have other problems
#34 |
ROLL TIDE!!!!!!
lol ok well good then i dont have to worry about getting the braided line i can get this thing running tomorrow hopefully
still need to get my driveshaft shortened tho ![]() |
