fuel gauge
when you guys did your swap how did you all keep your gauge mine has not worked since the swap and what i have is the fuel sender in the tank with the pump tooken out with a rubber hose run down threw there i still have the fuel wires connected on the sender / i took out the stock fuel filter and ran a hose and i put an inline filter on.. and i have a mechanical pump to pump the fuel but i still have not gauge the fuse is fine what can it be and what did you guys do
Re: fuel gauge
on my first generation blazer the plug coming from the fuel pump there was 2 wires one was power 2 the fuel pump and one was 2 the sending unit i cut the brown for power 2 the pump and left the pink one pluged up for the sending unit! Not sure if yours are color coded the same hope this helps.
Re: fuel gauge
on mine there was 2 purple wires for the flot reader and the pump there was a black one and a tanish one i cut both and took the pump out sinc i got a mechanical pump
Re: fuel gauge
not sure but the factory gauge may not work since u remove the pump. I left my pump in but cut power 2 it cuz i have a mechanical pump 2.
Re: fuel gauge
then what did you use for the fuel pick up if the pump does not work?
Re: fuel gauge
the mechanical pump pulls gas from the tank the gas flow right throw elec pump even though it's not workin.
Re: fuel gauge
hmm but i dont know what wire to cut the black wire or the tanish wire
Re: fuel gauge
the tanish wire the black wire is a ground.
Re: fuel gauge
well the thing is i already took the pump out cut the connector of the pump and now i just looked for it and cant find it and i cute the tube that connect to the pump so dont think i could salvage this back together can i?
Re: fuel gauge
i would either check a salvage yard or go with aftermarket fuel gauge.
Re: fuel gauge
if i go with an aftermarket fuel gauge and my fuel gauge does not work right now will the after market one work? and how would i get it to work? i will not care if i go with aftermarket as long as i can get my gauge to work
Re: fuel gauge
i found the connector with the 2 wires one is grey and one is black if i take the sender back out and put the pump back in since i cut the long wrinkle tube i can replace that with fuel hose and the little black tube i do not know what to do with that can i just leave it off
Re: fuel gauge
if i'm not mistaking the aftermarket ones comes with its on sendin unit.
Re: fuel gauge
no they dont i just looked at summit and they are not included but did you see my last post i found the clip for the wires now if i do this and splice the wires back together and keep the grey wire cut will i get a fuel gauge?
Re: fuel gauge
u should i don't see why not.
Re: fuel gauge
Good solder job on the wire with a good jelly filled crimp over it. Your guage should work if the wires are still good under the rest of the car and dash.
An aftemarket one comes with a seperate sending unit. Going to the junkyard and finding a new top for that fuel tank isnt at all a bad idea. Going inside to tank to locate the rite wire and make sure you make everything continues to the guage float might be good too. A chevy still uses a 90ohm sending unit, I believe. (just in case you want to check float and make sure it works before putting tank back in?) |
Re: fuel gauge
well i already have it all back together i will pull the bed again and test the ohms and see wht i got
