fuel delivery question
Old 06-29-2008, 08:23 PM   #1
Does NOT Work For CIA
Prostreet10's Avatar
Prostreet10 is on a distinguished road
a lot of you guys no I am going from a munual pump with no return line to an electic pump with a return line. do I need a fuel rail or somthing up here?
this is the line that used to be here
What about a gauge also?
Old 06-29-2008, 08:25 PM   #2
Re: fuel delivery quetion
I know some dont like the Holley Blue pump, but this is all I have to work with at this point. $$$'s are a lil low at the moment.
Old 06-29-2008, 08:34 PM   #3
V8 AWD member
The Stunningman's Avatar
The Stunningman is an unknown quantity at this point
You should be running 1/2" from the tank to the regulator then 3/8" to each carb.
Old 06-29-2008, 08:38 PM   #4
Do I need to run a return? as it looks in the pics, its -08 line all the way up.
Old 06-30-2008, 09:49 PM   #5
V8 AWD member
No.
Old 06-30-2008, 10:20 PM   #6
trailwart's Avatar
trailwart is on a distinguished road
if by chance you need to run a return line, scrogindicky has a kit that goes to the filler neck on the tank. you could look at that and fab 1 up real easy.
Old 07-01-2008, 06:55 AM   #7
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
What will your fuel pressure be?I dont see a fitting for the fuel pressure gauge?Except on that duel line.
Your going to need to know how much fuel pressure you have.Are you planning on running without PSI gauge?
Old 07-01-2008, 11:54 AM   #8
I know, there is an adaptor I can get place off each carb. I just have to find them. Other than that do you see any reason this wont work at least for now?
Old 07-01-2008, 08:51 PM   #9
V8 AWD member
I had a 6-71 Blown 23 T bucket. It had a blue fuel pump with no return line but 2 Holley's 1/2 to the regulator then 2 3/8 lines to carb. It had 0 problems with fuel delivery... when full throttle was used.
Old 07-02-2008, 11:15 AM   #10
Rudejester.s10 is on a distinguished road
Re: fuel delivery question
Umm I would suggest a fuel log for those carbs...Those edde's like to surge without em..(damn emulsion tube carbs)...looks like a sweet rig though.
Old 07-03-2008, 08:12 AM   #11
s10-den's Avatar
I ran my without a return too, but, I only drove it about 15 miles at the MOST on the street.The pump and the fuel was a little warm.Like Stun says, it will work, but, I dont know how much or how long you plan on having this beech running or driving at a time.
Old 07-03-2008, 01:08 PM   #12
It wont see long journeys or anything. 15-20 mile one way trips is really all. that and a bunch of 1/4 mile blasts is all.
I hope to have it running this weekend. will post video if i get her done.
Page generated in 0.13062 seconds with 11 queries
