fast burn vs vortec heads - S-10 Forum
post #1 of 15 Old 09-15-2003, 01:06 PM Thread Starter
Project: Sabriel
MuddyS10's Avatar
User is: MuddyS10 is offline
Send a message via AIM to MuddyS10
ok, i was looking at heads for the v8 when i drop it in (4 years down the road, gotta start saving), and it seems like the fast burn's are better then vortecs. GMPP has a ZZ383 i was looking at that seems really really nice, and would work prefectly with what ill do with it, but what are the major differences in vortec and fast burn heads?
Corey - 1999 Firebird Formula Trans Am, Blue-Green Chameleon, M6
Mods = Yes
Project: Sabriel
MuddyS10 is offline
post #2 of 15 Old 09-15-2003, 02:53 PM
User is: SmallBlock_98_S10 is offline
The Vortec heads are more new school with their bowls in how they maximize the air and fuel, where the Fast Burn heads are more of an old school design that relies on larger valves to force more fuel in. The Vortec heads in stock trim can only accomodate about a .500 lift cam, so if you are thinking about a big cam and more modifications down the road, you might want to consider the Fast Burn heads because their springs can hold up to a .550 (I believe) lift cam stock. Also, the Vortec heads requires a special intake manifold that's more expensive than the standard head bolt pattern intakes.
Or, you could just spend the money now and buy a set of Dart heads and never have to worry about anything !!
Just my $.02
post #3 of 15 Old 09-15-2003, 04:26 PM Thread Starter
Project: Sabriel
MuddyS10's Avatar
dart heads? lol i was just asking, cuz theres a 383 w/vortec heads, and a 383 w/fast burn heads (ZZ383), and i was thinking of putting a turbo on and a hotter cam
Mods = Yes
Project: Sabriel
MuddyS10 is offline
post #4 of 15 Old 09-15-2003, 07:17 PM
User is: tomskifi is offline
dood vortec heads \fast burn are the same
tomskifi is offline
post #5 of 15 Old 09-15-2003, 07:22 PM Thread Starter
Project: Sabriel
MuddyS10's Avatar
um...i doubt it. the specs are totally different, the fast burn engine has more power, and if they were the same why would they have en engine with fast burn heads, and an engine with vortec heads?
Mods = Yes
Project: Sabriel
MuddyS10 is offline
post #6 of 15 Old 09-15-2003, 07:49 PM
dood the vortec heads fast burn combustion chamber dnd hi velocity ports combaine produce big hp you have many pr#for dif applications ck gm perf parts
tomskifi is offline
post #7 of 15 Old 09-15-2003, 09:47 PM
eric0o1's Avatar
User is: eric0o1 is offline
Send a message via AIM to eric0o1
fast burn heads are the aluminum version of the vortec head. However, the fastburns are junk!!!! They flow a lot less out of the box than vortecs. even with machine work and new springs, you can have a good set of heads for less that $1000. I believe pro line sells vortec heads that can accomodate more lift. Also, Comp now makes a ls1 style beehive spring for vortecs that will allow a higher lift without having to have the seats cut.
02 Blazer (2wd), supercharged 383 in the works http://www.s10forum.com/forum/f10/20...3-swap-456167/
eric0o1 is offline
post #8 of 15 Old 09-15-2003, 09:49 PM Thread Starter
Project: Sabriel
MuddyS10's Avatar
huh? i did...theyre diff heads...
Mods = Yes
Project: Sabriel
MuddyS10 is offline
post #9 of 15 Old 09-15-2003, 09:59 PM
eric0o1's Avatar
any time I've head any one refer to a head as a fast burn head, they've been talking about the aluminum vortecs. This is coming from parts guys at a chevy dealership
http://www.goautocenter.com/cylinder_heads.htm
3rd one down "vortec intake"?
eric0o1 is offline
post #10 of 15 Old 09-15-2003, 10:05 PM Thread Starter
Project: Sabriel
MuddyS10's Avatar
no, the HT 383 vs the ZZ383 on this page http://www.superchevyperformance.com/sbcrate.html
says the HT has vortec heads, and 100 less hp, and the ZZ has fast burn heads and 100 more hp
Mods = Yes
Project: Sabriel
MuddyS10 is offline
post #11 of 15 Old 09-15-2003, 10:08 PM
eric0o1's Avatar
the fast burns are vortecs, trust me, they're just aluminum. Redesigned a little, but none the less, they're vortecs. That other motor has more cam and a roller valve train, not just different heads.
eric0o1 is offline
post #12 of 15 Old 09-15-2003, 10:17 PM Thread Starter
Project: Sabriel
MuddyS10's Avatar
so the ZZ383 is still the better engine right? i was looking at a 385, but the hp and tq numbers for the 383 are better. i wish i could drop a 572 ramjet, but thats not going to happen.
Mods = Yes
Project: Sabriel
MuddyS10 is offline
post #13 of 15 Old 09-15-2003, 10:20 PM
Off Roadin' Member
fmfredrider501's Avatar
User is: fmfredrider501 is offline
Send a message via AIM to fmfredrider501
man if you put that 572 ramjet in that zr2 and stuck some drag slicks on the back i bet that thing would do a wheelie! GM has alot of nice crate engines, too bad i dont have enough money for one. plus another problem i run into is 99% of them are for carbureted setups and you would hafta switch over some stuff for FI and the engine itself is already expensive enough.
4.3/3500/233/208/44/60/35" General Grabber MT's
post #14 of 15 Old 09-15-2003, 10:20 PM
eric0o1's Avatar
it all depends on how much money you want to spend. The better motor generally cost more money
eric0o1 is offline
post #15 of 15 Old 09-15-2003, 10:29 PM Thread Starter
Project: Sabriel
MuddyS10's Avatar
yeah, when i get the ZZ383 its going to FI, carb'd setups dont work too well when ur wheeling (off-camber, sitting sideways, ect doesnt make fuel flow right in them), i was also thinking about a big-block merlin....but thats too much work lol
Mods = Yes
Project: Sabriel
MuddyS10 is offline
