Electric cooling fan - S-10 Forum
post #1 of 9 Old 01-11-2011, 11:44 AM Thread Starter
User is: Gbrown2934 is offline
What size electric cooling fan are most of you using with the 350 engine swap?????
post #2 of 9 Old 01-11-2011, 01:10 PM
http://www.vicbaggers.com
Ricky's Avatar
User is: Ricky is offline
Send a message via AIM to Ricky
Re: Electric cooling fan
My advice, go with biggest you can fit, or a couple of 10-12" ones..
I have 2 10" Zirgos high CFM ones on the way..I'll let ya know how they do.
Ricky is offline
post #3 of 9 Old 01-11-2011, 01:40 PM Thread Starter
Thanks, I was going to buy a 16 in 2250CFM , before I purchased I wanted to see what other 350 users were using
post #4 of 9 Old 01-11-2011, 03:45 PM
m.a.d.'s Avatar
User is: m.a.d. is offline
im using dual electric fans from a 2000 ish malibu, not sure of the cfm but they fit as pushers right where the ac cond. was.
95 s10 383, 12to1 comp, world ported and polished heads, msd, air gap intake, quick fuel carb, lunati 240/250 0.50, 3.73 gears,electric water pump&fan 1/8 7.40 @94, 1/4 11.60 @ 114.9 mph
m.a.d. is offline
post #5 of 9 Old 01-11-2011, 04:15 PM
Ricky's Avatar
I would do like I did here..& cut out a hold for the fan. Mounting it on the radiator is fine, but I think it'll cool better w/the shroud.
I had it just mounted on the radiator on my 4.3 & it did awesome, but the V8 will run a lil hotter I assume.
Ricky is offline
post #6 of 9 Old 01-11-2011, 05:38 PM
4x4 v6 blazer
neo71665's Avatar
User is: neo71665 is offline
A v8 will run hotter esp if you are running inner fenders. A shroud is key to making an electric fan work at its best. It also needs to be spaced a bit from the rad and not just laying flat on the core. A good cheap trick is to use aluminum cookie trays sized the closest you can find to the core size of the rad. Cut the hole(s) for the fan(s) and mount that to the rad.
87 blazer tahoe 2 door, 5.7, auto, sfa 4x4
91 noma reg cab, 3.4, 5speed, lowered
President of the Arkansas chapter Anti-bag Coalition
"Bags are for groceries"
Originally Posted by alarm_the_alarm View Post
Lift That Sh*t, Fat Girls Can't Jump
i just made love to your bowels......and then reported them.
neo71665 is offline
post #7 of 9 Old 01-11-2011, 06:17 PM
Ricky's Avatar
My shroud is about 5/8" - 3/4" away.
Ricky is offline
post #8 of 9 Old 01-11-2011, 09:34 PM
4x4 v6 blazer
neo71665's Avatar
Mine is just ugly as sin but its a mud buggy.
neo71665 is offline
post #9 of 9 Old 01-14-2011, 01:43 AM
Spark Plugs Are Overrated
DieselS10's Avatar
User is: DieselS10 is offline
Exactly!
I ran two 14" Perma Cools in a shroud that I made when I had the sbc's in my truck. My truck is/was way heavier than most S10's so it was under a greater load all of the time. With that setup I could pull a fullsized car or truck on a trailer in the middle of July and it would never heat up at highway speeds or setting still, so I know they can be made to work great.
Always mount them as puller on the engine side of the radiator and always shroud them.
'85 S10 4WD Ex-Cab Long bed, LLY/Allison/241/241, Locked 1 Tons with air-ride and 38's.
-{Click Here For Build Info}-{Transfer Case Doubler Info}-{ Click here for Duramax Swap}
