Cutting off
Old 05-24-2009, 06:25 PM   #1
airedout's Avatar
Cutting off
Have a slight problem i have a 88 s10 blazer stock 350,with a 270 comp cam elderbrock intake,elderbrock 1405 carburetor! It has a rough idle but when i put it in gear it idle 2 low and cuts off! Can anyone offer any suggestion?
Old 05-24-2009, 07:11 PM   #2
Hoods are overrated
sadexcuse4s10's Avatar
Re: Cutting off
get a timing light
clamp 1 end on ground, and 1 end on the #1 spark plug wire (drivers side front) and check the timing off of the crank shaft balancer. there's a little timing tab, it may be nasty and you may have to clean it off.
get it timed to 0 by turning the distributor one way or the other.
that's a good base to start from, then you can adjust the timing + or - depending on how it runs as you give the motor some gas
Old 05-25-2009, 01:28 AM   #3
Johnny87's Avatar
Re: Cutting off
Sounds like the converter is not enough for the cam... I dont know what duration on that cam is but You are probably going to have to get it idling high in park to idle down right in gear.....
But i would start with the timing to.... I would set it advanced at about 37ish, for a stockish 350. So try and set the timing advanced with the vacium hose pulled off the distributer, and blocked from the intake.
Old 05-25-2009, 09:57 AM   #4
goin broke but n style
S15vortecpwr's Avatar
Re: Cutting off
you want about 37 total timing, and idle timing you would want anywhere form 0-8 degrees, some eng can take even 10 degrees, depending on cam and octane of gas used.
It also sounds like it may be idled 2 low, idle it up a bit with the idle screw on the throttle.
Old 05-25-2009, 03:37 PM   #5
airedout's Avatar
Re: Cutting off
Thanks the specs on the cam 470" lift 270 duration!
Old 05-25-2009, 10:27 PM   #6
Re: Cutting off
with something like that, i woudl recommend a 2500-3k stall convertor. What is your stall.
Old 05-25-2009, 10:38 PM   #7
airedout's Avatar
Re: Cutting off
It's the stock stall when i ordered the cam they told me it was the biggest cam i could run on the stock stall converter!
Old 05-26-2009, 11:42 PM   #8
Re: Cutting off
that is really pushing it.
have you tired to idle it up to see what it does, i woudl start with 100 rpm increments.
Old 05-27-2009, 06:58 PM   #9
LXtasy's Avatar
Re: Cutting off
I was going to suggest idle as well. what is it idling at to begin with?
Old 05-30-2009, 01:17 PM   #10
bad s-10's brewing
solenoid's Avatar
Re: Cutting off
That paticular cam is pretty tame , the duration you quoted is actually advertised duration. The duration at .050 lift is closer to 228 duration. I agree with the rest of these guys get your timing set and readjust your idle, your convertor shouldn't play into this at all.
Old 06-27-2009, 12:07 PM   #11
airedout's Avatar
Re: Cutting off
Well guys i've tried everything and its still cuttin of soon u put in gear only thing left 2 2 try is changin out the torque converter!
Old 06-27-2009, 02:52 PM   #12
Your God Drives a Dime!
Ecartman84's Avatar
Re: Cutting off
Make sure you put a vaccum gauge on it and check for a leak. It could actually be something as simple as that. What does your vaccum read @ idle?
Old 06-29-2009, 07:29 PM   #13
airedout's Avatar
Re: Cutting off
Lol went 2 get a stall converter and realize i don't know what kinda transmission i got! do any of u guys know what transmission came with a pinion yoke on the tail shaft and no shift cable works of vacuum alone and is not computer control?
Old 06-29-2009, 09:15 PM   #14
Re: Cutting off
sounds like a turbo 400...
but the convertor is not your problem! i've got the same cam in a 350 in my 82 van. it idles at 750-770 in park. and 680-700 in gear. it sounds rough but it isnt at all. still have plenty for the steering and brakes. you have some other issue goin on.
and this is with a stock 700-r4 convertor with lockup...
Old 06-30-2009, 12:25 AM   #15
Registered Neanderthal
SH-60B's Avatar
Re: Cutting off
Does it stall only when cold, and it's OK when warmed up? Electric choke? Set the idle mixture screws with a vacuum gage for the highest reading when the motor is warmed up, then back each one out 1/4 turn for slightly rich. It may be that they are set too lean and the motor is stalling from lack of fuel. The primaries should be full closed at idle. If the idle comes up while you adjust the idle mixture screws, turn it back down.
Old 07-01-2009, 11:07 AM   #16
Re: Cutting off
No, the cam is not too big. Why not set up the idle a little faster? Also,there should be no rough idle with this cam. Check the carb settings and the ignition timing.
Old 07-03-2009, 03:38 PM   #17
bad s-10's brewing
solenoid's Avatar
Re: Cutting off
Try to set your timing with a vacum gauge. Its kind of old school but it works. Advance your timing till you get the highest manifold vacum (not ported) when you get that turn the distributer 1/4 inch farther advanced and it should be good.I have a 98 vortec with 95 4.3 serpentine and cant get a light on my balancer ,this has always worked well for me ... Good luck
Old 07-26-2009, 10:22 PM   #18
airedout's Avatar
Re: Cutting off
wanted 2 thank everybody for their input and suggestion,finally got this thing going the problem turned out 2 be valves were adjusted 2 tight! Thanks again everybody!
Page generated in 0.59746 seconds with 31 queries
[Output: 97.02 Kb. compressed to 89.70 Kb. by saving 7.32 Kb. (7.54%)]
