Comp Cams 270H in a 350 V8? - S-10 Forum
post #1 of 11 Old 03-15-2005, 02:08 PM Thread Starter
User is: BigDuVall is offline
What do you think? My plan was to put it in my V6, but I think it's totaled, so I might as well do a V8 swap. How big of a cam can I put in a 350, or would my 270H work well?
post #2 of 11 Old 03-15-2005, 03:33 PM Thread Starter
Re: Comp Cams 270H in a 350 V8?
Nobody has any opinions?
post #3 of 11 Old 03-15-2005, 03:52 PM
V8 Member
the_dubster98's Avatar
User is: the_dubster98 is offline
Send a message via AIM to the_dubster98 Send a message via Yahoo to the_dubster98
i may be reading it wrong.. are you trying to use a v6 cam for a v8?
mmm wont work. if thats what your wondering..
post #4 of 11 Old 03-15-2005, 03:58 PM
footbraker
Rhansen's Avatar
User is: Rhansen is offline
What compression ratio?, which heads?, you'll need decent heads to turn it past 5500 rpm.
270H prolly needs at least 9.5:1 CR and should rev to 6000 rpm+-
spare parts...
Rhansen is offline
post #5 of 11 Old 03-15-2005, 03:58 PM Thread Starter
Here's the specs...
Part # CCA-CL12-211-2 Hydraulic Cam & Lifter Kit
RPM range 1800-5800
Dur Adv 270/270 @.050 224/224 Lift .470/.470 110 LC
post #6 of 11 Old 03-15-2005, 04:08 PM Thread Starter
I haven't found an engine yet, just blew my V6 last night.
post #7 of 11 Old 03-15-2005, 04:10 PM
footbraker
Rhansen's Avatar
edit
try to find a decent set of heads. If it were me, I'd look for a used truck motor w/vortec heads, have the work done to the heads (.500+ lift cams), bump the CR to around 10:1 and use a roller cam like the Crane 119831.
spare parts...
Rhansen is offline
post #8 of 11 Old 03-15-2005, 04:48 PM
9 sec. street truck!!!
Formulakid1's Avatar
User is: Formulakid1 is offline
Send a message via Yahoo to Formulakid1
Call Comp Cams and talk to Brian Brannen....he knows his stuff and hell take care of ya.
post #9 of 11 Old 03-15-2005, 04:53 PM
footbraker
Rhansen's Avatar
Originally Posted by Formulakid1
Call Comp Cams .
yes
spare parts...
Rhansen is offline
post #10 of 11 Old 03-17-2005, 05:29 PM
superprohero's Avatar
User is: superprohero is offline
I ran the same cam in my 406 when it had stock 400 heads that I hogged out. It smoked the tires infinitely before I tubbed it out. I didn't have any cooling issues even using a Camaro radiator. I did buy the appropriate valve springs for that cam though. You'd probably be suprised how good it will run.
http://www.superprohero.com
Definition of "Trailer Trash" (tray-lure trĂ¢sh) A Mopar after the 1st round of eleminations at the drag strip.
post #11 of 11 Old 03-17-2005, 05:50 PM
Magnuns are good cams.....just old technology. The extreme stuff has kind of kicked em to the back burner.
I had a 280(i think) magnum in my truck for a long time.
