Carb Question
Old 10-10-2009, 03:32 PM   #1
Carb Question
Just wondering if im running Too big of a carb.... ive got a brand new setup ready to be dropped in my 85 s10
went with a 4 bolt main block got it for 50 bucks...
350
Eagle Kit Steel Crank,Forged Rods,Hyper Pistons
.060 over
Pro Comp Aluminum Heads 2.02 1.94 valves 190cc runners
Flat top +5cc pistons
RPM intake
Comp Cams XE274 cam
TH350 w/3000 stall
3.73s in the rear Mini Spool.....
i was running a 750 vac secondaries before on a similar setup... its Jetted at 70s up front and a metering block conversion out back with 72's...32 shooter with a 50cc pump on it... just wondering if its too much carb i don't want to ruin this new setup... please any advice would help
Old 10-11-2009, 01:17 AM   #2
1 Fast S10! 9 Second Club
bgblock427's Avatar
Re: Carb Question
it would come out of the hole faster with a 650. unless your turning over 7200 its a little to big but not much.
Old 10-14-2009, 06:35 PM   #3
Sox Nation
Re: Carb Question
I have a 750 double pump on my set up which is a 350/350 and its not that wild. the 750 can work if its tuned in right, but thats the trick. I got lucky that my friend used to build and tune carbs so he did it right. If your gonna go with a lot of pony's then it should be ok. On a normal, not to crazy set up, a 650 usualy works better.
I have a 383 in production and Im going to put that carb on it as well. definately make sure you have the right jetting for your altitude/climate, it does make a difference.
Old 10-14-2009, 11:17 PM   #4
FKNBMPN's Avatar
Re: Carb Question
Which accelerator pump cam are you using?
The only thing I would think would be a tad smaller on the jets, maybe a smaller pump nozzle, and anything besides the "brown" accelerator pump cam.
Old 10-15-2009, 12:05 AM   #5
Registered Neanderthal
SH-60B's Avatar
Re: Carb Question
A 750 is fine for that motor. A 650 could become a restriction.
Page generated in 0.55863 seconds with 31 queries
[Output: 52.93 Kb. compressed to 50.26 Kb. by saving 2.67 Kb. (5.05%)]
