Cam Question
Old 10-08-2009, 10:57 PM   #1
Cookston60's Avatar
Cam Question
I have a cam question. I am getting ready to put a 305 tbi in my 4.3tbi s10. We are taking the 305 .30 over with flat top pistons. What kind of cam should I use? I am looking to get the motor to have a nice deep sound. My grandfather is helping me build the motor. He has built tons of carb motors, but not many fuel injected engines. So, he wasn't 100% sure on the type of cam to use. Thanks in advance for all of the help.
Old 10-08-2009, 11:13 PM   #2
I'll need human lives...
1fast4by's Avatar
Re: Cam Question
A whole lot depends on what it is you are trying to do with it. And what other parts you will be running.
Old 10-08-2009, 11:20 PM   #3
Cookston60's Avatar
Re: Cam Question
The motor is going to be pretty much stock other than cam and taking it over 30. We are going to rebuild it; it is going to have the stock heads with a new valve job, stock crank, .30 over pistons, a new cam, and maybe some bigger injectors. That's all I can think of right off. Let me know if I left anything out that needs to be added.
Old 10-09-2009, 08:01 PM   #4
LSx and V8 Mod
SweetS10V8's Avatar
Re: Cam Question
TBI doesnt allow you to use many cams. for example...Comp Cams only makes 1 TBI cam.
I would put a carb on it, maybe even swap to TPI.
Old 10-09-2009, 10:54 PM   #5
Cookston60's Avatar
Re: Cam Question
I am going to keep the tbi, because I don't want to have to change out the wiring harness. I will check with comp cams and see what kind of cam they suggest. I appreciate all of the help.
Old 10-14-2009, 10:30 PM   #6
Towmanred's Avatar
Re: Cam Question
Call the summit tech line and ask if this cam will work for you... The summit part number is 1103.. I use this on my carbed 327. Has good low end torque and pulls real well, best part is you can use a stock converter, so I think it will work for a tbi setup.
Page generated in 0.56983 seconds with 31 queries
[Output: 56.45 Kb. compressed to 53.40 Kb. by saving 3.05 Kb. (5.40%)]
