Body Drop v8 Question
Old 10-11-2009, 10:48 AM   #1
RockerDragger's Avatar
Ive got a 2000 4.3 truck thats bodydropped with 22's .
My question is which motor mounts and headers is everyone running?
i need all the hood clearance i can get and i have sd control arms so i need room for them with the headers.
thanks for any help
Old 10-11-2009, 04:13 PM   #2
Heavy Metal Body Man
Maverick2664's Avatar
Re: Body Drop v8 Question
my truck is bodied with a v8 and heres a few things ive noticed along the way:
- if you plan on running a stock hood, expect to do a LOT of creative cutting, and your choice of intakes is severely limited, you may even be forced to go with a LT1 engine... buy a big bottle of asprins, youll need it... im running a goodmark 2.5 inch cowl hood and i still have to cut/relocate the underbracing, and im running fuel injection with is lower a lower profile than a carb and air cleaner is
- headers depends on how your truck is bodydropped... if its traditional then headman makes a set of nice longtubes that do not hang below the frame... if its stock floor'd then shorty headers or weld up your own, ive yet to come across a set of longtubes that dont hang lower than the engine cradle
theres a few places that sells the mounts, mine came from trans dapt
Old 10-11-2009, 11:13 PM   #3
Krazykrakr2186's Avatar
Any more advice?? i'm about to tear my truck apart do a traditional bd and do a carb'd v8 swap. I'll take all the ideas i can get.
also what can i just use a fuel pressure reg and keep my stock pump and sending unit?
Old 10-12-2009, 07:33 PM   #4
thats about all i have so far, im still building it and learning as i go
you can do a few things with your fuel setup, you can either do a pressure regulator like you say, but make sure it can go down as far as 7-8 psi, thats what a carb operates at, but that may cause issues with flow... i dont know though, the pressure will be there, but cfm may drop, im not too certain how a regulator regulates pressure, if you go this route ask someone who knows for sure
or you can pull out (or disable) the factory in tank pump and just use the mechanical pump on thats on the side of the engine and you wont have any problems
Old 10-12-2009, 07:42 PM   #5
Mine is trad dropped. and will be carbed and will has a 2.5 cowl hood
with the headers i didnt want them to hit my control arms is why i was asking
i was told that to start with 2.8 mounts instead of the 4.3 they set lower.
Old 10-12-2009, 07:44 PM   #6
ill take some pictures when i go to work tomorrow, maybe itll give you some ideas
Old 10-12-2009, 10:48 PM   #7
yep
cbennett's Avatar
Mine ia sfbd with a carbed v8 I am running sanderson header, motor mounts are from S10V8.com, sd upper arms, and a piston type fuel pump.
headers drivers side
pass side
motor mounts
fuel pump
kinda see the height of the carb in this pic
sorry for the long post
Old 10-12-2009, 11:36 PM   #8
firstgenon24s's Avatar
Good ideas here guys,I havent even gotten this far yet on my blazer as far as drivetrain but now I know what to expect,mines a 3 inch trad. bd'd 97 blazer with 22's and ART control arms.
Old 10-13-2009, 12:02 AM   #9
cbennett thanks for the help
where did you get your headers? and did you have to change the sterring shaft?
are you useing a stock oil pan?
thanks
Old 10-13-2009, 12:12 AM   #10
yep
cbennett's Avatar
thanks
Its a stock style oil pan, The headers came from sanderson, they are the angle plug version headers. I had a set of strait plug headers also they were just cheap ones from summit. I did end up changing the steering shaft.
Old 10-13-2009, 12:42 AM   #11
yes you can use the stock pan, you can even use high capacity pans because the extra room is added to the sides, not the bottom, so they dont sit any lower than a stock pan would
like i said earlier, my truck is stock floor'd, though things are still in mock-up, it looks like the pan will have at least 2 inches of ground clearance when laid out
Old 10-13-2009, 07:03 PM   #12
thanks or the help
whick mounts do you have 2.8 or 4.3?
Old 10-13-2009, 09:09 PM   #13
frame side mounts i dont know, they were on the truck when i bought it (no engine), i dont know if the kid changed them out or not, it originally had a 2.2... engine side mounts came from trans dapt
Old 10-13-2009, 11:25 PM   #14
groundforce1's Avatar
Heres a good site. s10v8.com
im in the process of dropping in a 350 in my 94 sten. its td bodydropped. i got the bod off right now, but u were talking bout using the 2.2 mounts. what do u mean? cause i was going to buy mounts off tht site but im concerned about room. btw im planning on running a tpi intake. they look sik and low profile. :-)
Old 10-13-2009, 11:38 PM   #15
so far i dont believe anybody has talked about using the 2.2 mounts.... who are you talking to?
Old 10-13-2009, 11:49 PM   #16
I think they confused 2.2 with using the 2.8 mounts because allegedly the 2.8 mounts can be used and have a lower profile. but im not sure about that.
Old 10-14-2009, 12:06 AM   #17
ROLL TIDE!!!!!!
draggindime072010's Avatar
i dont know about you bodydrop guys but i use 2.8 frame mounts i was always told the 4.3 mounts were too weak
and cbennett what is that fitting on your crossmember are you running your fuel line through the frame
i am trying to figure out my fuel line right now pm me about how your doing yours it looks awesome
Old 10-14-2009, 12:11 AM   #18
right ya i ment 2.8. the mounts on s10v8 look perty good. i was thinking bout trying to get some measurments for them and compare to the 2.8 mounts.
Old 10-14-2009, 12:02 PM   #19
yep
cbennett's Avatar
The more of a solid mount that i have posted above is from s10v8.com I had 2.8 mounts in before and just swaped these out didnt change a thing.
Old 10-17-2009, 01:13 AM   #20
5 Dime's Avatar
thanks guys for some input on v8 with a bd . Ive searched all over for some info on a v8 swap on a bd truck and havent found much with bd . mine has been td bd 5 1/2 and i need my engine to set as low as i can get it
Old 10-31-2009, 10:35 PM   #21
steering is my biggest concern.....
any more info on how that steering arm was modified
Page generated in 0.60941 seconds with 31 queries
[Output: 111.31 Kb. compressed to 102.91 Kb. by saving 8.41 Kb. (7.55%)]
