best cam for a prty stock vortec 350?? - S-10 Forum
post #1 of 22 Old 04-20-2007, 05:36 PM Thread Starter
s10baller2000's Avatar
User is: s10baller2000 is offline
I am building a vortec 350 to swap into my truck, all I need now is the cam and then the motor can be put together. I know that the vortec heads can only take a .480 lift or so.
I have two questions:
what is the best cam to use with stock heads?
what is the best cam to use with heads good to a .550 lift?
This is a street truck and will be a daily for the next few months a least.
thanks
Kyle
2000 s10
6.0/4l80e/pt88 in progress
post #2 of 22 Old 04-20-2007, 08:24 PM
So-GT0071's Avatar
User is: So-GT0071 is offline
Re: best cam for a prty stock vortec 350??
I'd contact comp cams or some kind of reputable engine company and have them grind you a cam or recommend one for you.
Sonoma GT #0071
- 5.7Liter Ls1 - 2.6Liter Kenne Bell Supercharger - Meth Injection - Built 4L60E - Ladder bar coil over rear suspension -
- Narrowed Ford 9 inch - Tubular front coil over suspension - iForged 18x7Front/18x12Rear -
post #3 of 22 Old 04-20-2007, 09:24 PM Thread Starter
I was thinking that, I just wanted to see if anyone had any personal experince with certain cam they liked or didnt like.
2000 s10
post #4 of 22 Old 04-20-2007, 10:47 PM
WGPV8S10's Avatar
User is: WGPV8S10 is offline
My opinion you can go bigger than a performer series edelbrock. In my truck power falls flat about 4700rpm (just my experience). But the best thing to really do is post #2 advice
2012 R56 S
2011 F800GS
1991 500hp LM7 S10 For sale
WGPV8S10 is offline
post #5 of 22 Old 04-21-2007, 01:32 PM
Isn't orange anymore!
bdydrgns15's Avatar
User is: bdydrgns15 is offline
This was a reply I received to the exact same question:
For the cam, I'd pick a Comp Cams grind somewhere in the 258 to 274 range, depending on how smooth an idle you want. Also, remember your motor has a hydraulic roller from the factory, and all you really need is the cam and valvesprings, you can reuse your stock lifters. The 270HR: XR270HR-10, Camshaft Part#12-422-8 Dyno Sheet would get you a hard running motor, but I'd probably be more likely to go with the slightly milder 264HR here: XR264HR-10, Camshaft Part#12-412-8 Dyno Sheet.
Dagen
post #6 of 22 Old 05-03-2007, 12:08 AM Thread Starter
would either of these cams work? I was wnating to not have to get my heads machined because I heard that when you cut the guides down you need to use roller rockers or your rockers or something will wear out fast. is this trure? if not im going with the 270hr
http://store.summitracing.com/partde...3&autoview=sku
Lunati Hydraulic Roller Tappet Camshafts: LUN-54760LUN - summitracing.com
2000 s10
post #7 of 22 Old 05-03-2007, 12:14 AM Thread Starter
also when I look these cams up on summit it says they are not computer controled. does that matter since I will have a custom tune?
thanks
A LOT
Kyle
2000 s10
post #8 of 22 Old 05-03-2007, 12:25 AM
BadS15v8's Avatar
User is: BadS15v8 is offline
Stock vortec heads have a maximum lift of around 480 or the press-in rocker arm studs pop out, as long as you upgrade to some screw in rocker studs you'll be good to go with stock Vortec heads.
BadS15v8 is offline
post #9 of 22 Old 05-03-2007, 12:28 AM Thread Starter
so I can get screw in studs and then do I have to get any machining done to run a higher lift cam?
sorry but I dont get it. I thought you had to cut the guides down to allow for more clearance?
2000 s10
post #10 of 22 Old 05-03-2007, 12:41 AM
dillon_b12's Avatar
User is: dillon_b12 is offline
Send a message via AIM to dillon_b12 Send a message via MSN to dillon_b12
I am going to be running and Brian at TBIchips.com recommends the LT1 Z28 cams. They can be had really cheap (got mine for $35) and will work with zero modifications.
1994 S-10 4x4 - Black, 4.3 TBI, Lowered 4/5, 98 S-10 Frontend, Zexel-Torsen Differential, Velm Sunroof, Flowmaster 40 Series, Sony CDX-MP70, Pioneer 4x6s, Pioneer REV Series 6.5s, Pioneer 4x10s, Adire Audio Brahma 12", Hifonics BX1000D, and Corvette C6 18x8.5s with 235/55/18 Michelins.
post #11 of 22 Old 05-03-2007, 01:10 PM Thread Starter
then what is the difference form the vortec motor to an lt1? I thought parts were not interchangeable because the vortec motor is a genI and the lt1 is a genII.
2000 s10
post #12 of 22 Old 05-03-2007, 01:28 PM
Gaaoooooo
MINTSICK's Avatar
User is: MINTSICK is offline
The lift limit of approx. .480" really has nothing to do with the rocker arms, it has to do with the retainer coming in contact with the valve seal/valve guide. If you really do not want to do any machining on the heads I would call up comp, tell them you like the specs on the 270 but you are interested in no more than .470 lift (to be safe, if you measured the heads you have you could get an exact #).
2004 Silverado Z71 ECSB - |Silver Birch Metallic|5.3|Custom Single Exhaust|Method Standards
1993 Mustang LX Hatchback - |Reef Blue|5.0 H.O.|5 Speed|MGW Short Shifter|70MM MAF|MAC Shorty Headers|Pypes O/R X|Spintech Pro Streets|3.55's|
1984 El Camino Conquista - |Black|5.0L|Comp XE262H|Holley 570|700r4 swap|2.41 open rear|
MINTSICK is offline
post #13 of 22 Old 05-03-2007, 01:46 PM
BadS15v8's Avatar
LT1's have reversed cooling system and a few other differences like cam driven water pump, and the optispark distributor mounted on the front of the engine negine the crank pulley and water pump.
The valve springs from a LT1 are great upgrades for the Vortec engine. The cam is also a great upgrade for the Vortec engine is your vortec had a factory roller cam. Just cause they're different motors, dosen't mean things won't exchange out. Look at the 4.3 and Small Block. Pistons, Rods, Bearing, etc.. will all swap out. The 4.3 is a Small Block with 2 cylinder chopped off.
BadS15v8 is offline
post #14 of 22 Old 05-03-2007, 01:48 PM
dillon_b12's Avatar
Read this...
LT1 cam digest (the ultimate one) - TBI - Third Gen .org : F-Body : Chevrolet Camaro, IROC, Z28, Pontiac Firebird, Trans Am
post #15 of 22 Old 05-03-2007, 02:50 PM
Build them right....Mod
philntx's Avatar
User is: philntx is offline
I used this cam in my 97 Blazer when the 5.7 Vortec was installed:
Comp Cam .501 Int .499 Exh lift.
210 Intake 224 Exhaust Duration w/112 lobe separation.
918 springs
w/ Crane Gold 1.6 roller rocker arms
Crane pushrods
LT headers
The heads were modified and prepped with screw-in studs and ported by Jared of CPR fame.
Fastchip tune by Ed Wright
It idled at 850 RPM and made 285 at the rear tires
philntx is offline
post #16 of 22 Old 05-06-2007, 07:24 PM
Miles
User is: milesp07 is offline
918 springs
Crane pushrods
LT headers
how did that cam idle for you?
milesp07 is offline
post #17 of 22 Old 05-11-2007, 12:06 PM Thread Starter
I found a stock lt4 cam that I can get for free. would this cam work with no modification?
thanks
Kyle
2000 s10
post #18 of 22 Old 05-11-2007, 01:47 PM
Mobile Performance
DimeDarkness's Avatar
User is: DimeDarkness is offline
Yeah I beleive that was a response from one of my questions at one time.
I love doing drugs. I like "Speed" the most. Want Some?
post #19 of 22 Old 05-14-2007, 06:40 PM
nicenlow97's Avatar
User is: nicenlow97 is offline
i am running a lt4 cam from a grand sprt vette with the vortec motor. but my heads were from sdpc and updated to handle .525 lift.
post #20 of 22 Old 05-14-2007, 07:19 PM Thread Starter
well my heads will be completely rebuilt with new guides cut down for how ever much lift I need. but what will the lift be with the stock 1.5 RR because the vettes had 1.6RR ??
2000 s10
post #21 of 22 Old 05-14-2007, 08:26 PM
User is: Blmfighter is offline
I'm new here! I used a comp Cam with 305 D and 525 lift. if you have goods heads and exhust. This is a great cam. If you have a auto you will need a 3500 stall.
post #22 of 22 Old 05-14-2007, 08:32 PM
philntx's Avatar
800 RPM in park.
Smooth
About 725 in gear.
2,400 stall converter.
Heads were modified for this cam.
"Red-light runners" should lose their license for 30 days.
Blazer was sold! Now in Michigan!
Sounds good! http://www.youtube.com/watch?v=aejtZxXyvA4
At the Track: https://www.youtube.com/watch?v=gs1Zs8TJJ_A
philntx is offline
